5925's, slop in gear train
Tower Hobbies
Logged in as Guest
  Printable Version
JR R2000, JRPR2000 10CH RX, and JR Synth TX Module
Seller:  Erick Royer
Details:   $400.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> 5925's, slop in gear train
Page: [1]
Login
5925's, slop in gear train - 7/15/2002 8:25:42 PM
jelaird
Status: offline
I have (2) 5925's just installed for ailerons and a 5945 on rudder in a 27% plane. ( not flown yet). I noticed some slop in the gear train of the 5925's and thought it was acceptable but after installing some 1.25" servo arms, the ailerons have way to much play at center and I don't want to risk flutter. This play is in the servo itself disattached from linkages. The 5945 on the other hand, has zero play at center. Is this normal on this model # or should I send them in.
Jack
       Post #: 1
5925's, slop in gear train - 7/19/2002 10:03:44 PM
MikeMayberry
Status: offline
The long arms will exaggerate any small amount of slop in the gears. What I have found is that the gears when rotated inside compared to each other it can affect the amount of slop since the tolerances can be minutely different. This is why some servos are tighter than others with exactly the same gears. A little extra grease will also help. This is the same with every servo on the market.
Mike.
(in reply to jelaird)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU1
