RE: Official Rustler Thread
Tower Hobbies
Logged in as Guest
  Printable Version
AXIAL AX10 SCORPION CRAWLER 12MM HEX WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Official Rustler Thread
Page: <<   < prev  180 181 [182] 183 184 185 186 187 188 189   next >   >>
Login
RE: Official Rustler Thread - 7/8/2008 5:31:41 AM
rustleracer23
Status: offline
just ordered my aluminum idler gear from tower
_____________________________
desert rat rustler(not ready yet) 4-tec
tamiya-midnight pumpkin,super hornet
(in reply to simplecj)
       Post #: 4526
RE: Official Rustler Thread - 7/8/2008 4:23:12 PM
HeliSmith
Status: offline
quote:
ORIGINAL: simplecj
I would say don't go with that wheely bar, get the Swami. That Integy one only mounts with two good holes, the Swami mounts on all four main mounting holes and has bigger wheels.
As far as the pinion gear goes, I'm running the Sidewinder w/ 4600 motor and I use a 18 tooth pinion and a 83 tooth spur. Good enough speed, about 35+ with 3s lipo and plenty of torque. Just stick to the lower end of what they recommend in the CC gearing chart and you'll be fine. And yes, you will want metal tranny gears!
You can't get Swami from Tower huh? Where's the best place?
So this is the correct tranny gear?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ94&P=Z
Pinion
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ79&P=OW
I took the cover off and I have the 86T 48P gear so I should get the 83 then?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNMN7&P=OW
http://www.helismith.com
       Post #: 4527
RE: Official Rustler Thread - 7/8/2008 4:39:12 PM
zimm11
Status: offline
i dont know if i wanna bash or if i wanna race a little is the rusty able to bash good, and race.
(: ʞɔnן pooƃ - ʇı pɐǝɹ uɐɔ noʎ ɟı ǝןıɟoɹd ɹn sı sıɥʇ ʇnd
(in reply to HeliSmith)
       Post #: 4528
RE: Official Rustler Thread - 7/8/2008 5:02:37 PM
simplecj
Status: offline
You can get the Swami Bar at the Official Swami Site
That's a good pinion to go with. You could probably stick with the 86 tooth spur if you want it more geared down. CC actually recommends larger spur gears.
I believe that is the correct idler gear. I got the VXL, so I haven't had to replace any internal gears yet.
AS FOR THE LOSI Adam Drake 2 SHOCKS>>>>
I put them on last night and I am slightly dissapointed. They are excellent quality, but not a straight fit for the rustler. The included springs are way too short for the rear, so I had to stick my blue T-maxx springs on them. I put the red springs on the shorter front shocks. The rear shocks are too short, so you have to move the bottom mount in several holes towards the body which gives you a more vertical position.
Also, I had to try out multiple screws to mount them. The original screw that was already on the truck won't fit through the ball on the bottom of the shocks. This could be remedied (i think) by using the bottoms off the original shocks. Also the top mount hole is too big for the stock screw. I used some longer screws and the included grey bushings to mount the tops. The front bottom mounts need a wider ball joint to fit the space, so I just put the stock ball in, but the shock is kinda loose on it.
Overall suspension still seems very soft even with the T-max springs on, not sure how good they will be for bashing. Our RC club is supposed to be doing a demo at an upcomming city festival so I'm going to stick the street tires back on and see how it handles. I'll follow up with more including pics later.
(in reply to zimm11)
       Post #: 4529
RE: Official Rustler Thread - 7/8/2008 6:00:09 PM
warheadforever
Status: offline
quote:
ORIGINAL: HeliSmith
quote:
ORIGINAL: simplecj
Pinion
That should just about do it.
I have God, Guns, and southern pride!
May you grass be green, and your tides be high forever.
       Post #: 4530
RE: Official Rustler Thread - 7/8/2008 6:06:08 PM
zimm11
Status: offline
anybody gonna answer my qusetion about bashing the rusty
(in reply to warheadforever)
       Post #: 4531
RE: Official Rustler Thread - 7/8/2008 6:09:10 PM
warheadforever
Status: offline
quote:
ORIGINAL: zimm11
Yep I will answer you right now. The answer is it is a great basher, and a good racer, I mean it does go 70+ after all. (Not that you go that fast at a track.)
< Message edited by warheadforever -- 7/8/2008 7:13:05 PM >
       Post #: 4532
RE: Official Rustler Thread - 7/8/2008 6:24:16 PM
daywalker121800
Status: offline
its good fo bashing as long as u are ready to replace parts...do not get aluminum shock towers...make sure u get the rpm front bumper...and if u run a wheelie bar on it make sure u take it off in the dirt or when jumping it....that's a good start...if u plan on getting lipos for it..u have to run 11 volts to go speeds of 60 plus...and u have to begeared very differently
DrDaywalker-obsess much???Rustler vxl. custom 2 speed rustler Jato aka JESTER 2.5r, tmaxx 2.5, nitro rustler 2.5, Losi xxxt
       Post #: 4533
RE: Official Rustler Thread - 7/8/2008 6:42:27 PM
zimm11
Status: offline
i got a felling that im gonna go with a stampede though i have read and it says that the pede is a better basher, and u can race it wiht lot o upgrades
(in reply to daywalker121800)
       Post #: 4534
RE: Official Rustler Thread - 7/8/2008 7:10:41 PM
stonecolded
Status: offline
Why? do not get aluminum shocktowers????
Mugen MBX5prospec / Savage SS / TA05R / Rustler VXL.
Tucano lookalike w brushless hacker. KO propo EX10Helios.
       Post #: 4535
RE: Official Rustler Thread - 7/8/2008 7:11:41 PM
daywalker121800
Status: offline
u can race anything with a lot of upgrades....after I did the extended arm conversion and some other stuff my rusty was good on the track...remember though...the pede and rusty r basically the same truck except the rusty has a better center of gravity..get some good offroad tires andyoull be fine for the track with a rusty
       Post #: 4536
RE: Official Rustler Thread - 7/8/2008 7:12:14 PM
warheadforever
Status: offline
quote:
ORIGINAL: stonecolded
Because if you land up-side-down then you will more then likely bend it, and when you try to bend it back, it tears.
(in reply to stonecolded)
       Post #: 4537
RE: Official Rustler Thread - 7/8/2008 7:14:51 PM
