BigBasher
AB, CANADA Status: offline
- Snapped Left front axle clean off right at the CVD cup. CVD is intact, just a gaping hole where the axle used to be. T'was a beautiful sight, LST clearing the doubles, sailing over the table tops, floating through the whoops... THEN... clears the doubles cleanly yet again looking like an angle flying through the air and SNAP the left front wheel goes zinging off into the sky when the truck returned to terra firma... ARGH@!!!!!!! The left side CVD cups are WAY too brittle / there is too little material holding the axle to them. There is a ring less than 1/2 a millimeter holding that entire axle on. Snapped clean off. For a 13+ Lb truck, I would have expected a little more... Rich T., will Losi / Horizon replace this for me? (I know others have had this same issue and have gotten replacements.) I will call on Monday I guess... I would just go buy replecements BUT my biggest problem up here in the frozen north is that BOTH my LHS's refuse to bring parts in "untill they know what breaks" They are really lame when it comes to supporting the Losi crowd up here. All the AE and Kyosho crud you can shake a stick at but they won't support Losi unless it's the Mini-T... ARGH!!!! Anyways, it was a blast running this truck, now it's shelved until I get replacement parts...
_____________________________
http://www.monsterbashers.com LST # 132
