jefx
IL, Status: offline
quote:
ORIGINAL: RMG2 quote:
ORIGINAL: Jayphred My body looks identical to that also. Must be the same hit and run driver that ran into me I broke my third black axle today. I hope a better axle comes out soon. Also broke a second set of Losi clutch springs (all three). Time for alternatives. No more Losi clutch springs for me. Also stripped the HI spur gear after a rock got in there and chewed it to hell first. Me want better cover. Take a look at what this guy did to solve the spur gear cover problem. http://www.bonetracker.dk/rc/lst/lst2.html That's pretty cool with the carbon fiber and all. I too got a rock in there and nearly destroyed my pinion gear. After removing the rock from the spur, I took a file and straightened the teeth on the pinion a bit so that they could still grab a little, then I readjusted the gear mesh. My new gears should be in stock around the middle of next week. Is Losi coming out with a new and improved cover? Also if you look at the bottom of the cover, there is a hole for debris to come out of. That hole is perfectly lined up so that roost from the front right tire shoots straight into the 2-speed assembly. I think that this is a majority of the reason people are having problems with the gears stripping out. I ended up putting a piece of tape over the hole to help keep debris out.
_____________________________
Who farted??!!
