sopwith
CO, USA Status: offline
I have been using water to replace some of the oil in the fuel that I mix to reduce the cost and mess. I have been using 10 percent "Morgan fuels Heavy Gold 4 stroke oil" with 5 or 10 percent water. I have good operation, cleanliness, needle valve response, and no overheating problems. I suspect there will be no detremental effects in the long run, but only time will tell. I figure that since the latent heat of vaporization of water is so high, it will be a far better coolant than the oil is with just conduction cooling. Has anyone tried this? I have identical or better power as when I use 20 percent oil, but the engine and plane are much cleaner. I also seem to have fewer dead sticks, can run the engine leaner, and the needle valve sensitivity is less. I have been using these mixes for a few weeks, so haven't fried any engines yet. After a few months when summer arrives the story may change. Sopwith
