RE: Home-brewing fuel
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-26cc Gas Engine
Seller:  XYZUSA
Details:   $219.00   |  4/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> RE: Home-brewing fuel
Page: <<   < prev  4 5 6 7 8 9 10 11 [12] 13   next >   >>
Login
RE: Home-brewing fuel - 8/24/2006 7:02:31 PM
mustangous
Status: offline
I am trying to get the scoop on this fuel mixing process....
I was reading earlier somewhere in all these post that soemone was using the Klotz heli oil(for cars or trucks) instead of the Klotz KL-200 because its thinner and less messier out of the exhaust. Has anyone esle done this or can confirm that this is a good idea or should i stick with the KL-200.
Also tell me if i have this correct: I was gonna try to get VP's M1(methanol)(use62%) with VP's Nitro 100(use 20%) with some klotz heli KL-198(use 14%) and a little Klotz Castor BC-175(4%)
If the heli oil is not a good the i was gonna use 64% M1, 20% nitro, 12% KL-200, and 4% castor oil.
I will be using this fuel for a few lst's. These % numbers is just a base, obvioulsy i'll adjust here and there if needed. Thats why i like the "making my own fuel" method. I dont know what i am getting with these off the shelf fuel. Not many say what their percentage are....
Thanks for anyones help....
_____________________________
LST
Mini-T
(in reply to Prairie Mike)
       Post #: 276
RE: Home-brewing fuel - 8/25/2006 12:54:23 AM
hpi apollo
Status: offline
i would suggest using VP's M3 methanol because it has less additives in it that your engine doesnt need, i plan on using 12% all Klotz benol castor oil in about a week when i start mixing mine
95% of statistics are made up on the spot
(in reply to mustangous)
       Post #: 277
RE: Home-brewing fuel - 8/25/2006 4:24:50 AM
DrRider-X
Status: offline
try Powermasters they are outstanding as far as fuels go so far. www.powermasterfeuls.com they have it for every need so far.
       Post #: 278
RE: Home-brewing fuel - 8/25/2006 3:57:56 PM
RaceCity
Status: offline
KL-200 is a fine oil. It's been around forever. It's is unwise in my opinion to choose an oil on the basis of the "exhaust mess". Oil serves a very distinct purpose in your engine, and "EZ cleanup" is not a good reason to choose one oil over the other. Worry about the expensive engine it protects, and less about paper towels....the latter being vastly cheaper.
KL-601 "HeliGlow" is a fairly new product. It is a much lower viscosity product compared to KL-200. (5W -vs- 50W). There may be advantages, but a much thinner oil doesn't sit well with me. Particularly in a harsh environment. I mean, if your family car manufacturer specifies 15W-50 for your engine...would you feel safe dumping super thin fork oil in the crankcase instead???
I don't know.
Use either one (KL-200 or KL-601), but I'd keep at least SOME castor (BeNol, etc) in the blend for a margin of protection when all the synthetics have long since gone up in smoke.
An option is to use KL-100. It is a pre-mixed 80/20 blend of Techniplate (KL-200), and BeNol. It would save you the hassle of purchasing the Synth and Castor oils separately.
Homebrewing is fun!
< Message edited by RaceCity -- 8/25/2006 4:02:23 PM >
AMA 63990
(in reply to DrRider-X)
       Post #: 279
RE: Home-brewing fuel - 8/25/2006 5:15:38 PM
mustangous
Status: offline
quote:
ORIGINAL: RaceCity
I don't know.
Homebrewing is fun!
Cool thanks for the information
I am having problems getting the nitro... I might have to drive a little ways to get(1.5 hrs), but i have to purchase 5 gallons($150)of it at a time... Now what can i do to keep it as fresh as possible? Could i separate them in quarts or other smaller containers and storm them in a cool dry place? Or once i open the 5 gallon can there is nothing other to do other than use it fast...???
LST
Mini-T
(in reply to RaceCity)
       Post #: 280
RE: Home-brewing fuel - 8/26/2006 2:54:57 AM
RaceCity
Status: offline
5 gallons of nitro at a time? Wow...
Being in NJ, you might contact Stan at S&W fuels near Easton, PA. No guarantees, but he might be able to help you with smaller qty's of Nitro. Alternatively, Klotz sells their Nitro in one-gallon cans. It's about $45/gal list...a Klotz dealer in your area might be able to do better price wise.
In the absense of a kart-racing shop (where I buy most of my stuff), I'd guess that a dirt bike dealer might carry Klotz products, or could order them for you. You'll have to do the homework on this.
As for storing the fuel making chemicals....I'm not big on keeping any more of the stuff on hand than I can use in a relatively short period of time. Keeping the ingredients fresh is one thing, but a stockpiling flammables in your house is entirely another. I'm not recommending it.
Good luck with the homebrewing.
AMA 63990
       Post #: 281
RE: Home-brewing fuel - 8/27/2006 5:17:32 AM
hpi apollo
Status: offline
has anyone here experimented with sidewinders CP-07 additive that claims to reduce friction by 80%? if so, where can you buy it without being blended with something else, thanks
       Post #: 282
RE: Home-brewing fuel - 8/27/2006 6:36:12 AM
RaceCity
Status: offline
Everybody has some miracle additive that will magically reduce friction by some unverifiable amount.
Think about how many "motor elixirs" have been marketed over the years...each promising an end to "power robbing" friction, etc...
Does anybody actually believe this anymore?
Yes...Morgans sells this product, but you'd have to contact them for details.
Given that the highest performance model engines on the planet use nothing but methanol and castor....I wouldn't worry about it. Use good ingredients, tune carefully and the performance will take care of itself.
< Message edited by RaceCity -- 8/27/2006 6:43:14 AM >
AMA 63990
(in reply to hpi apollo)
       Post #: 283
RE: Home-brewing fuel - 8/27/2006 1:48:35 PM
Dr Nitro
Status: offline
quote:
ORIGINAL: hpi apollo
They're secret additive is....OIL!! Yes, oil has been known to reduce friction by over 80% when using it over not using OIL at all in your fuel...LOL
There are a lot of good friction modifiers and extreme pressure lubricants out there that are worth their weight in gold, the reason exotics are not in wide use in the rc fuels is the expense. The good ones are way too expencive to be an economical additive in the percentages necessary. There are a bunch of low cost ones out there that have little if any benefit when used in a methanol based fuel environment, still not worth the cost.
If Morgans actually had something that was working its one of these things: Something fairly expensive to prop up a very substandard base synthetic, or something cheap to prop up a mediocre base synthetic, or just nothing at all and just telling people there is something there and still using a mediocre oil. The RC industry is 85% marketing hype and 15% facts. Few product makers have my respect with the product they sell, when it comes to fuel I trust Cooper's and when Brian is questioned, he gives you a no-BS response. You can also trust S&W, if you can get it, its good fuel and oil too.
Dr Nitro
       Post #: 284
RE: Home-brewing fuel - 9/26/2006 3:16:19 PM
Team_Monkey
Status: offline
Hello Home brewers!
First post here. It has taken me MANY visits but I've finally finished reading every post on the thread. I think every body should do that before openning their pie-hole. It would reduce a lot of the duplication.
Any-hoo, like many others I have been lookign for sources of ingredients and thought I'd post mine to help others.
Norwalk Raceway in Norwalk, Ohio( http://www.norwalkraceway.com ) has rolled back Methanol prices to $2 per gallon this year. They have a regular gas pump of it so bring a container.
I ordered a gallon of Baker's AA castor oil from SIG ( http://www.sigmfg.com ) for $27.98 delivered. best rice I found after weeks of looking. If I read it right, international shipping is only a dollar more and there's no HAZ-MAT fee on bean oil!
I bought KLOTZ KL-200 at the local bike shop for $10.99 a quart but it would have been cheaper to order a gallon of it from SIG with the castor and combine shipping.
The Nitromethane has been VERY hard to find but I finally found two local sources in North Eastern Ohio. R & R Auto body(216) 267-5454 in Cleveland and Coppersmith Powersport (330)724-2900 in Akron,Ohio. R&R is not ordering any more fuel this year but Coppersmith i ssupposed to have some. I'm trying to get them on the phone and I'll post here if they have any more.
All this breaks down to the following cost in USD after tax and shipping:
Castor $.22/oz
KLOTZ $.37/oz
Nitro $1.03/oz (this was a cost for shipping a quart of it, I'm hoping to lower it.)
Meth $ .02/oz
So a gallon is roughly $14.86 to make 5% nitro, 18% oil (50/50 castor/syn). No real savings, but most of us aren't here to save a few pennies on fuel. For true money savings, the way I figure it is to buy a gallon of 15% nitro with any oil blend. Then just do the math to blend that down to three gallons of 5% nitro and the oil content you want. Doing that brings it just under $11 per gallon. OR get a higher nitro content fuel and blend it down further, you see how it works.
All this came about as the Magnum engines I ordered recommend castor oil as the lube and I like to build things myself. I'll run a 50/50 blend of castor & syn. But I will be playing with that and the overall oil percentage. The castor is cheaper than the syn so I may be playing with a higher percentage of castor but a lower overall percentage of oil.
I had a Saito .65 that hated nitro so I'm hoping my new Magnum .91 will be the same. 0% nitro, 15% oil (70/30 castor/syn) would run me $10.89/gal.
I read an excellent article ( http://www.amaclub217.com/newsletter/TakeOff%20June03.pdf ) about model fuel oil content. I recommend it.
This is long enough. Thanks so much to the long time posters, there are too many of you to list. But to the fellow with the Emu head on his posts....that cracks me up.
Oh, if anyone lives in the Medina, Cleveland, Akron area and wants to split up costs, I'd be willing to look at that too.
(in reply to Dr Nitro)
       Post #: 285
RE: Home-brewing fuel - 9/26/2006 3:59:59 PM
downunder
Status: offline
quote:
ORIGINAL: Team_Monkey
Who? What? CRIKEY!!!!
(in reply to Team_Monkey)
       Post #: 286
RE: Home-brewing fuel - 9/26/2006 5:47:10 PM
Team_Monkey
Status: offline
Fast update!
Coppersmith Powersport in Akron has one 5 gallon can of Nitro left at $159.00.
Get it if you can, I think I'll just buy some commercial fuel and mix it down to my spec's. I'll not fly enough this year to warrant 5 gallons of nitro. It will also give me a chance to experiment with some small batches of break-in fuel and 0% nitro sport fuel.
But next spring....
if you haven't checked it out, the Engine Conversion forum has a LOOOOOONG thread on gas to glow conversion with no ignition. They mix commercial model fuel with high octane pump gasoline to make fuel. Some guys are using it in their smaller engines too. Might have to tailor the amount of methanol to keep the glow plug hot though.
(in reply to downunder)
       Post #: 287
RE: Home-brewing fuel - 9/27/2006 12:56:28 AM
hpi apollo
Status: offline
may i ask where you ordered the sig oils from? i am looking into getting some synthetic oils for my fuels, and castor that cost a little less, so i figured sig would ahve it, without the hazmat shipping fee
       Post #: 288
RE: Home-brewing fuel - 9/27/2006 3:54:53 AM
lukesp
Status: offline
Agreed
       Post #: 289
