Acetone
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-26cc Gas Engine
Seller:  XYZUSA
Details:   $219.00   |  4/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Acetone
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
Acetone - 9/3/2002 9:23:29 PM
Graham-RCU
Status: offline
[QUOTE]Originally posted by downunder
Now this is where using metrics makes things so much easier
Say you want to mix 1 litre (about 2 pints) of fuel with 12% nitro, 18% oil and 3% acetone. Now 1 litre is 1000cc so go from there.
120cc nitro
180cc oil
30cc acetone
Top up with methanol to make 1 litre
Shake.......
If you want to make 4 litres (slightly over a US gallon) then just multiply the figures by 4.
[/QUOTE]
First I had heard of Acetone in the mix, is this an error or am I missing something????
_____________________________
Graham
(in reply to volare)
       Post #: 26
Acetone in fuel - 9/3/2002 9:39:51 PM
Dave Harmon
Status: offline
Yes, you are 'missing something' as so many like to say these days. Here is a quote from a previous post...
"Acetone is a handy additive at about 3-5% because it increases the combustion flame front speed, reduces the tendency to pre-ignite with lean mixtures (helps stop throwing props on 4 strokes) and reduces the ability of methanol to absorb water from the air."
I don't use it because my engines (YS 140-L) don't have the problems that are mentioned. If I did have those problems, I would fix those problems instead of slapping an acetone bandaid on them.
You only need 3 ingredients....oil, nitro, alky. Your engine size and make and application will determine what the mix will be.
By the way, in the upper right hand corner of this screen you can search for the word 'acetone' and it will find every post re this subject.
Dave
Mix Your Own Fuel....It's Easy!
       Post #: 27
Fuel Price - 9/3/2002 11:33:48 PM
Dave Harmon
Status: offline
Capgains....Dan, using your percentage numbers and the price I am paying for oil, nitro & alky, I come up with $9.50 gal for mixed fuel. I figured this up using Klotz KL-200 straight synth oil at $19.20 gal, nitro at $27 gal, alky at $3 gal. The Klotz KL-100 synth/castor oil is the same price.
Dave
< Message edited by Dave Harmon -- Sep 3 2002 6:39PM >
       Post #: 28
Home-brewing fuel - 9/4/2002 12:34:58 AM
Graham-RCU
Status: offline
Thanks Dave... need to be straightened out on that one..
Graham
       Post #: 29
Home-brewing fuel - 9/4/2002 3:19:00 AM
Capgains
Status: offline
Thanks Dave,
You gave me a mark to look for now. Like JS3 I am having trouble finding a supplier for Nitro and Methanol in my area ( I've just never gone looking for it). We just don't have many speed shops. However, I do have a neighbor that races dragsters, and the manager of the local Chevy dealer is a funny car driver. They must be getting it from somewhere. I found a web page [url]www.cometkartsales.com/[/url] that has kl-200 for $5.95 qt. I like the idea of knowing what is in my fuel, and if I can save a few bucks as well.....great.
This whole thread brings up something that I think a lot of us take for granted. Fuel quality is not a constant when it comes to running our engines. How many times have we chased low needle and high needle settings because we thought they were messed up when really the fuel we were using was junk? Most of the time we don't even think about it.
Dave, do you have an optimal batch size? I really don't want to have a drum of methonal sitting around getting stale because I didn't need to make anymore fuel or ran out of another ingredient. Do you buy in batches to make a certain amount?
Dan
Altamont Airport, Hair Care and Tire Center
       Post #: 30
Fuel Price - 9/4/2002 5:28:14 AM
Dave Harmon
Status: offline
Dan....great! You have it 3/4 made already....those racers will know exactly where to get it.
This is what I recommend...VP Fuels is the only mfg of nitro and it is available in a sealed 5 gallon can. I pay $27 gal in 5 gal quantity. If your seller does not handle nitro in that small of a container, you can pick up empty fuel bottles at the field and use those, or you can buy a 5 gallon 'race bottle' from the seller and put it in there. Race bottles are about $10 and very worth it as the top is sealed with an 'O' ring. Definately buy a race bottle for the alky...that 'O' ring will keep out all the moisture...buy the alky in 5 gal quantitys too. Please enquire the seller if he will order cases of KL-200 too as you are getting ripped off at $5.95 qt.
Cases consist of 10 qts @ $48 = $4.80 qt.
I use a lot of nitro because I use 30% nitro and 24% oil (HeilGlo) in my pattern and helicopter engines. 18% if I use KL-200. I use the HeliGlow oil all the time now as the idle is somewhat improved due to the thinner oil not loading up the plug as much as the KL-200 even though the % is 5% more...less oil drag too because it's so thin = more rpm. Also, if you are concerned about how much oil gets on the plane from the exaust, the HeliGlow has a LOT less mess.
Remember that the main way you can save money, if that is a consideration, is to buy the ingrediants in quantity to get the price down. The quality of the ingrediants comes with the product no matter how much you buy or how much you pay.
Alky will last a very long time if properly stored....in a race bottle. During a slack period for me, I had a couple of gallons in a 5 gal race bottle in my garage for almost 3 years. When I used it there was no problem.
I will say though, when you start mixing fuel, get a large plastic funnel with a screen in the outlet that will fit into a used fuel bottle you scrounged from the trash at the field, put a coffee filter in the funnel and pour the nitro & alky through it. You will be surprised at the dirt that gets into that stuff from the mfg.
When you mix, use a graduated, glass measuring cup...pour the oil in the fuel bottle FIRST with out the funnel & strainer, then the nitro & alky through the funnel & coffee filter using the glass measuring cup. Then fill the remainder of the fuel bottle with alky 1/2 way up the handle....no need to measure the alky.
I mix only 1 gal at a time...cuz I might change my mind...haha...and that's one of the advantages.
Lemme know how you make out...
Dave [email]K6XYZ@attbi.com[/email]
       Post #: 31
Homebrew fuel - 9/9/2002 2:59:49 AM
fiery
Status: offline
Hi Dan
To answer your earlier query
1/ pre mix fuel in Australia is dearer than what you pay in the US
2/ Methanol appears to be cheaper here
3/ Nitro is much more expensive (double)
4/ syth oil is a little more expensive. Castor about the same.
Also, we don't seem to get the get great range of pre-mix fuels that seem to be readily available in the 'States. Cool Power and Klotz KL200 techniplate are the readily available syth oils, sold in gallon (or 5 litre) jugs.
Many more Australian flyers make up their own fuel. Where I am it's the "norm" for serious flyers. Only beginners seem to buy pre-mix. Costs saving has a lot to do with it. Also, you get the blend you want - not what is offered by a fuel manufacturer.
Regards
fiery
       Post #: 32
Ahhh very well then!!! - 9/9/2002 7:30:21 AM
Capgains
Status: offline
I was just curious about the cost situation, but now I am really interested in the quality control of it all, and the over all simplicity. I am also beggining to see how premix may have been the source of some of my problems of critical tuning issues.
Thanks for your response from down under.
Dan
       Post #: 33
Home Brew fuel - 9/9/2002 11:02:22 AM
fiery
Status: offline
No worries Dan!
(Oz talk for "your'e very welcome!"
fiery
       Post #: 34
Home-brewing fuel - 9/10/2002 9:01:18 PM
hilleyja
Status: offline
I also heard that an oz of Armorall in your fuel mix keeps it from frothing in the airplane's fuel tank.
Jim Hilley
AMA #671825
RCCA# 758
Twist 150 Brotherhood #14
       Post #: 35
Home-brewing fuel - 9/11/2002 3:11:42 AM
Fuelman
Status: offline
An ounce of Armour All? Thats a very large amount.
The trick is, if one chooses to use Armour All as an anti-foaming agent, is to add only a drop at a time untill the foaming stops.
I do not recommend the use of Armour All as an anti-foamer, I simply know it is in wide spread use out there.
A much better solution is to properly pad the tank and balance the prop to eliminate as much vibration as possible.
Fuelman
Fuelman
Cooper Fuels LLC
       Post #: 36
Home-brewing fuel - 9/11/2002 3:30:21 AM
Capgains
Status: offline
I don't know why you'd want to use Armoral in the fuel either.
Do you suppose it keeps the inside of the fuel tubes moist and protected from harmful UV rays?
I did see some of these outfits that sell nitro and methanol also sell an additive that makes the exhaust smell pretty, like fruit or perfume.
Wouldn't that be a trip to come home from the field smelling like Channel 5? Bet my wife would be wondering what the heck goes on out there (or her lawyer).
Dan
       Post #: 37
Home-brewing fuel - 9/11/2002 7:06:00 AM
Steve Guinn
Status: offline
Source for nitro.
https://www.worldwideracingfuels.com/default.htm
"The weather is here, wish you were beautiful."
J. Buffett
       Post #: 38
Home-brewing fuel - 9/11/2002 7:13:26 AM
downunder-RCU
Status: offline
ArmorAll contains silicon which is the active ingredient in cutting out foaming. It reduces the surface tension of the fuel so bubbles can't form and one drop in a gallon of fuel is all that's needed. For those who doubt how well it works, shake a part filled gallon jug until you've got lots of foam on top then quickly give one light spray into the fuel. The foam disappears instantly. Give the jug another good shake and you still won't see any foam. Contrary to some rumours it has absolutely no affect on plug life either.
       Post #: 39
Armor All - 9/12/2002 7:05:02 AM
rslstft
Status: offline
Whether it's right or wrong, I have been adding about 2 drops of Armor All per gallon of mixed fuel that I make. I mix 15% for my 2-strokes and 25% for my 4-strokes and never have had a problem with foaming or plugs life being short. In fact, some of my engines haven't changed plugs in almost a year and haven't touched the needle valve. Maybe I'm just lucky, but all of the engines run very well, no different in fact since I quite buying fuel and started mixing my own.
