POWERMASTER
Joined: 10/27/2002 From: Elgin, TX, USA Status: offline
Rsieminski, The FAI Pylon races do require FAI fuel, 80% Methanol, 20% Castor for these races. The Pylon Gold Cup Races, fueled by Powermaster Fuels, use fuel that does contain Nitro in the amount of 15% and 18% oil content of which 2/3 of the oil is synthetic and 1/3 is Castor oil. quote:
ORIGINAL: rsieminski The lower the nitro, the cooler the engine will run. If the engines on no nitro were melting some component on the engine, than the NV was set wrong, or there was too little oil in the mix. There is no mystery, synthetics will burn up way before castor will. Yes it may cause a litle more gum, than the synthetics, but break them down and clean them once a year(like you should any high performance engine), and they'll last years. Castor makes engines run cooler, by spuwing that oil all over the plane. That's what carries away the heat. Methanol has almost twice the latent heat of evaporation. This means it will carry away with it more heat than a higher mix of nitro, net resut is that it runs cooler. You can regain back most of those 2 or 300 rpm, by increasing the compression ratio. The pylon racere use only no-nitro/castor fuel. They avg over 130 mph. A little nitro gives you some slack with the NV, but it's not really necessary.
_____________________________
Wendell Hammond
