BALANCING SPINNER
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> TEAM RCU >> TEAM RCU - Josh Glavin >> BALANCING SPINNER
Page: [1]
Login
BALANCING SPINNER - 7/18/2004 3:06:35 PM
fredycompean
Status: offline
Hey Josh,
Please suggest how I can balance my spiner. It's aluminum and clearly not balanced. Should I ligth sand it? Add weight?? It's a big spinner and I don't want to mess it up. It cost me like 90 bucks.
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: BALANCING SPINNER - 7/19/2004 10:28:46 PM
DENNIS C
Status: offline
what spinner is that?
_____________________________
"Opinions are like Buttholes EveryBody has one "
(in reply to fredycompean)
       Post #: 2
RE: BALANCING SPINNER - 7/19/2004 10:43:02 PM
fredycompean
Status: offline
I have no idea, I bought the plane already with it, but then my friend that saw it told me that they cost like 90 -100 bucks. It's awesome and extremely light.
(in reply to DENNIS C)
       Post #: 3
RE: BALANCING SPINNER - 8/10/2004 5:12:07 PM
IFLY3W
Status: offline
Looks like a Tru-Turn or a Paragon..............
Chris~
       Post #: 4
RE: BALANCING SPINNER - 8/10/2004 5:28:39 PM
fredycompean
Status: offline
well this is how it ended. up
is that a tru-turn?
Click for fullsize
< Message edited by fredycompean -- 8/10/2004 12:31:03 PM >
(in reply to IFLY3W)
       Post #: 5
RE: BALANCING SPINNER - 11/15/2004 3:17:05 AM
Spaceclam
Status: offline
look in the back of the cone. on the inside, at the front of the cone, if it is tru-turn it will be stamped there.
Duct tape is like the force. It has a light side, a Dark side, and it holds the universe together.
       Post #: 6
RE: BALANCING SPINNER - 11/15/2004 4:11:52 AM
DENNIS C
Status: offline
Freddy that backing plate looks like its bent some.
From what i was told on how to balance a spinner. it should sit at 3:00 & 9:00 just like you have it. and it sholud balance at 12:00 & 6:00 also.
< Message edited by bodymann -- 11/15/2004 4:12:18 AM >
(in reply to Spaceclam)
       Post #: 7
RE: BALANCING SPINNER - 11/15/2004 4:22:13 AM
Spaceclam
Status: offline
the spinner cone is bucklingtoo. forget balancing it, get a new spinner. that is dangerous. remember, aluminum fateauges, so you dont want to fly it with a backplate and a cone like that one. here's a tip for spinners with lightened backplates. only tighten them as much as you wan with your pinky. i know it sounds like disaster, but if the spinner is any good, it will have a friction locking system such as that on the truturn spinners, so a pinky is tight enough. I dont think it is a truturn though because of the shape of the cutouts. truturns dont use that flower-pedal shaped cutout for lightening the spinner. if i am not mistaken, that is one of the airwild nova spinners. check this out. http://www.airwildpilotshop.com/MoreInfo-1.asp?title=product&id=158
also, a balanced spinner should balance in any attitude you put it at. if it's balanced, that means the forces on each side are equal, so it should not matter if it's 3:00, 4:00, or whatever you may, it should balance.
< Message edited by Spaceclam -- 11/15/2004 4:28:04 AM >
       Post #: 8
RE: BALANCING SPINNER - 11/15/2004 11:09:53 AM
Geistware
Status: offline
Why I do is add epoxy and sawdust to the light side a little at a time to balance
You have to balance the spinner and backplate together. Doing them seperately is difficult. Just make sure that you put them back the same each time.
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 9
RE: BALANCING SPINNER - 11/16/2004 1:08:23 AM
Blow n Go
Status: offline
Hey Freddy,
Enjoyed meeting you here in Ft Worth. Hope to see you again next season.
I have to agree, unless that's an optical illusion, I don't think you're problem is balance, but rather your spinner and backplate are damaged to badly to repair. Also , Tru-turn is adamant that they don't want you to balance their spinners. However.......if you really want to, here is how to do it:
Balance the backplate first. I use a rotary file on the heavy side, although adding epoxy to the light side is just fine too. Once the backplate is perfect, couple the cone and backplate together and balance them as an assembly. That is the only way to keep the cone aligned while you balance it. I had to cut an extra long rod to reach through the whole assembly. Adding epoxy is the only feasible way of balancing the cone. Add a clump to the light inside of the cone.
When it's perfect, break the cone and plate apart, and reseat them in a different orientation (spin the cone about 90 degrees relative to the backplate). Recheck the balance with this orientaion and they should be perfect again.
You will never be able to balance a bent or cracked spinner. I know it hurts sometimes having to trash one.......I lost 4 last year for different reasons.
Good Luck! CJ
(in reply to Geistware)
       Post #: 10
RE: BALANCING SPINNER - 11/16/2004 3:35:30 AM
fredycompean
Status: offline
Na!! thank you all, but I had already gotten a new one. this is an old post of when I crashed the edge.
CJ, it was nice to meet you too, and we'll be seing each other in the SC Region IMAC contests. Hope to make most of them.
fredy
(in reply to Blow n Go)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
