John Z Williams Jr
Joined: 9/17/2003 From: Boulder, CO, USA Status: offline
I will have to disagree with you Danny, I have been trying to make props for about 1 year now, I have put in a lot of time and money and have made only a couple that would go as good as the black prop. The means to the end would be that in Muncie or Florida, you would even the playing field, as has been done on the west coast, the black props work good there, but in high humidity and heat the black ones will not get into the power band.. 22,300rpm is a little low... I thought the whole reason to let in black props was to make the field more level, not make it a who can make the best prop contest, but who can fly the best... I know these go hand in hand, but I also know I do not have the skill to make a good wood prop, although I am trying and will continue trying to achieve this goal, I feel if a couple of lower pitch cf props where allowed it would enable people like myself to go fast or faster in hot humid conditions where the black prop is sometimes too much load.... This would even out the playing field between guys that know how to make a great prop and guys that do not, then its a pilots race, not a prop race... I have put in many hours in the last 3 months testing all different types of props and would rather spend my time going around the poles than carving them, but I was willing to try and maybe some day I will get it, but in the mean time, a larger selection of cf props would give the people that do not know how to make wood a better chance at staying up with the guys that do. I also know if I did know how to make a good wood prop and had a lot of time and money into it I would not be so ready to allow the new cf props into the ballgame, I guess it depends on which side of the fence you reside.... JW
