RE: DeHavilland Mosquito
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: DeHavilland Mosquito
Page: <<   < prev  15 16 [17] 18 19 20 21 22 23 24   next >   >>
Login
RE: DeHavilland Mosquito - 5/12/2006 3:56 PM
mpriestley
Score: 100
Last Login: 3/15/2010
Status: offline
big thanks for the pics and the info, very reasonable on the price and from the looks of it, the spinner back plate looks to be 1/4 inch thick, that might be what I need to fit my motors with out any mods...
Thank you!!!
I am ordering some today.
Hide Signatures
(in reply to Jimmy Bananas)
       Post #: 401
RE: DeHavilland Mosquito - 5/12/2006 7:39 PM
wayneporter1
Score: 100
Last Login: 9/28/2006
Status: offline
[image][/image]
Hide Signatures
(in reply to codimasta)
       Post #: 402
RE: DeHavilland Mosquito - 5/13/2006 9:22 AM
Jimmy Bananas
Score: 100
Last Login: 3/22/2010
Status: offline
Mpriestley:
Here is the correct info on the spinners:
# 5507360 ( 3-1/2 "-2 blade black spinner)
Good Luck
Hide Signatures
(in reply to mpriestley)
       Post #: 403
RE: DeHavilland Mosquito - 5/20/2006 4:40 PM
Billsky
Score: 100
Status: offline
quote:
ORIGINAL: Hot Rod Todd
You will likely need nose weight, so you might as well use plenty of engine. I use twin .46AX two strokes. The December 2004 issue of Fly RC magazine has a test where they fitted twin YS .63 four strokes. Even with the 1400mah ni-cad all the way in the front of the nose, they still added a few ounces of nose weight. I would say go with the .56's, nothing less. Two Saito .82's would be really sweet! With retracts the plane ends up fairly heavy. The extra power will help you.
How did you get the twin aX's to fit in the cowls? I had to move the engines forward because the needle valve hits the mount which makes the spinner not flush on the cowl?
Hide Signatures
(in reply to Hot Rod Todd)
       Post #: 404
RE: DeHavilland Mosquito - 5/22/2006 1:42 PM
Hot Rod Todd
Score: 100
Status: offline
I unbolted the needle valves from the bracket and mounted them on the firewall. .46AX needles are on an adjustable bracket, and can be removed. It was a tight squeeze, but I got it done.
Hide Signatures
(in reply to Billsky)
       Post #: 405
RE: DeHavilland Mosquito - 5/22/2006 1:54 PM
Billsky
Score: 100
Status: offline
Thanks, I never noticed that. I looked at everything but that. I was even going to extent the cowls.
Thanks again.
Hide Signatures
       Post #: 406
RE: DeHavilland Mosquito - 5/22/2006 2:31 PM
lozza1965
Score: 105
Status: online
Well got a few more flights under its belt so decided to finnish her off, painted up the Graunper 11/7's, peeled off the radiator stickers and made some more scale type ones filled and painted, and added some flight crew
lozza
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
http://www.flickr.com/photos/laurie-hughes/
Hide Signatures
       Post #: 407
RE: DeHavilland Mosquito - 5/22/2006 2:39 PM
BlueRider
Score: 100
Last Login: 10/3/2006
Status: offline
Hi All,
I am a new member of this group and a fan of the Jamara Mosquito. The mine fly very well with two electric engines AXI 2820/12,
BUT BE CAREFULL, There is a big error about the CG in the original doc.
Look at below the good place of the CG for a good and a safe flight...
I hope this will help you.
You will find all the photos and a video of my electric powered Mosquito at :
The Electric Powered Mosquito
Have fun a good flights,
BlueRider
Regards,
BlueRider
Hide Signatures
(in reply to spitmad)
       Post #: 408
RE: DeHavilland Mosquito - 5/22/2006 3:55 PM
lozza1965
Score: 105
Status: online
Bluerider welcome aboard fella
reference the Cof G if you read back through this thread your see its something were all aware of but thanks anyway
lozza
Hide Signatures
(in reply to BlueRider)
       Post #: 409
RE: DeHavilland Mosquito - 6/13/2006 9:10 AM
UK Warbird Guy
Score: 100
Last Login: 3/16/2010
Status: offline
****SPINNERS*****
Hi all, have not been around much, been busy flying for a change. Just to let you all know Dave Brown has put some spinners on Ebay. They are made to exactly the profile that the Mossie used as the drawing used was taken off the profile of the real thing. (See page 15)
They are the best you will get and are absolutly spot on. See picture below. Dave said he intends to make some more but is very busy at the moment.
Have fun
"..you know what to do with the straglers seargent..."
Quote by Christopher Plumber from the film Battle of Britain ..
Hide Signatures
(in reply to lozza1965)
       Post #: 410
RE: DeHavilland Mosquito - 6/13/2006 6:28 PM
Jimmy Bananas
Score: 100
Status: offline
UK Warbird Guy:
Where at on E-Bay does Dave have those spinners????
Hide Signatures
(in reply to UK Warbird Guy)
       Post #: 411
RE: DeHavilland Mosquito - 6/13/2006 10:30 PM
UK Warbird Guy
Score: 100
Status: offline
No Idea he just said could I post on here thart he has them on ebay.
What have you searched under? Maybe he hasn't put them up yet. I spoke to him last night.
I'll have a look myself and let you know if I find them.
Hide Signatures
       Post #: 412
RE: DeHavilland Mosquito - 6/14/2006 1:49 AM
Slider758
Score: 100
Last Login: 1/21/2008
Status: offline
Hi, quick question for lozza - what engines have you got in the mossie, and what's its total weight and wing span?
Thanks.
< Message edited by Slider758 -- 6/14/2006 1:50 AM >
Hide Signatures
       Post #: 413
RE: DeHavilland Mosquito - 6/24/2006 4:07 PM
Hornant
Score: 100
Last Login: 2/10/2008
Status: offline
Here is a video of my electric conversion.
http://www.rcgroups.com/forums/show...437#post5660175
There is also a thead on the build
http://www.rcgroups.com/forums/showthread.php?t=523476
Hide Signatures
(in reply to Slider758)
       Post #: 414
RE: DeHavilland Mosquito - 7/2/2006 5:10 AM
Hornant
Score: 100
Status: offline
Sorry wrong link
This is the video link
http://www.rcgroups.com/forums/showthread.php?t=534437#post5660175
have a look at this
Hide Signatures
(in reply to Hornant)
       Post #: 415
RE: DeHavilland Mosquito - 7/5/2006 1:36 PM
bradshawce
Score: 100
Last Login: 10/20/2008
Status: offline
Well, I've done it. I've finally bought one.
Need to decide on engines though.
I've read the posts and most people have their favourites but which would you guys consider the best to put in it? (Contentious I know)
Saito FA50/56 - ok?
RCV 58CV - slim design - less cowl bashing
OS FS52S - good reputation
Obviously reliability is a big factor here (even with a TwinSync) but weight will be an issue (heavier the better I guess) as will the sound
Cheers
Chris
Hide Signatures
       Post #: 416
RE: DeHavilland Mosquito - 7/6/2006 12:10 PM
kaastrup
Score: 100
Last Login: 12/27/2009
Status: offline
If you want the sound, you should go with 4-strokes. I think nearly any motor could be as reliable as you want, just make sure it has enough brake-in time (the older the engine the better).
I bought 2 new Magnum 52 FS, they are identical with the OS version. Maybe not as good finish. I had them both on my engine-break-in-mount for about 3x 250 cc tanks, and I think the run nice, and nearly same rpm. These Magnum are just cheaper them OS.
But the Saitos would be very lovely in the plane. I had one FA-72 and earlier I thought about buying one more. But I got some response that they would be too big for the cowls.
For the weight, I plan on douple receiver (2x 5-cells) batteries on a MPX RX-9 receiver. Glow-driver for the engines. And maybe a special ACT voltage regulator. All just to make some use of the extra weight up-front you need.
< Message edited by kaastrup -- 7/6/2006 12:13 PM >
Christian Kaastrup
OY-5704
Hide Signatures
(in reply to bradshawce)
       Post #: 417
RE: DeHavilland Mosquito - 7/11/2006 4:58 AM
cmingram83
Score: 100
Last Login: 3/21/2009
Status: offline
I just started assembling a Mossie myself. Thanks for all the tips fellas. I'm thinking of using a pair of O.S. FSR .40s. Theoretically, it will go about like a rocket. I probably have some reinforcing to do.
Hide Signatures
       Post #: 418
RE: DeHavilland Mosquito - 7/11/2006 1:22 PM
Hot Rod Todd
Score: 100
Status: offline
OS .40's will be OK, but not a rocket by any means. It can easily handle them without re-enforcing. I'd opt for the .46AX's, you can then get a bit more thrust which helps a lot on take off. Don't go by the recommended power, whoever came up with that was a bit off.
Hide Signatures
(in reply to cmingram83)
       Post #: 419
RE: DeHavilland Mosquito - 7/12/2006 12:59 AM
cmingram83
Score: 100
Status: offline
Well, those old FSR 40s are a bit more powerful than the new ones, or should I say a LOT more powerful. Pretty comparable to a Tigre 51, just without the weight.
Hide Signatures
       Post #: 420
RE: DeHavilland Mosquito - 7/12/2006 1:11 AM
cmingram83
Score: 100
Status: offline
Also, I was wondering if anyone had any input concerning mechanical retracts to use. The ones they make for the mossie don't look very durable.
Hide Signatures
       Post #: 421
RE: DeHavilland Mosquito - 7/12/2006 10:25 PM
kaastrup
Score: 100
Status: offline
I am using those from 3DXHobbies.com
http://www.3dxhobbies.com/store/catalog/product_63_Mechanical_Retract_Main_Gears_2PC_SET_cat_310.html
I got them a long time ago, and they seem very sturdy. And I use Robart struts 65xL+R (I think it is).
Christian Kaastrup
OY-5704
Hide Signatures
       Post #: 422
RE: DeHavilland Mosquito - 7/13/2006 3:12 AM
cmingram83
Score: 100
Status: offline
WOW those look very tough, and expensive. Just out of curiosity, what's the weight on those?
Hide Signatures
(in reply to kaastrup)
       Post #: 423
RE: DeHavilland Mosquito - 7/13/2006 9:39 AM
kaastrup
Score: 100
Status: offline
If you read whats on the page you can see the weight and price !!!!
Christian Kaastrup
OY-5704
Hide Signatures
       Post #: 424
RE: DeHavilland Mosquito - 7/14/2006 12:27 AM
cmingram83
Score: 100
Status: offline
Well I feel dumb now. That's not bad on the weight. I'm thinking of using robart mechanicals, though. They should work fine and they're about half the price. I just wish someone made some scale retracts for this particular model.
Hide Signatures
       Post #: 425
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.281RCU1
