RE: DeHavilland Mosquito
Tower Hobbies
Logged in as Guest
Users viewing this topic: oldtimer143
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  11/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: DeHavilland Mosquito
Page: <<   < prev  18 19 [20] 21 22 23 24 25 26 27   next >   >>
Login
RE: DeHavilland Mosquito - 4/1/2007 6:55:51 AM
Billsky
Status: offline
I fly on a grass field, and I am sick of the mechanical retracts breaking, what are the best mechanical retracts for the mossie? I have seen 3dfx retracts mentioned. I am also considering just installing the supplied fixed gear that came with the kit. any suggestions are welcome.
(in reply to DragonLines)
       Post #: 476
RE: DeHavilland Mosquito - 4/1/2007 7:18:37 AM
kaastrup
Status: offline
I use the "old" version of these
http://www.3dxhobbies.com/Mechanical_Retract_Main_Gears_2_PC_SET_p/buz4060.htm
The new one should soon be ready.
I have also bought a pair of these
http://www.ripmax.com/item.asp?itemid=F-ASM-CSS01&Category=010
_____________________________
Christian Kaastrup
OY-5704
(in reply to Billsky)
       Post #: 477
RE: DeHavilland Mosquito - 4/1/2007 1:55:17 PM
Billsky
Status: offline
Thanks for the information, the struts look nice http://www.ripmax.com/item.asp?itemid=F-ASM-CSS01&Category=010 . Are they for fixed or mechanical retracts? I could not get a closer look than the picture allowed. I am not to experienced with landing gear issues.
Thanks again
(in reply to kaastrup)
       Post #: 478
RE: DeHavilland Mosquito - 4/1/2007 7:26:05 PM
kaastrup
Status: offline
They are for mechanical or air retracts, and actually made for these
http://www.ripmax.com/item.asp?itemid=F-ASM-ARS01&Category=010
I don't think they are stronger then the ones from 3dxhobbies, I only bought them to get more scale like ones..
Christian Kaastrup
OY-5704
       Post #: 479
RE: DeHavilland Mosquito - 4/4/2007 7:51:29 AM
kmtranmd
Status: offline
Just maidened my CMP Mosquito over the weekend. Great flying machine. Set up: OS 46FX(2), Robart spring down 510's air retracts, CG 116mm from LE at fuselage (had to put almost 1.5 lbs of weight in the nose to balance it), Futaba 9CAP (twin engine trim premixes per instructions at Futaba-rc.com instructions). Only thing I did not like was the stock tanks allowed for only about 5-6 minutes of flight time. Expect that will improve when the engines break in fully. The Robart 510's are pretty sturdy units, easily handle 12-15 lbs warbirds. http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJZD2&P=0
GI Doc
       Post #: 480
RE: DeHavilland Mosquito - 4/4/2007 8:33:21 AM
kaastrup
Status: offline
Just to make sure....the ASM struts for the DH88 Comet are way to big for the Mossi...so don't buy
Christian Kaastrup
OY-5704
(in reply to kmtranmd)
       Post #: 481
RE: DeHavilland Mosquito - 4/7/2007 9:23:45 PM
Hotrcair
Status: offline
In your 11/04 post you discussed how well the plane flew. Are you still flying the Mossie with 32's for power?? How about what retracts did you use?? Lastly is your Mossie a Nitro Planes kit??
(in reply to codimasta)
       Post #: 482
RE: DeHavilland Mosquito - 4/8/2007 12:38:57 PM
Billsky
Status: offline
Go with 46AX's, I did and I am happy with the choice, Plenty of power. The mossie hauls at half throttle. I fly off a grass field and need the extra power for lift off. If you have a pavement field then 32's would work fine. I also reccomend that you get robart retractable gear as mentioned in some other threads. I had normal retracts in and on almost every flight on landing I side would buckle and break, I eventually went to the FIXED landing gear that came with the kit due to the grass and uneven ground I was landing on. I also would put in larger fuel tanks than 6oz if you go with the 46AX's.
       Post #: 483
RE: DeHavilland Mosquito - 5/9/2007 10:42:17 PM
gloria
Status: offline
Hi everybody
Any UK persons who is flying the the twin IC Flair Mosquito. I have some problems and would like to discuss them!
Regards Bo
       Post #: 484
RE: DeHavilland Mosquito - 5/9/2007 10:55:30 PM
Tony Packe
Status: offline
Hi Bo
I've not got round to flying mine yet as I've just got hold of a pair of ASP FS 61's which I plan to fit very soon.
Most of your problems will probably listed in the past posts, but what are they anyway?
Regards Tony
(in reply to gloria)
       Post #: 485
RE: DeHavilland Mosquito - 5/26/2007 10:57:24 PM
Viper427
Status: offline
Hi all
anyone know where i can purchase the CMP Mossie in Orlando for the best price?
I am visiting in a week and hope to pick up a few bits.....
(in reply to CharlieDelta)
       Post #: 486
RE: DeHavilland Mosquito - 5/29/2007 4:29:22 PM
jran
Status: offline
Hi All,
Ever thought of going electric? This is my 93" Mossie enlarged form the Brian Taylor plan (81" Over 40 flights so far. Built four years ago on cheap DC brushed motors, 16lb AUW.
John
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Viper427)
       Post #: 487
RE: DeHavilland Mosquito - 6/2/2007 5:34:18 PM
Scott Douglas
Status: offline
Here's mine. Excuse the low quality photos, I was using my phone. Cant say I really enjoyed putting it together. The paint finish is crap.....look at it and it falls off. I do hope it flies better than I think it will.
Regards
Scott
Click for fullsize
Click for fullsize
Click for fullsize
http://www.dadmac.org.uk
(in reply to jran)
       Post #: 488
RE: DeHavilland Mosquito - 6/2/2007 8:04:38 PM
