RE: DeHavilland Mosquito
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  2/18/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: DeHavilland Mosquito
Page: <<   < prev  21 22 [23] 24 25 26 27 28 29 30   next >   >>
Login
RE: DeHavilland Mosquito - 9/23/2007 2:24 AM
Alex 51
Score: 100
Last Login: 3/17/2010
Status: offline
I have completed my moquito. CG, if i am reading you correct 115mm from the leading edge next to the fuselage ??
I installed a twin sync unit into the mosquito. It brings the running engine back to idle if one of the engines die. Works great on the ground and it syncs the engines automaticaly three clicks above idle. I still have the original fuel tanks in the mosquito. I have evo 46's i can get about 6.5 to 7 min out of the tanks at 1/2 throttle, not much time is it anyone out there using the tanks? I used Robart 510 retracts and 1.5 volt bats with a switch for each engine.
Hide Signatures
(in reply to CAP232AC)
       Post #: 551
RE: DeHavilland Mosquito - 9/23/2007 4:07 AM
j3_av8r
Score: 100
Last Login: 2/27/2010
Status: offline
Hi CAP232,
I did use the JR Hi Torque servos but I think they are overkill (I had them sitting around). The Mossie's gear is shorter than the P-47's and if you use light weight wheels, I would think you could probably do fine with some lighter duty ones. I even removed one of the two springs on the retract units as it didn't seem necessary. With the gear retracting aft, the airflow helps retract them anyway.
Yes, they have 85 deg rotation which is why my gear mounting blocks are deeper into the nacelle and angled forward slightly.
The gear has a bit of play but does not wobble at all (especially compared to what wire gear would do). That is one of the reasons I went to the oleos. It taxies, takes off and lands smoothly with the oleos. And they look so much better!
Another pointer on the rudder mixing...I set it up so it would only add throttle to the required engine and not have any affect on the inboard engine. I didn't want to be able to inadvertently shut the throttle too far and kill the engine if the throttle was near idle.
The Welkin is very cool. The high aspect ratio wing makes for a great performer on modest power. I was actually starting to draw one up hoping to have a one-of-a-kind machine when Marc showed up with this one. Oh well. It did when Best of Show - Military at the NEAT Fair last year.
Hide Signatures
       Post #: 552
RE: DeHavilland Mosquito - 9/23/2007 4:10 AM
j3_av8r
Score: 100
Status: offline
Alex 51,
Yes, the 115 mm is at the fuselage.
The twin sync is a great idea and would have probably saved me from my 1st flight prang. Which unit are you using?
Andy
Hide Signatures
(in reply to Alex 51)
       Post #: 553
RE: DeHavilland Mosquito - 9/23/2007 4:52 PM
Alex 51
Score: 100
Status: offline
Thanks for the info i checked the cg last night and i will need a .65 lb's more that brings the plane to 14.25 lbs. I will need to use flaps on take off and landings big time. The twin sync is made by rc showcase(www.rcshowcase.com). This unit was setup for Futaba 9c tx but they can be programed for any of them i have a spectrum 2.4 and it works great. I had a programing problem when i first got it but it was a instructional error. showcase tec (Bill Wike ) was on top of the problem and helped me solve the problem by sending me a new set of instructions. You can go on line and print out a set of instructions. Also with this unit you can run glow starters.
Hide Signatures
(in reply to j3_av8r)
       Post #: 554
RE: DeHavilland Mosquito - 9/24/2007 1:51 PM
Hot Rod Todd
Score: 100
Last Login: 3/19/2010
Status: offline
I had no problems setting up the Mossy with my 9C. Just set up a mix on the second throttle channel to match the first. You turn on trim function and there you have it. Make sure you turn off the aux control on the channel you use, or you may find yourself wondering why it changes every time you bump a rotary knob. The rudder mix is also no problem, but you have to decide if you want it to drop a bit of power on one, or bring it up on the other. I have not needed to do this though, since the plane seems to take off well, as long as I have some toe-in set on the gear.
I'm not sure of my exact CG now, but I know it is back of 115mm. My previous model felt heavy, and when landing the elevator started to loose effectiveness. Now that I am back to 117-118 I love the way the plane flies and lands.
I would NOT take off with flaps. Unless you have a shorter runway than normal the extra drag could cause you some problems. I do like them on landing though, since it would be tough to slow the thing down without them.
I put some robart struts on mine, and like it much better than the wire retracts I had. They help to cushion the landing and keep the plane from bouncing. Here's a photo of mine where you can see the type I used. 90 degree retracts are what you want, if you are buying a new set anyway.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 555
RE: DeHavilland Mosquito - 9/24/2007 4:58 PM
CAP232AC
Score: 100
Last Login: 12/8/2009
Status: offline
What second throttle channel? I can't seem to find it. I used heli mode on my OV-10 (throttle and pitch curves) to sinc up the throttle curves, but would be unable to use rudder mixing that way. I'll go play with that radio again and see what I can do..
Hide Signatures
(in reply to Hot Rod Todd)
       Post #: 556
RE: DeHavilland Mosquito - 9/24/2007 5:15 PM
Hot Rod Todd
Score: 100
Status: offline
You can use any open channel. I don't have the book in front of me, but you just pick an open mix and use the throttle as the master, and the other channel as the slave. For example you could use channel 8, make channel 3 the master. Make sure you turn on trim, and turn off the default switch that enables the channel (in my case it was VRA I believe). The two channels will then match each other. End points can be set seprately on both channels, but the trim and throttle cut should work on both. I don't worry about matching up throttle curves since my engines run close enough. That is one feature I wish I had (like my buddies JR9303). Keep the linkage angles the same and you should have a very close match anyway. I think having the engines perfectly matched at every RPM is a bit overated, as long as they both keep running well.
Hide Signatures
       Post #: 557
RE: DeHavilland Mosquito - 9/24/2007 5:45 PM
CAP232AC
Score: 100
Status: offline
Well, I was hoping to edit my last post, but...Anyway, I still can't figure out how to "slave" a channel to throttle. However I figure I can use "throttle needle" to set the curve and just mix in "rudder to throttle" to get my steering mix on channel 3. Then I can "NULL" the channel 8 switch on AUX channel menu. As far as perfect sinc, I agree, they don't need to be absolutly perfect. I don't like the "WA -WA -Wa -Wa" sound they make when not synced perfect though, especialy on my electrics.
Aaron
Hide Signatures
       Post #: 558
RE: DeHavilland Mosquito - 9/25/2007 3:57 AM
Alex 51
Score: 100
Status: offline
Todd
Nice job on your mosquito I like your struts. I only hope we get some more good days to get mine up. Thanks to all for the great advice i never fly a new plane until I check the forums. I have the cmp 190 that I've been flying this summer. I put a 2300 Super tiger and a perry carb on it. I have been bring it to the fun flys and battle it out with a H9 150 P 47. It make for a good show for everyone.
Hide Signatures
       Post #: 559
RE: DeHavilland Mosquito - 10/7/2007 8:12 PM
Robinaire
Score: 100
Last Login: 3/20/2010
Status: offline
Hi Charlie. Holiday????? You had one in '89!! (It's my natural mean streak!) I just found this thread, and have a question for all. About 2 years ago, I was contacted by a Western Canadiam chap who was building a humongeous Mossie, I believe it was 144". I was designing a gear for it. He had built one himself, and hoped to put out a kit for the plane, with me building gear. He sent me pics of a Mossie in a museum up there, and much other info. A year or so ago, I had a massive blowup on my "confuser" and lost historical emails and a complete address book. I had been away from the project for a few months due to some production problems, and after I had the crash, I could not remember anything but his first name, which was Jerry, and that his last name was Eastern European! Maybe he reads this, or perhaps someone out there might recognize my brief description. I'm at a loss to know how to find him. I'm getting ready to build another Mossie gear, and wanted to look up some of my earlier general data, especially the full-scale stuff. Anybody out there with "detecting" talent??? Lee Robinson W. Palm Beach, FL
< Message edited by Robinaire -- 10/7/2007 8:15 PM >
Hide Signatures
(in reply to CharlieDelta)
       Post #: 560
RE: DeHavilland Mosquito - 10/11/2007 9:17 PM
Alex 51
Score: 100
Status: offline
I seen that mossi one time on a forum I wiil go back to some of the stuff I have saved and get back to you. Do you make the gear for the CMP mossi 71"
Hide Signatures
(in reply to Robinaire)
       Post #: 561
RE: DeHavilland Mosquito - 11/25/2007 12:50 AM
kahloq
Score: 105
Last Login: 3/21/2010
Status: offline
Looking at getting one of these Mossies as I have a spare saito 56 lying around. Two would power this plane decent as many have stated OS 52's work well.
Not sure if I'll get to this plane anytime soon though as a KMP B-25 needs to be built as well as 56" ws F-86 ducted fan jet.
Though, this plane doesnt look too hard to get put together, when i get one, it might get pushed to the front of the line.
Hide Signatures
       Post #: 562
RE: DeHavilland Mosquito - 1/1/2008 3:59 AM
j3_av8r
Score: 100
Status: offline
I recieved a PM on how to take advantage of 9303's programming for the Mossie. Here is what I did...
First thing to do is when turning on the TX; hold the ENT button to get into the System Menu. I programmed my Mossie using the Twin E function. This automatically dedicates another channel to throttle without any additional mixing. To activate it, you first need to go to DeviceSEL and inhibit the channel you will use for the second throttle (AUX2 in my case). This is not spelled out in the manual and it took me a while to figure out. Now you go into Wing TYPE and activate the TWIN E function. Go to MATE and select which channel you want to mix (AUX2). Set the trim function to ACT if you want the trim to work to work both throttles. I did this so I can shut them down together. That is all you need for the system menu that is Mossie specific.
Now you can go into FUNCTION LIST menu and set up the throttles. You will now notice that when you go into the menus instead of THR and AUX2, you have RTH and LTH. Pretty slick! Set-up reversing, travel adjustment, etc. as necessary to line up your throttles. Once you get the engines running you can go into THRO CURV. Note that there are now 2 curves; one for LTH and one for RTH. If you want, adjust the curve for LTH to get a more linear throttle response. Once it is set, leave it alone. Now apply the same percentages to the RTH curve. Now start up the right engine and play with the points in the RTH curve to synchronize the right engine to the left. I found that getting the engines to be in reasonably synch across the entire RPM range is important for helping keep the plane going reasonably straight on takeoff. With no fin and rudder in the prop blast, the tail can swing harder than the tailwheel can fight.
When setting up the flaps, you will find that there is considerable elevator trim change as the plane really wants to balloon up. I highly recommend using lots of flap for landing this bird. It gives washout, lets you keep the throttles up on approach and kills the float in ground effect. Go into the FLAP SYS menu. I have the ELEV NORM set at 0%, Mid at 7% and Land at 14%. FLAP at the default NORM U100%, mid 0% and D100%. And I set the Delay to 1.0s.
In SRV.Speed Menu, I set the FLAP to 2.14s to get a slow flap action. This speed, with the trim set-up in the previous paragraph gives a smooth transition with no apparent pitch changes.
The last bit of programming I added was to mix the rudder to the throttles. This helps immensely if one engine comes on faster than the other, taxiing in cross winds and keeping it straight on takeoff until the rudder is effective. As I only use this function on takeoff and taxiing, I set-up the radio to use the MIX switch on the top RHS of the TX. In the menu PROG.Mix4, set the RUDD to LTHR Pos1 to +22% for the top value and 0% for the value below and activate the MIX switch to POS1. Similarly for PROG.Mix5 set the Pos1 to 0% and the value below to -22%. And activate the Mix switch to POS1. By keeping the one end of the mix at 0%, I only add throttle to the “outside” (i.e. it is on the outside of the desired turn arc) engine when I input rudder. I did this to keep from inadvertently killing the inside engine when taxiing at low throttle. Depending on your throttle servo installation, some of these values might need to be reversed.
That is about it. Hopefully that is clear enough. If you have any questions, let me know.
Also here are a couple of pics that a friend took with his DSLR. Gotta love it!
Happing Landing in 2008 everyone!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 563
RE: DeHavilland Mosquito - 1/24/2008 7:31 PM
Hotrcair
Score: 100
Last Login: 1/21/2010
Status: offline
I need help now. I,m at the point of installing the Robart Retracts. Need pictures of how and where the air tank goes and how it gets there.
Many thanks
Hide Signatures
       Post #: 564
RE: DeHavilland Mosquito - 1/24/2008 9:57 PM
Hot Rod Todd
Score: 100
Status: offline
I don't have any internal pictures handy, but I mounted my air valve and air tank in the wing. I can cycle the gear without the fuse attached. Look closely in the photo and you can see the air fill valve under the remote glow hook up on the left engine nacelle.
Click for fullsize
Hide Signatures
(in reply to Hotrcair)
       Post #: 565
RE: DeHavilland Mosquito - 2/21/2008 1:56 AM
havnfun
Score: 100
Last Login: 10/5/2009
Status: offline
Hey! After lusting after a "Mossie" for some time, I finally got one lae last fall from GSP. I've picked up that several of you seem to share my fascination w/ this model craft (although I'm also very interested in the DH Comet). I spent some time going through most of the 23 pages of posts in this thread, and was amazed at the amount of info/data that y'all share. This craft (the 73" WS from CMP) is the one that I am talking about; it appeared that there were references to some other offerings from other mfrg's (Yellow, etc.) Am I correct? Anyway, we're about to start on this project; wish me success. I'll refer to this thread a lot as I progress; anybody got some suggestions as to what I should be initially looking at/for, as I get the box out and get started. I had planned to use OS .32's, but it seemed that most of you were going "more". I'm also interested in the 3-pc wing concept. I'm asking. Thanks, folks.
PS I have found a great looking retract for this craft; look at Century Jet Products in Louisville, Ky.. One of our local flyers took his Mossie to them and they engineered/built a specific gear for this craft, w/ oleo's and the perfect springs for the weight of this model. Other local flyers swear by their quality and dependability. I drove to their shop, and bought the set for my Mossie; it's a complete system w/ tank, valve, tubing, fittings, and a great instruction sheet. BTW, he lost his Mossie to some terrible confusion surronding the CG; he said he used the CG from the factory, and lost his on the maiden flight, I think
< Message edited by havnfun -- 2/21/2008 2:16 AM >
Hide Signatures
       Post #: 566
RE: DeHavilland Mosquito - 2/21/2008 1:15 PM
Hot Rod Todd
Score: 100
Status: offline
Someone asked about the air tank location. Here's how I did mine. I have the actuation valve and fill valve in the wing with the tank. This makes for no air lines to plug in when putting the wing on. You can see the tank down inside the wing. I just made some foam surrounds and stuffed it in there. The receiver is also in the wing, leaving only two wires to plug in when I place the fuse on the wing. The battery and switch is in the fuse nose, but all you have to do is Y-cord it to the Elevator or Rudder. Here's a photo of the wing install.
Click for fullsize
Hide Signatures
(in reply to havnfun)
       Post #: 567
RE: DeHavilland Mosquito - 2/22/2008 7:28 AM
havnfun
Score: 100
Status: offline
Kirk- If you're still in the market for double strut w/ oleo's retracts for your Mossie, try Century Jet Products Louisville, Ky. Their offering was engineered/built for the Mossie's weight and Nacelle space. One of our local flyers actually took his model to Century, so they could do their work. I got my Mossie last falll, and went down to Century to get a set (complete pkg) I'm just now starting on mine; target date is May 15. Good luck. Jerry Sharp (havenfun)
Hide Signatures
(in reply to Montague)
       Post #: 568
RE: DeHavilland Mosquito - 2/26/2008 1:29 AM
gijoe7658
Score: 100
Status: offline
Lots of good post to get me started on my kit. Glad i can learn fron you guys about the balance point. While looking for even more information about the CMP Mosquito I found a video of this plane . Painful to watch.
http://www.metacafe.com/watch/919464/twin_engine_radio_control_airplane_crash/
Hide Signatures
       Post #: 569
RE: DeHavilland Mosquito - 2/28/2008 6:41 AM
Servo481
Score: 100
Status: offline
My first post so hope this works out. Want to thank everyone for there posts and warnings on the cg setting. That information saved my Mosquito on it maiden flight.
My Mosquito is powered by 2 YS-63S Engines. I built duel strut retracts and added gear doors to improve the looks. Also I installed 10 oz fuel tanks to improve fight time. It weights 15 lbs with the 1 lb noise weight, but after I get confident with the plane some of the noise weight can be removed. I tried to add some pictures hope they come out.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to gijoe7658)
       Post #: 570
RE: DeHavilland Mosquito - 2/28/2008 7:26 AM
pdemon
Score: 100
Last Login: 2/13/2009
Status: offline
Nice shots! It seems you've put in the right dihedral, a thing not so many Mosquito ownerws have done. How it behave at that weight, isn't a little on the heavy side?
ciao
Pierluigi
Hide Signatures
(in reply to Servo481)
       Post #: 571
RE: DeHavilland Mosquito - 2/28/2008 5:51 PM
Servo481
Score: 100
Status: offline
I fly at 5000 feet, so we need to have good power. YS-63S engines with 11-8 propellers produce about 7 lbs of static trust, so it does not have unlimited vertical but will pull itself out of trouble. At 15 lbs it flies great, but it's not a floater. When landing you need to use a little power and keep some speed like most warbirds.
Hide Signatures
(in reply to pdemon)
       Post #: 572
RE: DeHavilland Mosquito - 3/7/2008 2:27 PM
flysfisher
Score: 100
Last Login: 10/19/2009
Status: offline
i have recently purchased a cm pro mosquito. i fly at almost 5500'( denver area) altiude so i am going to use 2 os 55 ax engines. i have heard that the cg mentioned in the instructions is a little off. does anyone know about this? also where can i get the retracts ans spinners for this model? from the looks in the instructions the retracts should have a sidewise U bend like the fixed gear provided and not just a stright stut like on the hobbieco mechanical retracts. any little bit of help here will be appreciated. thanks guys.
Hide Signatures
       Post #: 573
RE: DeHavilland Mosquito - 3/7/2008 3:56 PM
Hot Rod Todd
Score: 100
Status: offline
All of your questions have been answered. Only 570 posts to read.
Hide Signatures
(in reply to flysfisher)
       Post #: 574
RE: DeHavilland Mosquito - 3/8/2008 5:57 PM
havnfun
Score: 100
Status: offline
Hey flyfisher-I'm in the same boat as you. I finally got mine last fall, and am just about to tackle it. Hot Rod Todd said it best; spend time reading all 570+ posts in this thread. There is a host of tips, photos, successes and failures to be had going back about four years. I have spent the time to review most of the posts, and intend to go through them again before I start; can't believe the amount of info available. We should thank all the contributors for their efforts; I, for one, don't mind looking at a build with lots of pairs of eyes. BTW,if scale appearances matter to you, read my post 568 about retracts, and struts. I was impressed w/ Century Jet; hope this helps. The double strut isn't that diffucult to install; if nothing else, it makes slight toe-in easier to achieve, and keep. I haven't decided yet what my engines will be; am leaning toward 4 stroke. Good luck w/ your build.
Hide Signatures
       Post #: 575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.039RCU1
