Montague
On mine, one tube was a nice snug fit, while the other had a fair bit of play. I found that by swapping the tubes around, flipping them, and rotating them, I was able to get a reasonable fit on both sides. I did have to sand the outer panel root and espeically the wing center section to make everything flat and join up nicely with the correct dihedral, with the same amount on both sides. It took a bit of doing, but with some effort, you can get everything to line up. Just remember, it's a cheap arf. It's designed and engineered and assembled like a cheap arf, and to get a really nice result, you're going to need to put a lot of effort into it. It's a nice flyer for the money, but you do get what you paid for.
_____________________________
Kirk Montague Adams RCCA 560
