inverted engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> inverted engine
Page: [1]
Login
inverted engine - 7/21/2004 11:48 AM
blue62
Score: 100
Last Login: 12/30/2012
Status: offline
i am installing a 4 stroke engine in my biplane and i always see them inverted. is this preferable? i have plenty of room to mount it anyway i like but it will look good sticking out the bottom. better hidden that way.
i guess my question is do they run better this way? easier to start?
_____________________________
I don't have it, do you have it? crash! nope musta been shot down!
Hide Signatures
       Post #: 1
RE: inverted engine - 7/21/2004 12:22 PM
William Robison
Score: 599
Last Login: 1/30/2007
Status: offline
John:
The engines run just as well inverted as upright. But they can be more critical in adjustment.
Just make sure the tank is not too high, might be a bother to start until you get used to it, but once you get there all will be fine.
Bill.
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
Hide Signatures
(in reply to blue62)
       Post #: 2
RE: inverted engine - 7/21/2004 12:29 PM
wldcwbypilot
Score: 100
Last Login: 11/6/2012
Status: offline
The engine doesn't know its upside down. Even in most real aircraft with inline or v configurations, the engines are inverted. If you don't like iverted you can always mount it any way you like. Inverted means less obvious cutting of the cowl, just makes it look cleaner than a big hole in the top or the sides.
will
< Message edited by wldcwbypilot -- 7/21/2004 9:53:20 AM >
Hide Signatures
(in reply to William Robison)
       Post #: 3
RE: inverted engine - 7/21/2004 5:37 PM
smokingcrater
Score: 100
Last Login: 10/6/2008
Status: offline
to answer your question, no they will not run better, assuming your carb/fuel tank line up fine in both situations. invertered are more prone to flooding and as someone else mentioned sometimes a little more finicky to set up.
Hide Signatures
(in reply to wldcwbypilot)
       Post #: 4
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> inverted engine
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
