RE: FiberClassics P-51 now Comp-ARF P-51    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: FiberClassics P-51 now Comp-ARF P-51
Page: <<   < prev  68 69 [70] 71 72 73 74 75 76 77   next >   >>
Login
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/10/2011 6:26 AM
Canuck1
Score: 100
Last Login: 5/15/2013
Status: offline
Thanks for sharing Jeremy, those were quick flypasts.
Masked the roundels on the wings, leading edge yellow marking, as well as the chrome on the leading edge of the flap.
I hope to get up early tomorrow and get the bottom of the wings painted.
Craig
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Eat, Sleep, Fly
Hide Signatures
(in reply to Jeremy_D)
       Post #: 1726
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/11/2011 3:18 AM
Canuck1
Score: 100
Status: offline
Bottom of the wings are now painted. Gave it a little rub with "0000" steel wool just to bring out the effect. Should look pretty good when the whole airframe is done to bring out the details.
Will be doing the top grey colour soon.
Craig
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
(in reply to Canuck1)
       Post #: 1727
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/11/2011 4:26 PM
alanjets
Score: 100
Last Login: 3/29/2013
Status: offline
nice scale flying in the video
Hide Signatures
       Post #: 1728
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/12/2011 4:18 AM
Canuck1
Score: 100
Status: offline
Painted the Ocean grey on the top of the wings. It s still drying, and will check for good coverage before cleaning up for the night.
Will do the green in a few days.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
(in reply to alanjets)
       Post #: 1729
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/14/2011 6:38 AM
Canuck1
Score: 100
Status: offline
The dark green is now applied to the tops of the wings. Still need to paint the horizontal stabs, and some other small parts.
Removed all the masking from the roundels, top and bottom as well as the masking for the leading edge marking.
Will let is harden a few days before I wool it down with "0000" steel wool which will blend the paint
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1730
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/14/2011 7:01 AM
mustang41
Score: 100
Last Login: 4/14/2012
Status: offline
Very Nice works
Paint is the better moment and it's very original colour
Quick!! next step
Patrick
Hide Signatures
       Post #: 1731
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/15/2011 1:10 PM
oesterling
Score: 100
Status: offline
Hello Craig
Fantastic paint job, looks great. are you doing a clear cote in the end, looks like the real deal is clear coated..
Let soon see it all assembled...
Can't wait too se mine in flight metal..but there is a lot of work before I am at that stage..
Regards
Jan
Hide Signatures
(in reply to mustang41)
       Post #: 1732
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/17/2011 5:24 AM
Canuck1
Score: 100
Status: offline
Yes I will be clearcoating after all the painting, and rub on transfers are applied, as well as some weathering of dirt, and a bit of grim. So it will be a gloss finish just like the one I am modelling.
Painted the call letters on the tail, as well as the red fuel caps. One on each wing and the one on the fuselage portside. Once wooled down they should look pretty good.
Still need to do the small maple leaf on the fin, which I will tackle next.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
(in reply to oesterling)
       Post #: 1733
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/17/2011 11:26 PM
Canuck1
Score: 100
Status: offline
Have been progressing well with the small roundel for the fin.
Masked of the main circle, sprayed some white. Then masked off for the light blue circle, and sprayed it light blue.
Removed the mask, and the white is exposed.
Made the template for the Canadian Maple leaf............that was fun
When the blue has dried, I will put the flag template on, and pray it red. The leaf is pretty small so I will use light dusting coats.
I will post more as I complete the marking.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1734
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/18/2011 2:54 AM
Canuck1
Score: 100
Status: offline
Red Maple Leaf is now painted. Turned out pretty good. Still need to do a few things before its done.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1735
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/20/2011 4:18 AM
Canuck1
Score: 100
Status: offline
Worked on securing the horizontal stab.
Using some hysol, I glued in some wooden dowels into the alum tube and let it sit for 24 hours.
Drilled and tapped for a 6-32 screw. Inserted the screws, now I have a good secure method to hold the horizontal stab into location. Makes it easy to remove if necessary.
Next I can finish painting the stab both top and bottom
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1736
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/20/2011 6:45 AM
Canuck1
Score: 100
Status: offline
Pained the Starboard underside lights. Turned out pretty good.
Craig
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1737
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/22/2011 7:50 PM
Canuck1
Score: 100
Status: offline
Spent the last few days painting the horizontal stab.
After it has time to set up, I will wool it down so it blends nice, and the details will pop out.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1738
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/27/2011 2:22 AM
Canuck1
Score: 100
Status: offline
My Promark Graphics arrived in the mail today.
I ordered the 100" Nomenclature set. They look real good.
Now the fun part begins with the application of the graphics.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1739
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/28/2011 6:29 AM
Canuck1
Score: 100
Status: offline
Stencils are applied to the fuselage and the wings. I took a couple of pictures.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1740
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/30/2011 7:30 AM
Canuck1
Score: 100
Status: offline
I clear coated the bottom of the fuselage and wings tonight.
I am using KlassKote for my clear. Used it before on my P-47 with good results.
I willl let this set up for the required 24hrs before proceeding with the top.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1741
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/30/2011 8:05 AM
Canuck1
Score: 100
Status: offline
Still needs a bit more clearcoat for the bottom of the wings, so instead of doing it in the morning, figured I would stay up and give it another coat. Just mixed up another batch and after 40 minutes I can apply it. Prefer to have it bond with the previous coat before it sets. Hope to be in bed by 3am Love this hobby!!!
Craig.
Eat, Sleep, Fly
Hide Signatures
       Post #: 1742
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/30/2011 9:58 AM
peterduplessis
Score: 100
Last Login: 5/8/2013
Status: offline
I recently received the drop tank kit from C-arf ..... No instructions included!! Has anyone any information or ideas incl dimensions for the placement of the drop tank assy ??? Thanks in anticipation.
Peter
Peter du Plessis
Waco Brother #224
Hide Signatures
       Post #: 1743
RE: FiberClassics P-51 now Comp-ARF P-51 - 4/30/2011 8:15 PM
dvs1
Score: 100
Last Login: 1/17/2013
Status: offline
quote:
ORIGINAL: Canuck1
Craig.
looks awesome, you'll be in the air in no time. Can't wait to see some finished pictures after paint all assembled! I really dig your scheme too, nice to see something
different on a mustang for a change!
Hide Signatures
       Post #: 1744
RE: FiberClassics P-51 now Comp-ARF P-51 - 5/1/2011 5:38 AM
Canuck1
Score: 100
Status: offline
Thanks dvs1, it is starting to look pretty good.
No idea reference the drop tanks Peter, I am sure someone will chime in.
Finished up clearing the top, so she is done. Removed the masking of the windscreen, always nice to be able to do that.
I still have lots to do, still need an engine and attaching the doors etc.
Looking forward to putting it together to have a look. I will wait at least a week before I do that.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
(in reply to dvs1)
       Post #: 1745
RE: FiberClassics P-51 now Comp-ARF P-51 - 5/1/2011 12:35 PM
Thunderbolt47
Score: 111
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: peterduplessis
Peter
Here's a couple of pics that may be helpful to you.
Kelly
Click for fullsize
Click for fullsize
Greg Norman said, "Happiness is a long walk with a putter." Obviously he never flew a P-51 Mustang. :)
Hide Signatures
(in reply to peterduplessis)
       Post #: 1746
RE: FiberClassics P-51 now Comp-ARF P-51 - 5/1/2011 12:37 PM
Erwin DB
Score: 100
Last Login: 9/30/2012
Status: offline
Hi Craig,
Very nice job you did...just beautiful  !  Looking at your pictures gives me again some energy and inspiration to continue the building of our Mustang.
The last month I was busy building an Extra  330L from Comp arf for the summer days here in Belgium, the past weeks we had the chance to have a wonderful weather here.
We will post some pictures later on.
Again congratulations with the result you booked...
regards from Belgium,
Erwin & Jonas
Hide Signatures
       Post #: 1747
RE: FiberClassics P-51 now Comp-ARF P-51 - 5/1/2011 12:41 PM
Erwin DB
Score: 100
Status: offline
Hi Peter,
Just have a look to this thread...
Kind regards,
Erwin
http://www.modellflieger-neukirchen.de/baubericht/P51_1.htm
Peter
Hide Signatures
       Post #: 1748
RE: FiberClassics P-51 now Comp-ARF P-51 - 5/1/2011 6:43 PM
peterduplessis
Score: 100
Status: offline
Thanks Erwin ...
That reminds me of the old Bavarian Eagles website which was responsible for me deciding to buy the C-arf P51 .. Lol
Regards
Peter
Peter du Plessis
Waco Brother #224
Hide Signatures
(in reply to Erwin DB)
       Post #: 1749
RE: FiberClassics P-51 now Comp-ARF P-51 - 5/1/2011 6:54 PM
peterduplessis
Score: 100
Status: offline
Thanks Kelly
The pylon appears to be located between the outer (last two) machine guns ..
Much appreciated!
Regards
Peter
Peter du Plessis
Waco Brother #224
Hide Signatures
(in reply to Thunderbolt47)
       Post #: 1750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
