hitec 5945
Tower Hobbies
Logged in as Guest
  Printable Version
Low profile on/off switch with external charging jack
Seller:  k4lpcm
Details:   $19.99   |  9/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> hitec 5945
Page: [1]
Login
hitec 5945 - 7/20/2002 6:44:18 AM
daren
Status: offline
mike I have a hitec 5945 on my rudder with 1.25 servo arm and carbon rod going to the rudder. atv set at 140 max. dr set 140 max. rod is 7/8 out on control horn. my max deflection is only 35degrees. also low rate is set at 100% and when rudder is to the right you can see the rudder change from low to high. but when to the left there is no change from high to low rate. what do you think it is. I'd like to get as much throw as posable. would I need to go with a pull pull set up and bell crank?
       Post #: 1
hitec 5945 - 7/20/2002 10:40:03 AM
RightThrust
Status: offline
How do you like your 5945, I havn't had a chance to use mine yet. How does it center?
-Kelly
(in reply to daren)
       Post #: 2
hitec 5945 - 7/20/2002 10:51:06 AM
daren
Status: offline
centers very will but it does make some noise.
(in reply to daren)
       Post #: 3
hitec 5945 - 7/22/2002 11:19:21 PM
MikeMayberry
Status: offline
Have you tried it in any different channels to see if there is any difference?
What is the date code?
Mike.
(in reply to daren)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU1
