JET FX
Joined: 1/20/2002 From: Sydney, , AUSTRALIA Status: offline
Kerry, you said it! I have seen these models fly fine on the OS91 Ramtec set-up, and they will fly well off of short grass fields if you have a lighter model. Also I have seen them fly well with JPX 240P, and Sophia 450 power with ease... If I was to decide to install a 11lb thrust class turbine eg PST 600 or RAM 500 for instance, it would be only realistic to expect good performance if the Panthers AUW was say under 20 lb. between 15-18 lb is ideal, this lower weight is quite possible to achieve while building if you are planning on a smaller turbine to be installed....Also this is easier with a glass fuz instead of built up fuz. I am fortunate as I just happen to own a set of moulds for this fuz. And my glass Panther airframe assembled with wings/tail and retracts, less paint the engine and radio gear weighs only 8.5 lb. Here's a comparison of sorts! (similar airframe designs) Tam has been experimenting with the new D.L. ARF Aermacchi and he is flying his model at approx 21 lb AUW! with a RAM 500 for power. Tam has added a smoke system as well and numerous mods to improve structural strength for turbine use. Keep in mind this is a much smaller model with much less wing area than the Ziroli Panther. Tam reports the Aermacchi performs very well indeed despite the higher wing loading also apparent vertical performance is very impressive as well, all from an 11 lb thrust turbine.... That said with hotter conditions and adverse wind etc. it is nice though to have plenty of grunt on hand if need be....Although maybe I would not fly my pride and joy in extreme conditions anyway : ) In a nut shell the Panther 'WILL' fly well on the smaller turbines ala scale, 11- 12 lb thrust, and they fly very well on the wing! about as cub like as a jet could be... after all Nick designed this bird to fly on D/F power of only 9 lb thrust approx.
_____________________________
JET FX Australia~ Cosmic Pilots, Jets Munt, Yellow Aircraft, Sis-T, Fei Bao, Fly Eagle Jet, Wren- www.jetfx.net
