RE: SEAGULL HARRIER 90...WHO'S GOT ONE?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: SEAGULL HARRIER 90...WHO'S GOT ONE? Page: <<   < prev  26 27 28 29 30 31 32 [33] 34 35   next >   >>
Login
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 3/8/2008 3:15:33 AM
brewski
Status: offline
Cool! It really doesn't look to bad. I look forward to seeing it revived. Good luck.
_____________________________
A bad day flying is better than a good day at..........well........maybe not.
Revver Bro #177
(in reply to OK2Fly)
       Post #: 801
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 3/9/2008 9:38:04 AM
OK2Fly
Status: offline
Wait a minute!
Just had a brain fart. After reading through the entire thread, I'm going to steal the idea on post #295. Since the plane is already stripped of covering and reassembled, I'm going to cut the turtle deck and make it taper as it goes aft. Then I'm gonna build up a fin. The main reason I'm going to do this is asthetic, (looks more like a normal plane) and it'll probably flatspin better.
Here's the idea (from AdrianM).
Click to see fullsize image.
Click for fullsize
Anderson
(in reply to brewski)
       Post #: 802
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 3/10/2008 4:43:59 PM
clocklair
Status: offline
quote:
ORIGINAL: OK2Fly
Wait a minute!
ooh, now that's gonna look cool, post pics...
looks like you mend job is coming right along, just watch that taper near the back of the vert stab, you have those guywires that support the horiz stab that you will have to deal with. You could probably use some small carbon fiber on the top and keep the wire on the bottom. I would've tapered it down too if I had seen that thread. If you decide not to just two tone it, it turned out looking pretty good. It's pretty easy to cover.
< Message edited by clocklair -- 3/11/2008 7:49:31 PM >
       Post #: 803
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 3/16/2008 4:26:22 AM
fasterjman
Status: offline
I am selling a Harrier 3D 90 in the Ads. Check it out. It is a nice set up. Jeff
(in reply to FLYING WING)
       Post #: 804
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 3/16/2008 7:50:51 PM
OK2Fly
Status: offline
Been workin' hard! My teachers began to panic as spring break slowly crept up, and I was buried under homework, but I wrote myself out of the pile. Anyways, been pretty busy lately, but I should have a finished airframe by the end of the week.
As for the wires, I'll just build new mounts...
< Message edited by OK2Fly -- 3/16/2008 7:54:56 PM >
Anderson
(in reply to fasterjman)
       Post #: 805
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 3/16/2008 11:42:06 PM
wwaffelo
Status: offline
I am a new dude to the thread. I need some rookie control throws for the Seagull 90.
       Post #: 806
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 3/17/2008 8:37:16 PM
clocklair
Status: offline
quote:
ORIGINAL: wwaffelo
Wide open on both directions and fly it like you stole it.
(in reply to wwaffelo)
       Post #: 807
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 3/17/2008 11:09:25 PM
OK2Fly
Status: offline
quote:
ORIGINAL: clocklair
No, no. Fly it like a rental.
Anderson
(in reply to clocklair)
       Post #: 808
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 5/4/2008 7:20:15 AM
OK2Fly
Status: offline
I had to dig a little to find this thread. I got reeeaaally lazy [I'm only16], but I have a finished plane. Flying season is here, so I plan to get this bird in the air as soon as a replacement piston and sleeve (for the Evolution 100) arrives from Horizon. Apparently, they're on backorder .
As for covering, I guess I'll just use what's lying around as this gal will be my beater.
Click for fullsize
< Message edited by OK2Fly -- 5/4/2008 7:23:01 AM >
Anderson
       Post #: 809
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 5/4/2008 12:07:48 PM
asmund
Status: offline
quote:
ORIGINAL: FlyingGreg
Didn't know ASP made a 1.80. That's a lot of enginehope it stays attached to the fire wall. Good luck.
At last I have finally got to fly my big Harrier with the ASP 180 fs engine. It swings a MenzS 18-6 at 9000 rpm (8800 rpm for flying) and it is totally great. I think it is not too much engine and the plane flies great. Hovers at below half stick and pulls out instantly (of course[)]) After I get bored with this engine I will try my New ASP XL 120 AR twostroke to compare, and finally if I still have the plane ( sudden expiration date you know ) I will mount my MVVS 26cc gas engine with tunedpipe. I have lots of fun coming
(in reply to FlyingGreg)
       Post #: 810
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 5/5/2008 4:51:51 AM
wwaffelo
Status: offline
Dude it looks really awesome! Can't wait to fly mine with a Saito 150, and a Menz 16x8 what do ya think??
(in reply to asmund)
       Post #: 811
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 5/5/2008 4:55:17 AM
OK2Fly
Status: offline
Sounds like a good combo. I think u can turn a bigger prop.
Anderson
       Post #: 812
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 5/5/2008 4:56:29 AM
wwaffelo
Status: offline
I heard of this setup from a dude that has a 100in wingspan yak55sp with a DA 150 he said to use 30% heli fuel, and a 16x8 Menz! Am I the dope?
       Post #: 813
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 5/5/2008 5:01:43 AM
wwaffelo
Status: offline
Right now, I am only looking at 1 inch of ground clearance on takeoff, how big of a prop do yo you think I can swing??
       Post #: 814
RE: SEAGULL HARRIER 90...WHO'S GOT ONE? - 5/5/2008 5:09:34 AM
wwaffelo
Status: offline
I wish we could get more Seagull flyers involved, because I am really looking forward to flying this bird, but need all of the input that I can get. I'm still fairly new to flying r/c planes, but have a total interest into this planme for some reasoooon. I think it is going to be a BLAST to fly if I get enouigh input from others.
