IncredibleITGuy
ME, USA Status: offline
Saito 180, JR digi's sport servos all the way around. 1800MAH pack is behind the canopy wire-tied to the frame for very slightly aft cg...if not dead on. Swinging a 14x9 3 blade w/ aluminum hub. To tell you the truth.. too much power. at idle it will roll on the ground. I fly mostly with 2 clicks of throttle....90% of the time extreme slow flight. Unlimited vertical @ 25% to 33% throttle. Obviously hovering is in there as well. Plane responds nicely to controls and seemingly will not snap under ANY condition other than when properly instructed. I am not kidding. For those of you who own it, you know what I am talking about. All, meaning 100%, of my landings have been dead stick. I run the fuel out purposely each time just to make it fun. The is one of the best airplanes for such business. Climb to altitude..the smoke trail dies off...and off you go..rolling... dives...loops...inverted landing roll-outs..all dead stick. The plane is an incredible floater. The wing area makes landings a complete joke, and almost thoughtless. You would actually have to work pretty hard to crash this thing. I've got about 40 flights on mine now. Several gallons of fuel. Only thing that has happened is the bolt loosened up on my landing gear and I lost a wheel. Just harrier in the landing - no roll necessary. I also lost the canopy as the factory trim cracks from the vibes of a big thumper. got another one for $3.84 or some nonsense.. and up up away. Only downside is that it doesn't come in any more schemes.
< Message edited by IncredibleITGuy -- 12/5/2004 5:35:24 PM >
