MinnFlyer
MN, USA Status: offline
ok let settle a few things about balancing... 1) If a prop were perfectly balanced, you could set it to any place on a 360 degree plane and it will stay there. It will not rotate to a horizontal, vertical, or any other position. It will stay exactly where you stop it. 2) You will NEVER get a prop to balance perfectly. Don't believe it? Try this little experiment: Spend a few hours getting a prop perfectly balanced, then remove the prop from it's holder, and place it back on the holder in a different position. Place it back in the balancer, and I guarantee that it will no longer be perfect. 3) There was a recent article stating that if you place a slightly UNbalanced prop in the correct position on the engine, the unbalanced prop will actually REDUCE vibration by cancelling out some of the vibration caused by the piston. 4) Don't ask me what that position is, because I don't know. 5) I don't know because it just doesn't matter. I have been flying for 45 years and I have balanced 2 props. Never saw any reason to ever do it again. Bottom line: As I said before, if it's close, it's fine.
_____________________________
Mike B. AMA# 42400 www.gettingairborne.com "Those are my principles. If you don't like them, I have others." - Grouc |
