DTB
FL, USA Status: offline
quote:
Never having seen a 9c, it is hard for me to judge how similar they are. But when trying to follow the numerous examples posted about the 9c, the process begins to differ in a hurry. As far as the manual is concerned, there are lots of discrete examples for doing various things that are essentially straight forward. But the correct combination of settings (and sequence) for setting the flaps normal, low, high, and for crow do not exist. The closest they come is doing this for Flaperon settings, not for discrete Flaps. Just when I think it is going ok, I find that the flap on Ch6 moves but Ch5 doesn't. While tring to resolve this, I end up with one flap high and the other neutral when in normal mode (etc etc). Now I understand why several of the folks I know got the JR 8103 when they got their sticks. It covers all the steps to do this in the back of the stick manual. Martyn Hey Martyn Wait, Futaba makes great radios. The instruction manual may not show what you want to do, but don't down the entire company for that. I can't believe you've never seen a 9C. Below are the comparisions. The 7C is a fine radio, but can't touch the 9C. Futaba 7CA Air Rating: 3 / 5 Usage: Air Channels: 7 Modulation: PPM/PCM Frequency: 72 Computerized: Yes General Specs: - Trainer Mode: Both - Mode Select: Yes - 10 Models Controls and Trim: - Analog Trim - 7 Channel Servo Reverse Special Functions: - 3 Mixes Acrobatic Functions - Aileron to Rudder Mixing - Air Brake Control - Elevator to Flap Mixing - Elevon Function - Flapperon Function - Snap Roll Switch - V-Tail Function Applications: - All Purpose - Basic Trainer - Combat - Competition Airplanes - Pattern/Aerobatics - Standard Airplane Street Price: $319.99 Futaba 9CA Air Rating: 5 / 5 Usage: Air Channels: 9 Modulation: PCM Frequency: 72Mhz Computerized: Yes General Specs: - Trainer Mode: Both - Mode Select: No - 8 Models - Model Copy Controls and Trim: - Digital Trim - Trim Reset - Trim Memory - Sub Trim - 9 Channel Servo Reverse - 2 Slide Controls Special Functions: - 7 Mixes - End Point Adj. - Dual Rates - Exponential - ATL - Assignable Switches - Assignable Channels Display Warning: - LCD Display - Low Battery Warning - Timer Acrobatic Functions - Aileron Differential - Aileron to Rudder Mixing - Elevator to Flap Mixing - Elevon Function - Flap to Aileron - Flap to Elevator - Flap Travel - Flapperon Function - Landing Mix - Snap Roll Switch Helicopter Functions - Governor Program - Gyro Program - Idle Up - Pitch Curve - Pitch Trim - Revo Mix - Rudder to Throttle - Swash AFR (CCPM) - Swash Select - Swash Throttle Mix - Swash Type - Throttle Curve - Throttle Cut - Throttle Hold Sailplane Functions - Adjustable Exponential - Aileron Differential - Aileron to Flap Mixing - Air Brake Function - Butterfly Mixing - Elevator to flap - Elevon Function - Flap to Aileron Mixing - Flap Travel - Flapperon Function - Speed Presets - Start Presets Applications: - All Purpose - CCPM Helicopter - Competition - Competition Airplanes - Competition Helicopter - Competition Sailplane - Pattern/Aerobatics Street Price: $349.99 Notes: Price includes receiver, but not servos. I did a search on www.Futabarc.com and found this for you. Is the 7C capable of being used with a complex 7-servo aerobatic model with separate flap and aileron servos? Yes, but while you can use it with one such as the Ultra Stick, it is somewhat limited and not capable of full span ailerons. First you will need to plug your flaps into channels 5 and 7. Next go into your Para menu and make channel 5 Null. Next you will need to activate Flaperons and Flap Trim, setting the percentage of your Flap Trim as needed. Then go into your Airbrake menu and activate it, again setting the percentages as needed. Now you will want to go into your Elevator/Flap mix and activate it. Select your 3-position switch for this and once you have set your percentages as needed, you will want to make this active in the Up position. Then we will want to do three Pmixes. The first one will be Offset as master, to channel 7, put this on your 3-way switch in the Down position, and set the rate to +100%. The second one will be Offset as master, to channel 5, again put this on the 3-way switch in the Down position and set the rate to +100%. The third will be for your Flaps on a separate switch, so go into the Pmix, making Offset the master once more, and make channel 5 the slave. Set this to a separate switch in the Down position and make the rate -100%. Now you will want to go into Para and set channel 7 to whichever switch you want to control channel 5 and 7. Let's say switch E. Just remember to leave channel 5 Nulled. This will give you the following. 3-way switch in the Up position will give you some Aileron with your Elevator, in the Center position you will have normal functions of all channels, in the Down position you will have Airbrake with up flaperons, down flaps, and down elevator. You should be set now. Sometime, all you have to do is do a little searching. Let us know how it goes, DTB
_____________________________
FLY IT HARD AND HOVER IT LOW!!!
