daven
MN, USA Status: offline
Its been over a month since I pulled the first wing. Work has been crazy with travel, and I just haven't had much time to do anything. I spent the past few weeks cleaning up the molds. When I pulled the first wing, a few edges of the mold chipped loose and stuck to the wing. It was a bit more work filling these voids than I expected. First I cleaned the molds, than I filled with EverCoat "Easy Sand". I then sanded with 400 grit, than 600, than 1000, and finally 1500. After this, I checked the voids again, and refilled. This was followed by the series of sanding above. Of course, with all this sanding, additional pinholes opened up in the fiberglass mold. I needed to fill them and sand, and repeat. It took me quite a bit of time to get everything filled in and sanded smooth. After this, I applied a series of coats of Rubbing Compound on a buffing wheel attached to my drill. After that, I went down to Polishing compound with the same buffing wheel. When that was done, I proceeded to buff the mold with 5 more coats of Dolphin Wax. I can see why alot of people are using the Aluminum molds at this point
_____________________________
Dave Norman klasskote.com supertrc.com
