daven
MN, USA Status: offline
I have been working on a lay up schedule, and have it all written down so I can get everything ready before I begin. For the first part I will use PVA (just to make sure), as will as at least 6 coats of wax. The last thing I want is a stuck part, so I will not skimp on thta part. As to painting for the first one, I was thinking just a little green on the tips on top, with clear on the bottom and between the green trim. Just to fill the pin holes, but I want at least a tiny bit of color on the tips because I intend to fly the first one. I will use the rohacell on the first wing, because I need to learn how to use it, and figure out its quirks. I plan to spend considerable time making a perfect template to use for future rohacell cuttings. As to applying the glue, the caulking tubes look good, but I planned giving a sandwich bag with a cut corner a try. I spent quite a bit of time talking to Chuck Bridge and Terrence P. who have both been extremely helpfull in the layup process with not only products but also techniques. You'd think they would keep some of this to themselves, but that was not the case. Both have been Extremely helpfull and supportive.
_____________________________
Dave Norman klasskote.com supertrc.com
