Break In Settings!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Break In Settings! Page: [1]
Login
Break In Settings! - 8/5/2004 4:20:46 PM
teamsquirreltail
Status: offline
Hey guys, I need your help. I need to know the factory carb settings of an O.S. .15 CV-R w/ slide carb and a NovaRossi C12 with rotary carb. I tried looking on the net, but OS's site was no help, and NovaRossi's site is Italian, which I cannot read. I read somewhere that the C12 was 5 turns out on the high speed and 2 on the low, but that sounds strange. Thanks!
       Post #: 1
RE: Break In Settings! - 8/5/2004 4:59:00 PM
Frost_
Status: offline
So you bought an OS motor that came without instructions?? If not your breakin settings are absolutely in there...
_____________________________
http://www.fastrides.com/forums/5486/ShowPost.aspx
http://www.fastrides.com/forums/4178/ShowPost.aspx
(in reply to teamsquirreltail)
       Post #: 2
RE: Break In Settings! - 8/6/2004 2:03:25 AM
teamsquirreltail
Status: offline
Yeah, I bought them used!
(in reply to Frost_)
       Post #: 3
RE: Break In Settings! - 8/6/2004 11:56:26 AM
Frost_
Status: offline
Well the settings are on their site and undoubtedly posted on this site somewhere as well....
       Post #: 4
RE: Break In Settings! - 8/8/2004 7:50:04 PM
teamsquirreltail
Status: offline
If you can find the settings on OS's site, you are my hero. Also, if you can read French, you are a GOD! So, why not help me out?
       Post #: 5
RE: Break In Settings! - 8/14/2004 5:49:32 PM
redheat8
Status: offline
I have 3 cv.12rx motors and the factory settings if I recall are about H/s 3.5 turns out, bottom 2.5, now keep in mind that your motors are used so no telling what condition there in , and more than likely factory setting are gonna be to rich for a motor that has already been broken in, I would check to see what kinda compreeion they have before doing any tuning. RED
2- Tmaxxes, RC10GT, T3, B4, TC3 Time to rock
       Post #: 6
RE: Break In Settings! - 8/17/2004 4:43:50 AM
had enough
Status: offline
OS engine
http://www.osengines.com/manuals/15cv-r-cv-rx-manual.pdf
page 15-19
2 out on top (it says that on page 15, but that sounds funny?)
2.5 in from flush on the bottom
the Rossi engine i can't help you with other than to give you the current settings on my MT12
3 out on the top
1.5 out on the bottom, when in the closed position
go about .5 turn out on each and you'll probably be fine
My MT12 never came with a manual that shows settings either
< Message edited by scale_only_4_me-RCU -- 8/16/2004 8:55:59 PM >
(in reply to redheat8)
       Post #: 7
RE: Break In Settings! - 8/17/2004 2:45:00 PM
redheat8
Status: offline
Oops that was my 2.5 that would have set you very rich, RED
(in reply to had enough)
       Post #: 8
RE: Break In Settings! - 8/17/2004 3:21:17 PM
had enough
Status: offline
The RB site the has all the info in both French and English
http://www.rbproducts.com/indexEn.php
a c12 is a RB engine not a Nova Rossi
copy and paste fom the RB site
ROTARY carburetor settings.
The RB Concept carburetors of the 2.11cc(.12) engines are set at the factory with a special vacuum measure tool before they are packed, to obtain a setting for an easy start of the engine. If you are lost with your settings we cannot ask you to send back your carburetor to set it for you, so we propose to you in this way the settings we find generally as an average setting.
The main-needle(A) is used to adjust the debit of the fuel when the barrel is totally opened, it must be turned in totally(closed) and then opened again 4 turns.
The idle needle(B) situated in the barrel is used to adjust the debit of the fuel when the barrel is in the closed position(idle), it must be turned in totally(be sure you position the barrel in the open position before you do this, so you do not damage or block the needle in the spray-bar) and then open again 3,3/4 turns.
The idle/air-screw(C) is used to adjust the idle rpm, it must be turned so that when the barre of the carburetor is closed there is an air-gap(D) of approx. 0.6mm.
Please note that these settings should help you start your engine and that in normal conditions these settings are as we say on the rich side. You still have to adjust your carburetor to get optimal performance. Also please be aware that the settings can varie compared to the fuel you use. The settings mentioned above have been made with RB Concept Fuel.
< Message edited by scale_only_4_me-RCU -- 8/17/2004 7:31:34 AM >
       Post #: 9
RE: Break In Settings! - 8/23/2004 9:08:49 PM
teamsquirreltail
Status: offline
Ah, thanks guys! I eventually found the settings I needed on someone's site. Now, the C12 I have is an "RB" and not a "NovaRossi?" That is quite odd. I will have to get a picture. It has a purple head, and I could have sworn to it having the Nova symbol on the crank case! Oh well, I 'spose that doesn't matter. Thanks for your help people!
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.656RCU3
