Are Peak Chargers Killing my Batteries?
Tower Hobbies
Logged in as Guest
  Printable Version
Slimline Boxxer Fuel Pump
Seller:  Erick Royer
Details:   $50.00   |  9/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Are Peak Chargers Killing my Batteries?
Page: [1] 2   next >   >>
Login
Are Peak Chargers Killing my Batteries? - 7/25/2002 8:54:24 PM
YUKON BOB
Status: offline
I have been flying R/C planes for a long time and it appears to me that my batteries don't live as long as they used to. I have been using Smart Chargers & Peak Field chargers lately and the life span of my batteries seems to be shorter. If these chargers are so smart why are they killing my batteries? I still use my trusty Digipace to cycle batteries regularly. Has anyone else noticed this or it is just the nature of using these types of chargers in place of the good old stand-by and wait 14 hours for a full charge types?? Batteries are not that expensive unless you have several airplanes and radios. (Like Me) :disappoin
_____________________________
I love the smell of buring nitro in the morning.
AMA 1548
       Post #: 1
. - 7/25/2002 8:57:24 PM
lnorris
Status: offline
< Message edited by lnorris -- 9/11/2003 4:23:30 AM >
If you aren't breaking something, you're not trying hard enough...
(in reply to YUKON BOB)
       Post #: 2
Are Peak Chargers Killing my Batteries? - 7/25/2002 10:47:25 PM
rcflier_gi
Status: offline
IMO fast peak charging is usually harder on a battery than a properly timed slow overnight charge that goes to trickle. Every peak charger I have owned always get the battery fairly warm at the end of the charge. The heat indicates some overcharging has occured and overcharging is bad. So I guess we pay a price for a quick charge.
Current airworthy planes :
SIG Mayhem 3D w/OS 1.20FS pump
       Post #: 3
Are Peak Chargers Killing my Batteries? - 7/26/2002 4:44:08 AM
starzak
Status: offline
Nothing but goodness here. I fly using a Sirius Pro, or Alpha 4 to charge about twice a week, 52 weeks per year.
No problems here.
       Post #: 4
Peak charging - 7/26/2002 5:54:23 AM
RC Accessory
Status: offline
I rarely use a slow charge. I use a Alpha 4 and Dymond Super Turbo. My typical packs are usually tossed when they reach 2+ years old even though they cycle fine. Cheap insurance. I doid have 1 pack for over 4 years in a pattern plane. Always peak charged.
       Post #: 5
Are Peak Chargers Killing my Batteries? - 7/26/2002 6:11:12 AM
lch1780
Status: offline
the reason your batteries are getting hot is because they are reaching full peekness.If you want a good charge but fast do what ive been doing for 15 years invest in a peek charger that has a current adjust for instance charge a 5oo mh battery at 1/2 amp it will chare in aprox 1/2 hour but you battery will not get very warm chargers like the hobbico field charger charges at 2 1/2 amp and thats to fast for a 500mh batt im sorta stuck on the fma charger it will charge cycle discharge and charge any type of battery and it will fit in a small space in your field box i hope this helps some . happy flyin
       Post #: 6
Are Peak Chargers Killing my Batteries? - 7/26/2002 6:50:23 AM
Geistware
Status: offline
I would contact Red and ask him but it may be due to the higher densities that exist with our high energy batteries. We are putting more energy in the same space and this may be why batteries don't seem to last as long as they did in past years.
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 7
samples 4 years old and still strong - 7/26/2002 9:22:58 AM
larryflew
Status: offline
Being we used to sell batteries wholesale to hobby shops we have several that have been on twice a week charge and discharge and after 4 years are still almost as good as when they were new. These were 1200 mah nicad 4/5 A receiver packs. Have done the same with 1700 SCR sub C packs that are also that old and they are better than they were when new.
       Post #: 8
Are Peak Chargers Killing my Batteries? - 8/1/2002 3:21:10 PM
mskyhawk
Status: offline
I have found that peek charging is fine as long as the battery is down to 1 volt. we can't run them in our radio equipment this low so before quick charging, put them on a discharger until they are about 1 volt then peek charge them. If you don't discharge them, they will build up a memory and their useful run time will get shorter and shorter every time you peek charge them.
It is also good to every once in a while put them on a trickle charger for a day or two to get them a full charge. A peek charger will "peek" them out but will not give them a full mah. charge which means less run time on a peek charge. Just a faster charge
mskyhawk
[url]www.wabashrc.com/skyhawks[/url]
       Post #: 9
Are Peak Chargers Killing my Batteries? - 8/1/2002 9:21:20 PM
Rodney
Status: offline
Myskyhawk, you are missinformed; nicads do not, repeat DO NOT have memories. This is an old wives tale that does not seem to die. Check out Red's site [url]www.rcbatteryclinic.com[/url] and read the various info he has posted there. Red seems to know what he is talking about, at least when it comes to battery care and feeding.
In general, if your batteries are getting hot, you are abusing them and can expect reduced life and/or useful cycles. You might also want to check out [url]www.panasonic.com/[/url] and dig down to their info on both NiCad and NiMh batteries. Get the scoop straight from the horses mouth, not rumors from the uniformed.
       Post #: 10
Are Peak Chargers Killing my Batteries? - 8/2/2002 1:29:35 AM
mskyhawk
Status: offline
OK Rodney, I will check out the links. But I just had to take my batteries off my battery cycler where they wouldn't show a charge or charge above 300mah. Now after 3 cycles they will hold and charge to the battery rating of 600mah.
This isn't removing a memory? or restoring my battery to it's full capacity?
Confused by your statement, I am, But I will keep an open mind and read the links you sent. I have been around these batteries for years and the term memory build up has been associated with them for as long as I can remember . I love this site because I learn something new all the time. But I will keep using my battery cycler every so often because it works.
mskyhawk
       Post #: 11
. - 8/2/2002 1:54:07 AM
lnorris
Status: offline
< Message edited by lnorris -- 9/11/2003 4:23:44 AM >
       Post #: 12
. - 8/2/2002 2:06:19 AM
lnorris
Status: offline
< Message edited by lnorris -- 9/11/2003 4:23:58 AM >
       Post #: 13
Are Peak Chargers Killing my Batteries? - 8/2/2002 2:53:23 AM
mskyhawk
Status: offline
Thanks for this link Inorris. I haven't seen all of the link though I am still confused on the battery cycler. This document says it is harmful for nicads but yet it appears to help mine. I will read it completely and maybe it will help.
< Message edited by mskyhawk -- Aug 1 2002 10:02PM >
mskyhawk
       Post #: 14
Are Peak Chargers Killing my Batteries? - 8/3/2002 7:46:33 AM
Hangtime
