Car bogs down at full throttle
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Car bogs down at full throttle
Page: [1]
Login
Car bogs down at full throttle - 8/11/2004 10:09:11 AM
nitroarcher
Status: offline
Hi guys, hope you can help me, once i start my car the engine gets up to temperature about 215f and idles perfectly, when i start driving it around if i give it full throttle it bogs down and will sometimes cut out, am i running too rich or too lean on the HSN. Or is it anything to do with the LSN. i am still a bit of a newbie, all advice will be appreciated
       Post #: 1
RE: Car bogs down at full throttle - 8/11/2004 1:29:59 PM
Blackjaxx360
Status: offline
Your HSN is a little too rich. Make your adjustments in 1/8 of turns clockwise. Also make sure the engine is at operating temps before making adjustments. Tuning a cold engine can be frustrating.
_____________________________
[b] BLACK-OUT[/b]..........[i]coming soon![/i]
(in reply to nitroarcher)
       Post #: 2
RE: Car bogs down at full throttle - 8/11/2004 1:37:36 PM
nitroarcher
Status: offline
Cheers mate i will lean the HSN out a bit tonight, also Blackjaxx360, whats the best way to clean the foam air filter. Cheers mate
(in reply to Blackjaxx360)
       Post #: 3
RE: Car bogs down at full throttle - 8/11/2004 1:48:48 PM
Blackjaxx360
Status: offline
With dish soap and water. Make sure it is thoroughly clean and apply some air filter oil to the foam so that it covers the whole area. Slightly squeeze out the excess (not too much) and re-install it on the carb. I recommend doing this after every run for optimal performance. Some people don't, but I do. Sort of like after run oil. Do it after every time you finish running. Tip for newbies: It is also a good idea to leave the piston at bottom dead center after each run, it will help prolong compression in your engine. Mark your flywheel accordingly to save yourself time. Hope this helps
       Post #: 4
RE: Car bogs down at full throttle - 8/11/2004 2:10:30 PM
nitroarcher
Status: offline
I will pop down to my LHS and pick up some after run oil and filter oil later, am i right in saying you put just a couple of drops of after run oil in through the glow plug hole and then turn the flywheel by hand a couple of times leaving the piston at bottom dead centre
       Post #: 5
RE: Car bogs down at full throttle - 8/17/2004 12:47:27 AM
neil.jb
Status: offline
yeah, i also drip a few drops into the open carb (after removing the air filter obviously) to lube the crank shaft, after dripping it in just pull the starter chord a few times or turn the engine over with your starter box for a seccond or so, temp wise with your engine you want to be aiming for around 250 degrees, how are you measuring your engines temp?
       Post #: 6
RE: Car bogs down at full throttle - 8/19/2004 1:09:11 PM
nitroarcher
Status: offline
with a mini temp gun but am using farenheit, should i use the degrees setting instead
(in reply to neil.jb)
       Post #: 7
RE: Car bogs down at full throttle - 8/19/2004 5:02:43 PM
neil.jb
Status: offline
farenheit is fine, you shoud aim for 230-250ish
       Post #: 8
RE: Car bogs down at full throttle - 8/20/2004 7:10:13 AM
nitroarcher
Status: offline
Cheers Neil jb
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.486RCU3
