RE: Engines for B-17
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Engines for B-17
Page: <<   < prev  1 [2]
Login
RE: Engines for B-17 - 8/15/2004 2:37:59 AM
MEMPHISBELLE
Status: offline
I did know how to fly before I tried out the B-17. I did build a C-47 from tropflite and flew it for a summer before the bomber was finished.
The outboard tanks are behind the fire wall. The inboard tanks are in the wing beside the nacelles. I am not using pumps on the engines.
Wes
(in reply to b17flyer)
       Post #: 26
RE: Engines for B-17 - 8/15/2004 7:13:44 PM
BadBart
Status: offline
That is impressive. First twin was a C-47 then right to the B-17!
Great job!
Pat
(in reply to MEMPHISBELLE)
       Post #: 27
RE: Engines for B-17 - 8/16/2004 1:31:36 PM
FTIGER43
Status: offline
Thanks for the info on tank location. I have been flying for a long time, at present I am flying Ducted fans and Gaint scale. Is there a multi engine plane I should fly first or is the B-17 a good start. I did have a Hobico Twin that was not impressive. Thanks for all the help Tom.
       Post #: 28
RE: Engines for B-17 - 8/16/2004 6:18:28 PM
MEMPHISBELLE
Status: offline
Four is better than two. I would do the B-17 ,but thats just me.
Wes
(in reply to FTIGER43)
       Post #: 29
RE: Engines for B-17 - 8/19/2004 12:19:37 PM
fockewulf37
Status: offline
I am getting ready to start The American Eagle B-17. You may want to consider Magnum 70 4 strokes. I just ordered 4 of them. I have 3 of their 61 4 strokes and they run great. I have 2 of them on a 3 engine and have never had one go out. The 70's are on sell right now from Global. I paid $135 each. The AE b-17 will fly well on this even at the 50 lbs. The lightest one of the AE B-17's has come in at is 35lbs...So I am shooting for 40LBS...
TY
       Post #: 30
RE: Engines for B-17 - 8/22/2004 11:14:27 PM
b17flyer
Status: offline
mine was 38 lbs to start, after a major repair, 41lbs. you should have no problems.
(in reply to fockewulf37)
       Post #: 31
RE: Engines for B-17 - 8/22/2004 11:15:48 PM
b17flyer
Status: offline
mine was 39 on maiden and for about a yr and 1/2. After a major repair 42. You should have no problems there.
       Post #: 32
RE: Engines for B-17 - 8/23/2004 6:23:05 PM
BadBart
Status: offline
The more and more I "plan" I'm leaning towards the RCV .90's in order to reduce the amount of cowl cutting to a minimum. I'm trying to make this plane as scale as possible.
Pat
       Post #: 33
RE: Engines for B-17 - 8/23/2004 7:55:36 PM
bigchap
Status: offline
10 1/2 foot span and 50 pounds!what on earth is it made out of?
       Post #: 34
RE: Engines for B-17 - 9/10/2004 3:32:44 PM
allr
Status: offline
If you are looking at possibly gas engine, you might consider the RCS 1.4 it would fit the Don Smith but would most likely be to large for the American Eagle. The American Eagle size you should probably stay with 2 ro 4 stroke glow engine. Anyway the 1.4 is considereably smaller and lighter than a G-23. Not much larger than a .91 four stroke and with the carb in back makes a slinder package. It does have electronic ignition. The only draw back is probably the price.
(in reply to bigchap)
       Post #: 35
RE: Engines for B-17 - 1/29/2006 3:24:53 PM
dutch Jan Hermkens
Status: offline
hi Guys,
have a look at my home page and you will be astonished how little power a RC B-17 model needs for "scale" flying!! even with 2 cut-off engines!
www.home.versatel.nl/jan.hermkens/
My B-17 models: Both build from own plan.
Scale 1:10: Span;124". Weight;35 pound. Engines;4x0.40 Osmax FSR 2-stroke. 2x National champion.
Scale 1:8: Span;158". Weight;44 pound. Engines;4x 0.70 Laser 4-stroke. 4x European Star Cup champ.
Cheers,
Jan Hermkens, Netherlands (the flying Dutchman)
_____________________________
Flying Dutchman. Multiple Scale Champion all over Europe, with B17, P61, Sunderland.
(in reply to allr)
       Post #: 36
RE: Engines for B-17 - 2/3/2006 5:10:56 PM
Junior55
Status: offline
Hi guys i'm bulding a westcraft b-17 this one is all fiberglass fuse and wings. but four saito 91s. want to paint my green but not the olive drab. form who do you get the light green from. thank you jr.
(in reply to dutch Jan Hermkens)
       Post #: 37
RE: Engines for B-17 - 2/5/2006 2:56:30 PM
jimcork1
Status: offline
quote:
ORIGINAL: MEMPHISBELLE
All I have to say is SAITO, I have 105 flights on my don smith B-17. I might also add that all landings were completed with all four engines running every time. I am building Don's liberator right now and will power it with Saito's.
Wes
I fly my Herk with 4 Saito .30's and it flies very well. However it is not over powered and climb out is very realistic. Total weight fueled up right at 22#'s
Click to see fullsize image.
Click for fullsize
       Post #: 38
RE: Engines for B-17 - 2/6/2006 3:03:48 PM
dutch Jan Hermkens
Status: offline
Hi, Junior 55
I fly my B-17 (build from own plan, span 4m=158" ) with only 4x Laser 0.70 (13x6 M.A.prop) and it is flying real scale. Even on two engines, did happen once! made a touch and go on three engines, but soon after that the second one cut off, did fly to long, fuel was gone! I could keep the model in the air with the two remaining engines, could not get height anymore, but keep on flying without losing height, Perfect landing!
My favorite engines are the Laser four stroke from the UK. I have only them!
4x 0.70 in my B-17 (Over 400 flights, 1x cut-off engine). From own plan: span 158" .Weight:44 pound.
1x 0.70 in a Harvard. (span 60" ) . Weight 6,5 pound.
2x 2.40 V-twin in my P-61(over 150 flights, never cut-off ).From own plan.Span: 122". Weight:41 pound.
1x 2.40 V-twin in my Corsair (span 80" ). Weight 18 pound.
1x 2.40 V-twin in my Waco YMF (span73" ). New, did not fly yet, only finished it last november.
Junior, there are two types colour Olive drab: Light olive drab, and the more green one: Olive Drab 41 used for the B-17, and there is the colour Medium green 42, but not used for B-17 as far as I know.
Good luck with your B-17.
Have a look at my homepage for my R/C scale models: www.home.versatel.nl/jan.hermkens/
cheers,
Jan Hermkens from the Netherlands. Multi R/C Scale champion all over Europe.
(in reply to jimcork1)
       Post #: 39
RE: Engines for B-17 - 2/6/2006 4:50:36 PM
Junior55
Status: offline
Thanks i'm useing the saito 91s on my. trying to get the olive drab 41 or the light one.but no body hasit only top flite has the olive drab but not the 41 or the light. thank you for the help jr.
       Post #: 40
RE: Engines for B-17 - 2/8/2006 11:00:55 AM
Rickles56
Status: offline
I am going to use O.S. .91 4-stroke pumped engines on my DS B17. I contemplated engined for the longest time and decided on the OS engines for sound, size and weight. My second choice was Zen G26's or G23's if you can find them.
The Pumped .91 has no fuel draw problems, it works just like a gas engine... the pummp draws fuel from the tank. It doesn't pressurize the tank and then you have problems with tanks bursting, lines blowing off, etc.. Very simple, one line to the pump on the engine and a vent line from the tank hangs out the bottom of the nacelle. Use one tank per engine. The OS 91 can turn MA 14-7's 3 blade but it flys better with the 12x8 3blade.
R/C Rickles
B17's, is there anything else?
(in reply to Junior55)
