Adjust for reduced Nitro
Tower Hobbies
Logged in as Guest
  Printable Version
CRRC-Pro GF26I 2 stroke gas engine
Seller:  jewillis2
Details:   $219.88   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Adjust for reduced Nitro
Page: [1]
Login
Adjust for reduced Nitro - 7/26/2002 6:20:08 PM
lenough
Status: offline
If you have been using 20% nitro and drop down to 15% nitro, will the carb need to be adjusted leaner for the reduced nitro?
Thanks.
       Post #: 1
Adjust for reduced Nitro - 7/26/2002 7:52:41 PM
downunder-RCU
Status: offline
The short answer is yes....the less nitro you use the more economical the engine is so the needle has to be wound in a little. Just tune the engine the way you normally do...peak it then richen a little. The idle may need a small adjustment too.
(in reply to lenough)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.172RCU1
