mxwrench
CA, USA Status: offline
HighSierra, The model engine we are talking about here is the OS FS-26S-C car engine. It has a useable range of 3,000-22,000 rpm. The model you must be thinking of must be the airplane version. I believe it has a peak rpm of 13,000 rpm. The use of a two speed In my opinion is not necessary. My modified .26 is capable of 27,000 peak rpm. With valve float happening around 28,000. Hopefully with Ti valves and rockers I might be able to get this to 30,000. This would only be 5,000 rpm shy of most two strokes. Add the fact that you can engage the clutch much earlier on a four stroke due to it's awesome torque down low. I think it should be very compareable to two stroke power spectrum just 7,000 rpm lower in the range. Look again at the dyno graph, it shows the engine peaking at 26,500. As for the piston material, I believe it is high silicon aluminum. And yes this engine has a piston ring. Hope I have answered your questions. BK
