John Z Williams Jr
Joined: 9/17/2003 From: Boulder, CO, USA Status: offline
Yes, Duane and I have been using the eagletree system to test planes, props and engines, clearly an advantage to finding out what props work well, which props slow down too much in the turns and which props work well in the straights and in the turns, I could not see a 5mph to a 7mph difference in speed, but the data recorder can!!! It clearly helped up to develope props, we run the black prop and see if we can beat that with wood, what was interesting is like Duane said, some that ran 24,500 or 25k on the ground sounded awesome in the air, we thought we had the mother load... Wrong, it sounded great, but was not faster, but slower by 8-10mph than the prop peaking at 23,200 or so... We thought by sound and looking at it the higher rpm prop was smoking, but in reality it was slower!!! WE had one prop that would unload and go like stink across the field, but when put down on the course it bogged down to much and ended up being 10-12mph slower than the black apc prop... let it go across the field and it was 4mph faster than the black prop, this was usefull info!!! They can also measure by a dual axis g force meter acceleration out of the turns and off the line to # 1. Rpm in the air is helpull too... You can make sure you are reaching that majic 27k number in the air and when you reach it!!! Is it right after the turn, or is it half way down the straights or is it right at the end of the straight right before you pull again??? These are great quesions that can be answered by the data recorder... The clock will give you total lap times, but to study what the props and plane and engine are really doing in the turns and in the straights, the recorder can not be beat!!! If nothing else it let me know the apc black prop is hard to beat and out of 15 props, I made one that was slightly better!!! That let me know which one to run!!! Then we ran Duane's plane and it was on fire, it let me know how the extra weight on my plane affected speed in the straights and turns!!! He had 8mph on me!!! Boo Hoo, if first you do not succede, try try again... I would have never know this because our lap times were almost identical!!! This shows you can take a plane that is 8mph slower and still turn the same lap times as another pilot with a faster plane, now if I could get my plane going that extra 8mph, I would be set eh???!!! Of course Duane was running his monster BSE Jett Motor...
