hauckf
AL, USA Status: offline
To raise the oil percentage in a gallon of fuel from 17% to 20% add 4.8 ounces of oil to the gallon. If you want to calculate it yourself, here's the formula: Fl oz. to add to a gallon = (D% -S%) X 128 / (100 - D%) where D% is the desired oil percentage, S% is the starting oil percentage. In your example, (20 - 17) X 128 / (100 - 20) = 4.8 Here's an easier way: If you are trying to raise the oil percentage of a gallon of fuel to 20% oil, add 1.6 oz. of oil for each percent of increase you want. In your case, you want to increase the percentage from 17 to 20, or 3%. 3 X 1.6 = 4.8 oz. To get to 18% add 1.56 oz for each % increase you want. To get to 19% add 1.58 oz for each % increase. To get to 21% add 1.62 oz for each % increase. To get to 22% add 1.64 oz for each % increase. If you don't want to do any math at all, there are several sites that have calculators that will do the math for you, and several programs to do the calculations have been offered on this forum. (Sorry, I don't have any of the addressed for the sites.)
