2 stroke fuel in a 4 stroke
Tower Hobbies
Logged in as Guest
  Printable Version
CRRC-Pro GF26I 2 stroke gas engine
Seller:  jewillis2
Details:   $199.88   |  7/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> 2 stroke fuel in a 4 stroke
Page: [1] 2   next >   >>
Login
2 stroke fuel in a 4 stroke - 12/4/2001 6:57:15 AM
RCadmin
Status: offline
I'll kick things off here.
How may of you guys are using 2 stroke fuel in your 4 strokers and what are the advantages or disadvantages?
       Post #: 1
fuel stuff - 12/5/2001 2:38:03 AM
Hobbsy
Status: offline
Until recently I had been using Fox's 50%/50% in both two and four strokes. I got a RCV .90 and got the Recommended WildCat Premium Plus for it, so I'll use the Fox in two strokes and the Wildcat in four strokes and see how it goes.
< Message edited by hobbsy -- Dec 12 2001 3:29PM >
_____________________________
Giant Saito, 73.2 Cu. In., 70.5HP @ 5,800 rpm, 79 ft. lbs torque @ 3,500 rpm, 57 mpg, 3.50 bore, 3.81 stroke. 563 lbs.
(in reply to RCadmin)
       Post #: 2
2 stroke fuel in a 4 stroke - 12/8/2001 8:02:07 PM
ricfly52
Status: offline
I have been using omega 15% two stroke in both my 4 stroke engines with no problem. However, I have had two guys tell me that my 4 stokes will run a bit cleaner, and a little better on 4 stroke fuel. Has to do with the right oil content.
       Post #: 3
2 stroke fuel in a 4 stroke - 12/8/2001 8:22:09 PM
RCadmin
Status: offline
I was running the 15% four stroke fuel (Omega) in my 4 stroker and the muffler quickly became a brown nasty mess. I was told from the guys at the field that this is from the castor content and going to a 2 stroke fuel would run cleaner, avoid the muffler problem and work fine as well. This advice came from an engine machinist who really knows his stuff about model engines. Either one appears to be ok but the only downside of the 4 stroke fuel seems to be the brown glaze from the burned up castor on the muffler. A wire brush will clean it up though.
Marc
RCU Site Admin
RCU Videos. Free Video Sharing. - www.rcuvideos.com
Visit RCU''s New Banner Free E-flight Only Website: www.WattFlyer.com
       Post #: 4
Two-Stroke - Four-Stroke Fuel - 12/8/2001 8:40:15 PM
mglavin
Status: offline
The only difference between four/two stroke fuels is the fuel manufactures actual oil content.
For instance most four-stroke engine manufacturer's suggest running a higher percentage of oil by volume than their two-stroke cousins.
Four-strokes generally call for 18-20% oil.
Two-strokes range from 15-18% oil.
The other considerations are Nitro content and oil type...
Most engines [not all] respond to higher percentages of Nitro very well. 30% Nitro is very common and has proven to be safe. More expensive but does provide some benefits. i.e; improved performance, improved idle, cooler running engine. Four-stroke engines really come alive with 30% Nitro.
Oil is another consideration. Most user's regard synthetic as the answer to all. I use 100% synthetic oil by volume in my sport engines. My engines that are leaned on [not leaned out] and abused for racing such as my YS Engines 120-SC's and two-strokes, I am using a fuel such as Wildcat's Pro-Blend. It is offered in various Nitro percentages with typically 18% oil by voume with 95% of the oil mix being synthetic and the 5% balance being good old fashioned Castor Oil.... The Castor Oil offers some benefits not found in synthetic's. Castor Oil is superior in heat transfer, does not break down as early as synthetic when exposed to high temperatures and works as a rust inhibitor.
In the small ratio as I have suggested I have never had any negative problems with the use of Castor Oil...
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
       Post #: 5
2 stroke fuel in a 4 stroke - 12/14/2001 12:54:49 AM
newstick
Status: offline
Hey guys,
I was speaking to the owner of our LHS just last week about the difference in the 2. I use Omega's cool power 15% in my 2 and 4s engines. The owner was telling me Olmega's cool power and their 4 stroke fuel both have the exact same content. He said when he approached them and asked the difference they would not respond other than the label. Seems like a way to make more money on their part. I've seen the contents myself. Same nitro/oil?? Hmmm..
[QUOTE]Honey, I've gone flying!![/QUOTE]
       Post #: 6
2 stroke fuel in a 4 stroke - 12/14/2001 1:39:25 AM
Elwood
Status: offline
I have heard a lot about the different oils. It is my understanding that castor oil works better the hotter it gets, and that synthetic does not stand up to the heat of combustion very well. I think it would be best to use a good % of castor in your fuel. The synthetic will be great for the bearings, but the castor is even better for the piston area.
My .02.
Born in the U.S.A.......Not quite as long ago as Art!!!!!!!
       Post #: 7
Fuel differences - 12/17/2001 12:18:20 AM
CurtD
Status: offline
I checked on Cool Power for my 4-strokes. Their 4-stroke pattern fuel contains 20% oil (this is on their website). Cool Power 2-stroke fuel contains 17% oil (this is old information but I believe it's still correct). Several of the AMA pattern guys here are running the 4-stroke Cool Power pattern fuel in their YS's with excellent results (YS 1.40's require 20% oil).
       Post #: 8
2 stroke fuel in a 4 stroke - 12/20/2001 11:58:58 PM
Jester
Status: offline
I've been using Powermaster 2-stroke 15% nitro fuel in my OS 4-strokes. The OS instructions say use a fuel with 18% oil and this is what the 2-stroke Powermaster has. Just don't run the engine too lean. If you want some insurance, add a little extra oil.
       Post #: 9
2 stroke fuel in a 4 stroke - 12/22/2001 8:16:13 PM
ricfly52
Status: offline
I have been thinking about switching from Omega, to Cool power, for both my 2, and 4 strokes. What is the difference in the two?
       Post #: 10
Re: 2 stroke fuel in a 4 stroke - 12/23/2001 3:18:25 PM
Miniair
Status: offline
[QUOTE]Originally posted by RCadmin
[/QUOTE]
Not sure about all the engine manufacturers but Saito will void their warranty if you use 4 stroke fuel in their engines. They state to only use 2 stroke fuel.
Jim Rea
jr@miniair.com
       Post #: 11
this fuel vs. that fuel...BAH! - 12/23/2001 9:19:31 PM
Gene Chernosky
Status: offline
Four stroke fuel has less oil in it. Some four stroke engine manufacturers tell you NOT to use four stroke fuel in their engines because of this. Most four stroke engines are ringed and typically like synthetic/castor blends...heavy on the synthetic. Most two stroke engines are ABC and like the same blend but heavy on the castor, there are some exceptions. Typically four stroke fuel will have 15-18% oil and two stroke fuel will have 18-22% oil, there are some exceptions. I personally use the same fuel, 10% nitro/20% oil (mostly castor), in all of my glow engines...period! My planes are a little greasy at the end of the day...SO!...my engines are in excellent shape!
It is ALWAYS good to err on the side of a little more oil if you want the longest possible life out of your engines. Speaking of oil...don't forget an after-run oil after each day of flying either! If you use a heavy castor oiled fuel in a ringed engine this is imperative! I use Marvel Air Tool Oil...you can get a quart at a auto supply house for ~$6...cheap!
Eugene S. Chernosky
"I'm the person your parents warned you about"
       Post #: 12
Coolpower - 12/24/2001 1:32:39 AM
Jester
Status: offline
[QUOTE]Originally posted by ricfly52
[/QUOTE]
I've been told that Coolpower has only 17% oil. So I won't use it in my OS 4-strokes without adding some extra oil. As I recall it uses only synthetic oil. Otherwise it's a good fuel.
       Post #: 13
Fuel Choices - 1/14/2002 10:14:56 PM
HighSierra
Status: offline
U used to run Byrons 20/20 thru all of my engines but I've switced to Magnum #1 for all my saitos as well as my 2 opperational Helis. I always add about 2 oz's of Klotz per gallon of fuel (3 -4 ozs if it's a real hot summer) All of my enignes love it..smooth low idles and loads of power.
active in the hanger: TT Rare Bear (YS140), H9 Funtana (saito 180), DP Ultimate (YS 63), Trex SE V2 (Align 430LF)
       Post #: 14
2 stroke fuel in a 4 stroke - 1/15/2002 12:28:28 AM
RCadmin
Status: offline
After doing even more research on this and some discussions with some knowledgeable people on this topic I'm going to use my 2 stroke fuel also in my four strokers. 15% nitro and 20% oil. You may lose 100-300 rpm because of the replacement of oil instead of the alcohol component but the other side of the coin is the engine will last much longer and if your a sport flyer that is an easy trade off since that small an rpm drop is negligible (most of use overpower anyway).
I think unless you are a maximum performance competitor and don't care about burning up engines much sooner than necessary just in order to tweak a couple hundred extra rpm than going with the 2 stroke fuel w/20% oil is the answer. Even Saito as stated above will void the warranty if you use 4 stroke fuel! That should tell you something...
I guess it's a matter of application...all out performance vs. engine wear and longevity. For the 90% that are sport flyers I would think that longevity would be preferred.
Now I just have to burn the rest of my 4 stroke gallon off! Maybe I'll add an ounce of Klotz since the motor is still semi-new.
Also, Gene mentioned to use an after run oil but also should add to that to avoid certain after run forumulations in certain engines as it could damage o-rings/seals.
Marc
RCU Site Admin
       Post #: 15
4 stroke fuel - 1/20/2002 9:37:37 AM
CAPtain232
Status: offline
I recently purchased a 4 stroke engine and I too do not want to buy 2 separate types of fuel. I did some research on this and found out that it is pretty critical to the life of a 4 stroke engine to have caster in the fuel. I believe someone else mentioned that synthetic doesn't stand up in the extra heat of a 4 stroke. So, what I finally came up with is this....get the 2 stroke fuel of your choice and add a small amount of caster oil to it. I have been doing this in a smaller bottle. I add 1/4 oz caster to 10 oz fuel. This should bump the oil content up by 2%. So you can buy the fuels with less oil in them such as 18% and bump it to 20%.
good luck to all Jeff
       Post #: 16
