Mike James
AK, USA Status: offline
To minimize sanding and filling on any fiberglass surface, it's good to use a squeegee of some sort, to remove as much resin as possible. (The "industry standard" is to use the same weight in resin as the cloth weight) For jobs of this size, I use ordinary playing cards... available in packs of 52 each, and disposable. Old credit cards, calling cards, or anything similar can be used with good results. Once this is done, another tip is to place a layer of saran wrap, waxed paper, or even Monokote backing material on the glass, and gently smooth it down. When the glass is cured, peel off the plastic, and the glass will have a pretty nice surface with not much sanding required. Ta da!
_____________________________
Mike James RC Design and Building - www.nextcraft.com
