RE: making fuel
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> RE: making fuel
Page: <<   < prev  1 [2]
Login
RE: making fuel - 9/6/2004 5:41:12 PM
JPALPHA
Status: offline
Ed, Ross,
Could you tell me where can I get the ingredients
to mix my own fuel in Toronto/Ont. area?
JP
(in reply to Ed Smith)
       Post #: 26
RE: making fuel - 9/7/2004 12:53:24 PM
Ed Smith
Status: offline
JP, This could be an adventure for you.
If you are intending to buy small quantities it is a bit of a chore finding suppliers. Alcohol can be purchased in hardware stores. Look for 99% pure Methyl Hydrate. Synthetic oil such as Klotz can be purchased at Motor cycle stores. Decent hobby stores sell Sig castor oil. Nitro is a problem. I usually buy a gallon from the Klotz booth at the Toledo show.
There used to be a store in Markham called the "Winners Circle" I do not know if it still exists. You will have to dig around and find stores that cater to the performance motor cycle/Go kart crowd.
That is the best I can offer.
Ed S
(in reply to JPALPHA)
       Post #: 27
RE: making fuel - 9/8/2004 12:41:10 AM
Ross Kean
Status: offline
I agree with the above. Nitro may be available from speed shops or racetracks - methanol too. There are a variety of sources for oil but it can be surprisingly expensive. One solution for nitromethane, if you are making low nitro fuel such as 5% or less is to buy a gallon of 40% fuel from your distributor. By mixing it with your blend, you can use it to make 8 gallons of low nitro (5%) hooch which is perfectly acceptable for most 2-stroke sport flying. For low nitro mixes, this is likely cheaper than sourcing the nitro separately.
Ross
       Post #: 28
RE: making fuel - 9/8/2004 4:12:12 AM
JPALPHA
Status: offline
Ed, Ross,
Thanks for the information
I might try to look around to make fuel for my own
JP
(in reply to Ross Kean)
       Post #: 29
RE: making fuel - 10/28/2004 9:31:32 PM
transmission_dr
Status: offline
Everything you need to know about mixing percentages without any arithmetic.
http://www.rcuniverse.com/forum/Home_Brew_Buddy/m_2062693/tm.htm
_____________________________
Jerry Martire
       Post #: 30
RE: making fuel - 11/28/2004 7:07:01 AM
PhilNZ
Status: offline
Hi,
Lets take the quess work out of this ..
This is a fuel mix calculator in US and metric runs on a WINDOZE PC
If you use this and also use Acetone add this as EDL % 3 % for 2 strokes 5% for 4 strokes
http://www.birdgagesoft.com
winheli is the program, its better than all the guess work
Phil
(in reply to transmission_dr)
       Post #: 31
RE: making fuel - 11/28/2004 7:11:00 AM
PhilNZ
Status: offline
Hi
a correction to the WINHELI site
http://www.birdcagesoft.com
sorry
Phillip
(in reply to PhilNZ)
       Post #: 32
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU1
