RE: KMP Hurricane in detail    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: KMP Hurricane in detail
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: KMP Hurricane in detail - 1/28/2005 3:36 AM
hurricane527
Score: 100
Last Login: 10/6/2009
Status: offline
charliedelta
whats it fly like?? mine due to test fly this weekend weather here in the UK permiting.
ceejay
Hide Signatures
(in reply to bbuss)
       Post #: 201
RE: KMP Hurricane in detail - 1/28/2005 3:43 AM
DesertHucker
Score: 100
Last Login: 4/1/2013
Status: offline
Mine flies very smooth and glides for ever on the landings, think i need more flaps than whats in the manual.
be prepared for a long approach
_____________________________
Lawrie Goldfields Aeromodellers
www.gam.asn.au
Hide Signatures
(in reply to hurricane527)
       Post #: 202
RE: KMP Hurricane in detail - 1/28/2005 8:18 PM
BlueMax3
Score: 100
Last Login: 10/31/2005
Status: offline
For those who have added an antenna mast to this plane, how did you do it? What did you use?
Travis
Hide Signatures
(in reply to DesertHucker)
       Post #: 203
RE: KMP Hurricane in detail - 1/28/2005 10:33 PM
paladin
Score: 250
Last Login: 5/19/2013
Status: offline
Ok, guys. I'm getting ready to gt restarted on my IMP macchi 202 and was wondering what this covering material is (the stuff on the KMP Hurri). is it comercially available and from whom?
Joe
If it don't fly it wont ketch my eye.
Hide Signatures
(in reply to BlueMax3)
       Post #: 204
RE: KMP Hurricane in detail - 1/29/2005 3:41 AM
CharlieDelta
Score: 100
Last Login: 6/14/2011
Status: offline
ceejay
Mine has not flown yet either. Waiting for smooth west wind to show up in Southampton.
I have not fuel proofed it. With my 10% nitro fuel I think it will be OK - I'll let you know.
...few more pics showing my crude air system install. Its all new to me so I want access to all the parts.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to paladin)
       Post #: 205
RE: KMP Hurricane in detail - 1/30/2005 12:06 AM
Canuck1
Score: 100
Last Login: 5/15/2013
Status: offline
Well, some more progress on the Hurricane. The fuel tank has been added. The picture does not show all the foam packed around it. The batteries are also installed on the bottom under the fuel tank. There was lots of room down there. Throttle linkage is all done, all servo's are now in as well. I am still jigging the air system, have it just about sorted out. The cockpit is almost finished. The floor is epoxied, just waiting to spray it a light green colour. Pilot has been added as well.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
(in reply to CharlieDelta)
       Post #: 206
RE: KMP Hurricane in detail - 1/30/2005 3:46 AM
hurricane527
Score: 100
Status: offline
[image][/image][image][/image]
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Canuck1)
       Post #: 207
RE: KMP Hurricane in detail - 1/30/2005 3:59 AM
hurricane527
Score: 100
Status: offline
hi the previos pics should have come with words but i must have done something wrong cos they got lost!!!! so here are some more, photos are from the test flight's today of my YT/KMP hurricane, and all i can say is STUNNIN there arn't enough o's in smoooth to describe it, it needs lots of flap to get a nice descent rate, otherwise i can see it floating for ever, it does not need huge amounts of power, mine flies beutifully on an old but little used SC 108, using a custom built exhaust, 16x8 glass/nylon prop, 10% nitro fuel(it is cold and damp here) flaps 80 degs, no elevator trim used it just gently points its nose down and is easily controlled with the sticks to a nice flare and touch down, go finish them you will be very pleased you did.
Hide Signatures
       Post #: 208
RE: KMP Hurricane in detail - 1/30/2005 7:05 PM
Harigo
Score: 100
Last Login: 7/25/2012
Status: offline
I have finished my Hurricane but I am having problems setting up the throttle servo. I am using a Saito 150 inverted. The problem is the servo tray is above the fuel tank and the the engine's throttle arm is below. I have tried bending the control rod with a Z shape but I find that this makes the rod act like a spring and I do not have sensitive movements to adjust the throttle.
How have you all set the throttle servo up? A pic would help. Thanks
Hide Signatures
(in reply to mfranke)
       Post #: 209
RE: KMP Hurricane in detail - 1/30/2005 7:17 PM
DesertHucker
Score: 100
Status: offline
Have a look through this thread i think page 2 mount the servo on the engine mount under the cowl. I have used this method in 40deg c heat ok down under.
www.gam.asn.au
Hide Signatures
(in reply to Harigo)
       Post #: 210
RE: KMP Hurricane in detail - 1/30/2005 7:23 PM
DesertHucker
Score: 100
Status: offline
Page 5 has the throttle servo mounted on the engine mount and page 3 has a saito 120 mounted
www.gam.asn.au
Hide Signatures
       Post #: 211
RE: KMP Hurricane in detail - 1/31/2005 9:17 AM
Canuck1
Score: 100
Status: offline
Did some more painting. Painted up the cockpit and wheel wells green. I know the colours are not scale, but it will still look good.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 212
RE: KMP Hurricane in detail - 1/31/2005 5:36 PM
F86-Sabre
Score: 100
Last Login: 1/19/2011
Status: offline
try a flexible push rod (e.g. steel cable) and run it through a plastic tube.
Hide Signatures
       Post #: 213
RE: KMP Hurricane in detail - 1/31/2005 7:10 PM
paladin
Score: 250
Status: offline
Craig, what are you using for the panel lines? I used to us sharpe markers but the new formula is made to come off with alcohal.
Joe
Hide Signatures
(in reply to F86-Sabre)
       Post #: 214
RE: KMP Hurricane in detail - 2/2/2005 12:38 AM
Canuck1
Score: 100
Status: offline
Paladin
I used a perminent Steadler marker for my lines. They come in different sizes. I used the superfine tip. It has seemed to work good. I am not to sure on how fuel proof it is but I plan on clearcaoting anyways. I started the painting of the roundels using an airbrush last night. I got the yellow on and hope to get the blue on tonight.
Craig.
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 215
RE: KMP Hurricane in detail - 2/2/2005 5:50 AM
Canuck1
Score: 100
Status: offline
Got the blue painted on the lower side of the wing and on the fuselage.
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 216
RE: KMP Hurricane in detail - 2/3/2005 9:19 AM
Canuck1
Score: 100
Status: offline
Well I proceded with applying the white this evening. Did the botom of the wing, fuselage sides, as well as the white on the tail. I also applied blue to the upper portion of the wing. Tomorrow I plan on doing the red, on all roundels which should finish that portion, less the blue on the fin. Next will be the squadron markings, but presently I am not to sure of what colour to use. I have some documentation that states "Dark Sea Grey". I want them to stand out so maybe I will go with a lighter shade of grey.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 217
RE: KMP Hurricane in detail - 2/4/2005 6:35 AM
Canuck1
Score: 100
Status: offline
Well I managed to get the red applied this evening, as well as the last blue paint on the tail. All that is next is the squadron marking. Then it will be time to weather. I still need to add the scale exhausts to the cowling. Due to having my 2 stroke engine at 90 degrees, the starboard side will only have one exhaust while the port side will have the three.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 218
RE: KMP Hurricane in detail - 2/4/2005 8:51 AM
Canuck1
Score: 100
Status: offline
Another pic with it together on a couple of stools.
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 219
RE: KMP Hurricane in detail - 2/4/2005 5:23 PM
F86-Sabre
Score: 100
Status: offline
Hi Craig,
what type of paint are you using?
Hide Signatures
       Post #: 220
RE: KMP Hurricane in detail - 2/4/2005 6:48 PM
Canuck1
Score: 100
Status: offline
F-86
I am using Modelmaster paints. They cost about $4.00 for a small bottle. I mix it with Modelmaster thinner, and then airbrush it on. It seems to be working well. This is the model paint used on plastic models. I used the same paint on my Lancaster and after clearcoating have had no issues.
Craig.
Eat, Sleep, Fly
Hide Signatures
       Post #: 221
RE: KMP Hurricane in detail - 2/5/2005 2:12 AM
Canuck1
Score: 100
Status: offline
Did the squadron stenciling this afternoon. I think it turned out well. The stencils are a little dark, however some good weathering shoul take care of that. I have attached some before, during and after pics.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 222
RE: KMP Hurricane in detail - 2/5/2005 9:13 AM
Canuck1
Score: 100
Status: offline
I started playing with some weathering. I am using some old ceramic, water soluable paint. Seems to be working fine. The one picture with the cowl on, sure shows the difference that the weathering makes.
Craig.
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 223
RE: KMP Hurricane in detail - 2/6/2005 3:03 AM
Canuck1
Score: 100
Status: offline
Quickly put it together to have a look. It is starting to look like an old, well used Warbird.
Craig.
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 224
RE: KMP Hurricane in detail - 2/6/2005 10:07 AM
Canuck1
Score: 100
Status: offline
Worked on the exhaust tonight. They are mounted, painted, just need to add some weathering as well as the exhaust stains.
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
5.719RCU1
