RE: OMP Hybrid "My Build"    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: OMP Hybrid "My Build"
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: OMP Hybrid "My Build" - 10/10/2004 3:36 AM
Todd L.
Score: 100
Last Login: 5/13/2013
Status: offline
quote:
ORIGINAL: Crash90
If you look at the pic on the OMP website you can see that the front of the fuse is "open". In the pictures there doesnt appear to be much room to get the engine in and out. I was originally going to convert to a removeable cowl. Now that the fuse is built I can see that there is PLENTY of room to work.
The size of this thing is surprising, the fuse is as tall as if not taller than my 1/3 Sukhoi.
Really? That tall!! WOW..... I'm am thinking about getting one to assembel over the winter. I think I may sell my Wild Hare and use the DA 50 in it..... How many servo's used on the alierons?
Hide Signatures
(in reply to Crash90)
       Post #: 76
RE: OMP Hybrid "My Build" - 10/10/2004 8:15 AM
Crash90
Score: 100
Last Login: 8/22/2011
Status: offline
A total of 4 servos. Todd L. Did you see the pic of the rudder as compared to my Sukhoi? You can see by the hingeline that it is taller at the rear.
Hide Signatures
(in reply to Todd L.)
       Post #: 77
RE: OMP Hybrid "My Build" - 10/10/2004 9:47 AM
Crash90
Score: 100
Status: offline
Actually, when measured at the canopy, the Hybrid is 3" taller than the sukhoi. At the nose, They are the same height.
I wanted to do a "step by step" when building the wings, however once I got started it just went together to quick. I have my own method of installing shear webbing.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 78
RE: OMP Hybrid "My Build" - 10/10/2004 4:15 PM
Todd L.
Score: 100
Status: offline
quote:
ORIGINAL: Crash90
O yeah!! I sure did see the pic.... NICE! I know that the H9 Sukhoi had a nice sized rudder cuz I had one. Its lookin good so far Crash!
Hide Signatures
       Post #: 79
RE: OMP Hybrid "My Build" - 10/10/2004 8:59 PM
Rc-Warehouse-USA
Score: 105
Last Login: 12/22/2011
Status: offline
What is the inside width measurement of the engine compartment? I am trying to figure out if my ZDZ 80 will fit?
Hide Signatures
       Post #: 80
RE: OMP Hybrid "My Build" - 10/11/2004 7:32 PM
STLPilot
Score: 100
Last Login: 12/5/2008
Status: offline
5.5" tall by 4.5" wide at the firewall. Total engine compartment height inside is about 8.75" at the head location.
_____________________________
Here At The Wall
Hide Signatures
(in reply to Rc-Warehouse-USA)
       Post #: 81
RE: OMP Hybrid "My Build" - 10/12/2004 4:13 PM
AFSalmon
Score: 100
Last Login: 12/8/2011
Status: offline
Actually the engine inserts and removes from the front opening. It is easily tilted in and out. Obviously it's much easier (like with any model) to completely install the motor and muffler arrangement before doing the covering so you know where to trim out for the exhaust system. Plus you want to do this before you install the upper and lower cowling sheeting.
Glad the wings are going together great Crash, you'll be flying soon......hopefully before the weather gets too bad! Had mine out this weekend killing mosquitos with my smoke system.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
(in reply to STLPilot)
       Post #: 82
RE: OMP Hybrid "My Build" - 10/13/2004 7:49 AM
Rc-Warehouse-USA
Score: 105
Status: offline
Speaking of smoke. I am getting the hybrid can you give me the smoke system that you recommend installing in the Hybrid? And some installation experiance?
Thank you
Hide Signatures
(in reply to AFSalmon)
       Post #: 83
RE: OMP Hybrid "My Build" - 10/13/2004 3:56 PM
AFSalmon
Score: 100
Status: offline
Well I went cheap mostly to keep the weight down. I went with the Dubro smoke valve and used crank pressure from the back of the DA 50. A tap is already provided by DA and you just have to put the bleed tap (8-32 threads) into the hole. Use a one-way check valve between the crank and the smoke tank and run both lines through the valve per the Dubro instructions. Use two "T" fittings in the lines to fill the tank. One is the fill and the other is the vent. The smoke valve must be in the off position to avoid pumping fluid into the exhaust while filling! Use a standard servo preferably on a proportional channel so you can regulate the flow amount with endpoint adjustments. Everything but the servo is up in the engine box area. I mounted the servo back next to the throttle servo behind the wing tube just to keep separation between radio gear and the ignition box.
Ohio Model Planes
Hide Signatures
       Post #: 84
RE: OMP Hybrid "My Build" - 10/16/2004 6:20 AM
Rc-Warehouse-USA
Score: 105
Status: offline
How is the build progressing!!!
Hide Signatures
       Post #: 85
RE: OMP Hybrid "My Build" - 10/16/2004 8:04 PM
Crash90
Score: 100
Status: offline
Sorry for the delay. I got my first foamie and I have been having too much fun. I havent done much building. I will get back on it tonight and post progress.
Hide Signatures
       Post #: 86
RE: OMP Hybrid "My Build" - 10/18/2004 4:56 PM
on-your-six
Score: 100
Last Login: 2/16/2012
Status: offline
crash90 did you build the 1/4" stick fuse sub frame over the plans and then glue the side sheeting on to the sub frame or did you glue the 1/4" sub frame direct on to the sheeting
it looks to me that there is no way to get both sides the same with out building the sub frames
first - by building the subframes first all you would need to do would be cut and sand the sheeting to fit the frame - i dont want to cut the plans up if i do not need to
thanks for all the info on your build
Hide Signatures
       Post #: 87
RE: OMP Hybrid "My Build" - 10/18/2004 5:28 PM
AFSalmon
Score: 100
Status: offline
You build the sheeting and glue the framing to that. It's easy, all you do is mark the vertical lines on the sheeting (guides are already provided on the plans, and glue your framing on. Piece of cake.
Ohio Model Planes
Hide Signatures
(in reply to on-your-six)
       Post #: 88
RE: OMP Hybrid "My Build" - 10/18/2004 6:32 PM
Crash90
Score: 100
Status: offline
Correct. The locations for the vertical 1/4 x 1/4 balsa sticks are extended. When you lay the sheeting in place you can use a straight edge to mark the sheeting.
So to answer your question I glued the 1/4" sub frame direct on the sheeting.
Hide Signatures
       Post #: 89
RE: OMP Hybrid "My Build" - 10/21/2004 4:52 PM
on-your-six
Score: 100
Status: offline
hey crash90 how is the build going
i have one of these kits and have the
fuse sides done and about ready to
assem them togeather
i am putting a mvvs 58 in mine i
picked it up at a local lhs
happy flying
Hide Signatures
       Post #: 90
RE: OMP Hybrid "My Build" - 10/21/2004 7:35 PM
Rc-Warehouse-USA
Score: 105
Status: offline
What kind of thrust angle are you guys building into the Hybrid? My hybrid should be arriving any time now!
Hide Signatures
       Post #: 91
RE: OMP Hybrid "My Build" - 10/22/2004 9:09 AM
Crash90
Score: 100
Status: offline
I have worked 15 hour shifts for the last 3 days. Haven't done much building. The left wing is almost done. It went together well. I promise that I will begin posting lots more pics soon.
Hide Signatures
       Post #: 92
RE: OMP Hybrid "My Build" - 10/22/2004 9:28 PM
AFSalmon
Score: 100
Status: offline
Typically 2-3 degrees right thrust is standard on single engine planes. Some guys run zero offset and mix right rudder with throttle using a curve to compensate for engine thrust abd torque. I've seen pattern guys do this which permits a truer flying airplane.
Ohio Model Planes
Hide Signatures
       Post #: 93
RE: OMP Hybrid "My Build" - 10/27/2004 4:58 PM
on-your-six
Score: 100
Status: offline
hey crash 90 i have my fuse done with motor mounted - how are you doing with your build
you build a lot faster than i do
i mounted a mvvs 58 with a pitts muffler on mine - it sure is a pain to get a muffler that is wider than the fuse in this plane - if the fuse was an inch wider in the front it would be a lot better
i ended making the bottom of my cowl removable - it was the only to get the motor & muffler
to fit and to be removable - i will start on my tail feathers this week
hope your build is going good
happy flying
Hide Signatures
       Post #: 94
RE: OMP Hybrid "My Build" - 10/27/2004 6:14 PM
Crash90
Score: 100
Status: offline
Well, I don't have my motor yet. Hopefully I can get it in without too much trouble. I have the fuse and tailfeathers complete. The left wing is almost done. I haven't had a chance to work on it for a while. Hopefully this weekend I will get back to it.
I am short 1 main spar. My LHS doesn't have one. I am looking for a place that will ship just 1 piece. Not having much luck. So I can't begin the other wing yet.
Hide Signatures
       Post #: 95
RE: OMP Hybrid "My Build" - 10/27/2004 7:52 PM
AFSalmon
Score: 100
Status: offline
If I made the fuse wider, it wouldn't be a "Hybrid" anymore. Might as well just do a big full figured lady! LOL We put the inverted pitts mufflers on the DA 50 no problem. See the pics in the manaul. No problem installing or taking out. You still have to make the cutouts on both sides for the mufflers ends but after that, you just slide the muffler in, slide the engine in on top of it and bolt together through the side opening.
Ohio Model Planes
Hide Signatures
       Post #: 96
RE: OMP Hybrid "My Build" - 10/29/2004 5:00 PM
on-your-six
Score: 100
Status: offline
hey crash90 here is where i am at on my kit
its time to start the tail feathers
you were correct when you said that this plane is
big
tg
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 97
RE: OMP Hybrid "My Build" - 10/29/2004 5:05 PM
Crash90
Score: 100
Status: offline
Looks good. I am finished with the left wing. Still looking for a spar before I can start the right one.
Hide Signatures
       Post #: 98
RE: OMP Hybrid "My Build" - 10/29/2004 10:58 PM
AFSalmon
Score: 100
Status: offline
tlg1, me likes the look or your hangar. It's so clean......and all those airplanes! Nice touch on the removable bottom cowling too.
Ohio Model Planes
Hide Signatures
       Post #: 99
RE: OMP Hybrid "My Build" - 10/30/2004 3:54 AM
Rc-Warehouse-USA
Score: 105
Status: offline
Nice work! Thanks for the idea of a removable lower cowl. I am planning that with my ZDZ80
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
