Acceptable EGT increase due to FOD screen?
Tower Hobbies
Logged in as Guest
  Printable Version
JetCat P-120 - RTR
Seller:  ghost_rider
Details:   $2,350.00   |  10/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> SimJet Turbine Direct Support >> Acceptable EGT increase due to FOD screen?
Page: [1]
Login
Acceptable EGT increase due to FOD screen? - 9/7/2004 6:21:31 AM
Phil Cole
Status: offline
Is there any guidance on what would be an acceptabe increase in EGT due to the fitting of a FOD screen to a 1200 SP
I made one from a tea strainer with fairly fine mesh.
At idle, EGT increased from 580 C to around 600 C. At 160,000 RPM, EGT increased from 650 C to 680 C or maybe a bit more. Ambient at the time was well into the 30s, maybe even 40 C.
I can look around for a coarser mesh, but I suspect there's always going to be some amount of EGT increase when the screen is installed.
< Message edited by Phil Cole -- 9/6/2004 10:22:07 PM >
       Post #: 1
RE: Acceptable EGT increase due to FOD screen? - 9/7/2004 12:51:41 PM
KevinM
Status: offline
Hi Phil,
Ideally, of course we'd like to see no rise at all. In reality, however, it may take a mesh that is so coarse that it provides little to no protection at all. You should be okay with the screen you've got, but it's probably still worth trying something a hair coarser to see how much of that increase you can shave off.
_____________________________
Kevin McLeod
(in reply to Phil Cole)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.203RCU3
