speed sensor
Tower Hobbies
Logged in as Guest
  Printable Version
BUY A NEW JETCAT MOTOR AND GET FREE 8611A'S!!!!
Seller:  JTs Hobby
Details:   $2,595.00   |  11/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> speed sensor
Page: [1]
Login
speed sensor - 8/2/2002 4:14:27 AM
kelly vallee
Status: offline
Does anyone know how to set up the speed sensor for only max speed setting. I have one and I'm going to set it up, but the only thing I want is the max speed. Do I have to calibrate the sensor. Kelly
       Post #: 1
speed sensor - 8/3/2002 8:53:48 PM
mr_matt
Status: offline
Hi Kelly,
You just install the sensor per the instructions and plug it in.
MAX LIMITAIRSPD (in the limits menu) is always active, just change that value to whatever you want and you are in business
If you are using 2 channel mode, then do the following,
In the limits menu, set
SPDCTRL SW0 ACT to DISABLED/NONE
and then set
If you are using one channel mode you don't have to do this.
As for calibration, you can do it if you want it is not mandatory.
Sorry for the delay in answering.
< Message edited by mr_matt -- Aug 3 2002 4:01PM >
_____________________________
Matt
JetCat rep
(in reply to kelly vallee)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.203RCU3
