Adding Gasoline To Methanol
Tower Hobbies
Logged in as Guest
  Printable Version
MT FLEX HEADER & CANSTER For MT50,57, 62, Brillelli GT 366, DL50,DA50,G62 ENGINES
Seller:  mistydee0
Details:   $149.00   |  7/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Adding Gasoline To Methanol
Page: [1]
Login
Adding Gasoline To Methanol - 8/2/2002 10:51:29 PM
rvd
Status: offline
I know there are some people doing this for added horsepower but what is the trick to getting the gasoline to mix with the methanol...
       Post #: 1
Adding Gasoline To Methanol - 8/3/2002 5:24:31 AM
downunder-RCU
Status: offline
Gasoline isn't added to gain HP, you'll actually lose a little. It's usually added for greater economy because the needle has to be wound in to get the correct mixture. The engine may run a little hotter though which is why some people add it in extremely cold climates. I've never heard of any problems getting it to mix but if you try it then make sure you add extra oil as well to keep the oil % the same.
(in reply to rvd)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU1
