Tower Hobbies
Logged in as Guest
  Printable Version
Airworld BAe Hawk - ARF
Seller:  rambat1
Details:   $17,500.00   |  10/11/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >>
Page: [1]
Login
- 8/2/2002 11:25:43 PM
Nuker
Status: offline
What about a work table/ plane / heli setup area.
Also permanent tie downs for the planks
Hover area for heli training/practice
C/L designated area
Car track
Might not want E-W runways otherwise, depending on wind either take-off or landings early morn or late aft will be bright
Since you're going whole hog here, why not wiring and speakers for a PA system (don't need to peave PA there all the time but allow easy plug in.
Clean water supply.
Sun shelter
Safely designed spectator area
Safe place for the kids
Hope this helps
Nuker
_____________________________
Lighten up, Life is waaaay too short!!
       Post #: 1
- 8/2/2002 11:43:35 PM
rc-sport
Status: offline
I disagree with Nuker on the EW runway. The runway should run EW and the flight line should face North. Up in Washington the sun will allways be behind you and the prevailing wind there is from the west. Don't forget the potties.
(in reply to Nuker)
       Post #: 2
- 8/3/2002 12:09:07 AM
Elwood
Status: offline
How about a map of the entire property including rodas and the gun clup showing the direction of fire? If it is set up wrong, it could give new meaning to Shot Down!
Born in the U.S.A.......Not quite as long ago as Art!!!!!!!
(in reply to Nuker)
       Post #: 3
- 8/3/2002 12:22:21 AM
seafury_fb11
Status: offline
I like the idea of having separate flight lines. If I had my choice of any configuration, I would have the pits in the middle, with the runway on one side and the helis flying on the opposite side of the pits.
In the pit area, some shade trees would be nice so that folks don't have to bake in the sun all day. Also some descent restroom facilities. And if you are going all out, maybe a hotdog stand or at least some vending machines.
As mentioned already, some good work benches.
An engine break-in area away from the pits.
Russ.
You're just jealous because the voices don't talk to you.
(in reply to Nuker)
       Post #: 4
- 8/3/2002 4:36:25 AM
Nuker
Status: offline
Disagree??? I'm crushed. Actually one of our local fields has that config (E-W) and that's one of the probs. It was resolved my making NW=SE and the sun minimized. (at least kept to the periphy)
Of course you could always get sunglasses
Man now I feel like I have to upgrade our field. Some great ideas
(in reply to Nuker)
       Post #: 5
- 8/3/2002 7:18:11 AM
bdphil
Status: offline
Handicap parking close to the pits.
I had a heck of a time rolling 100+ feet through the grass with a GP Extra (60 size) balanced on my lap. This year the club did make provisions, and it has made things so much easier.
Ben
(in reply to Nuker)
       Post #: 6
- 8/3/2002 9:45:49 PM
bdphil
Status: offline
The only real problem that I had was that there is a drainage ditch along the road at our field. Everyone just parks along the side of the road before the ditch, then there are 2 waqlking bridges across. Well, the bridges are too narrow for a wheelchair so I had to go around the ditch. This year they put a length of culvert pipe in the ditch and backfilled part of it so I can just back my truck across and I'm right there. Makes everything much easier.
Most fields probably don't have a situation like this, but it doesn't take much to make things accessible.
Ben
(in reply to Nuker)
       Post #: 7
phone home - 8/4/2002 6:04:15 AM
Tapio
Status: offline
Are you guys lucky enough to have phone acess also? This would be good for emergencies. Also you could set up a web cam for the club website to see whos flying , a link to the portable anemometre would top off the list. Ive seen a frequency board that stated even channels only. I'm assuming this was done to avoid frequency conflict with another rc site ( odd ch ) that would be too close for radio interference. Perhaps you could do this with the heli guys, them odd ch's, planes even. I can see the protest already!!!!
(in reply to Nuker)
       Post #: 8
- 8/4/2002 1:59:14 PM
simo_aus
Status: offline
for the boats. A nice round or square pond with all sides access would be great for power and sailing. Not sure where to put it....Try to keep it as free of water grass and weeds as possible.
From what I've heard a rolled grass circle is best for control line.
Simon the flying aussie.
[url]www.geocities.com/simons_rc_page[/url]
(in reply to Nuker)
       Post #: 9
- 8/4/2002 11:22:46 PM
GalenB
Status: offline
Both of the fields that I fly at in the Puget Sound area have E-W runways and they both work very well. However, the one that has the pilot facing north is far superior to the one where the pilot faces south. So if at all possible you should orient the pilot stations on the south side of the field.
My only other suggestion is to make a playgound for the kids. RC Flying is a family activity and having a safe place for the kids to play while a parent flies is invaluable. Also having an area with picnic tables, etc. also adds to the family friendly environment.
Cheers!
(in reply to Nuker)
       Post #: 10
- 8/4/2002 11:41:06 PM
Chris 540
Status: offline
Theres 1 club I know that has a phone number you call and it will tell you the current wind speed and direction at the field. It also gives the same info from an hour ago.
(in reply to Nuker)
       Post #: 11
- 8/5/2002 7:10:24 AM
Tapio
Status: offline
Wow 540, I thought my buddies and I were looking into the year 2015 when we "joked " about this. Wonder how many clubs have a forum on their web site to discuss who's going that morning etc.. Our rc car club had a Bravenet forum and it was so handy.
(in reply to Nuker)
       Post #: 12
- 8/5/2002 7:40:53 AM
GalenB
Status: offline
[QUOTE]Originally posted by fitenfyr
Galen,
BTW where do you fly? Flaming geyser and Marrymoore?
coming.
[/QUOTE]
I a fly little and mostly instruct at Marymoor, and do most of my personal flying at Cascade Family Airpark in Snohomish.
< Message edited by GalenB -- Aug 5 2002 2:46AM >
Cheers!
(in reply to Nuker)
       Post #: 13
- 8/5/2002 9:09:19 AM
recon-RCU
Status: offline
Here is my (dream) field. The pic is rather old, there is actually a bit of green grass there now. No one flys helis or rarely control line, but you can see the attempts of control line circles. Our club is trying to stay as far away as possible from surface r/c for safety reasons.
[URL=http://www.****/clubs/medhatrc/images/rcfield.gif]Field Pic[/URL]
Medicine Hat, Alberta, Canada
[url]http://www.medicinehatrcers.org[/url]
(in reply to Nuker)
       Post #: 14
- 8/5/2002 10:02:31 AM
GalenB
Status: offline
Hmmm.... Haven't been there yet. Private full scale field?
[/QUOTE]
It's a private field that is used by both full scale and RC flyers. The only full scale flying there is pretty much done by the owners as he has something like 14 planes scattered around the puget sound area...
I like it because you face north and it is kid friendly and kid safe.
Cheers!
(in reply to Nuker)
       Post #: 15
- 8/5/2002 10:13:40 AM
recon-RCU
Status: offline
What saftey reasons are you concerned with for surface and air at the same place? [/QUOTE]
Just incase some one comes is a r/c car with an aircraft radio, and not familiar with frequency control, they drive their car and a plane gets shot down. Also not a safety reason but: If someone is driving a couple hundred dollar car with an aircraft radio and someone is flying a multi thousand dollar plane, you can guess the rest...
(in reply to Nuker)
