Frost_
VA, USA Status: offline
Not a rumor, just BS..... LOOK at the truck... what do you see?? If you are still scratching your head I'll let you in: The engine is on the opposite side as the Savage, so is the tank. Also the engine sits low to the chassis so you can use a starter box, unlike the sav... The shocks are shorter.... That comes form the first glance; I wanna see pix w/no body. BRING ON THA NUDIES.
_____________________________
http://www.fastrides.com/forums/5486/ShowPost.aspx http://www.fastrides.com/forums/4178/ShowPost.aspx
