Fred Marks
Joined: 8/5/2003 From: Frederick, MD, USA Status: offline
quote:
ORIGINAL: Slocan Floats I crashed and bent my Kokam battery packs today , can I staighten them and will they be safe ?There is no bheat and the voltages is up where it should be. See picture.[image][/image] The integrity of your pack has clearly been compromised. It would be unwise to continue use of the pack. To dispose of the pack, please observe the following : 1. Store the pack in a safe area where no flammable materials are present. A metal or ceramic storage container with a cover is best. A closed charcoal grill is a good storage place until you have neutralized the cells. 2. Place a light load on the cells via series connected 12V light bulb(s) or a motor and check voltage occasionally to see that voltage goes well below 2.5V per cell. This is a very important step as a charged cell has tremendous stored energy. 3. With voltage depleted, and working at the charcoal grill, use a fresh # 11 hobby knife blade as you would a scalpel to make a small incision in the edge of each cell. Cut lightly as if cutting a tummmy just over an intestine! This is so that the plates are not penetrated. 4. Place the cells in a container of salt water for at least 24 hours. Then you may dispose of the cells in the trash. 5. Contact Customer Service at FMA Direct with a copy of your purchase information to receive a personal courteous solution to your loss. 6. When you replace the pack, be certain to provide a protective sheath of FMA IMPAD around it. Exposed lithium packs can be risky. You risk damaging the pack in the event of a crash which reduces your investment security at the same time as it increases the risk of fire. I still crash on occasion so my plan for protecting the exposed packs is to wrap them in a super impact absorber from FMA Direct called IMPAD. It is packaged in 12" x 6" sheets and can protect an egg from cracking when the egg is dropped on to IMPAD at four feet off the ground. When pack heat is not an issue (e.g. you are not stressing the pack in the application), the pack can be wrapped in an IMPAD pouch using a simple Velcro strap to hold the pack inside the pouch. When pack heat is an issue, IMPAD end-caps can be made to allow air flow through the cells in the pack while protecting it from a blunt force. The new Skyvolt packs from FMA Direct allow air to flow between the cells for maximum performance and longevity. For either technique, I used clear shipping tape to form the pouch or caps. (To view pictures of a pack so protected click below and open Page 1, Post #6) http://www.rcgroups.com/forums/showthread.php?t=381477
< Message edited by Fred Marks -- 9/16/2005 5:19:18 PM >
_____________________________
Electroman
