RE: Welcome to the FMA Direct - Kokam LiPo Support Forum
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: Welcome to the FMA Direct - Kokam LiPo Support Forum
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: Welcome to the FMA Direct - Kokam LiPo Support Forum - 3/26/2006 1:04:15 PM
Greg Covey
Status: offline
Hi Frank,
Your assumption about running two Viewer applications at the same time is correct.
_____________________________
Visit my Web Hangar at www.gregcovey.com/rc.htm
(in reply to fvigg)
       Post #: 126
RE: Welcome to the FMA Direct - Kokam LiPo Support Forum - 5/4/2006 1:00:19 AM
Nelectric
Status: offline
Hello, any news on when the 4.800 packs will be available? , will you have Balance Pro HD packs in 5S configuration in that capacity? 15 or 20 C? Thanks. Nelson.
(in reply to fvigg)
       Post #: 127
RE: Welcome to the FMA Direct - Kokam LiPo Support Forum - 5/4/2006 9:59:09 PM
Greg Covey
Status: offline
Hi Nelson,
We are changing Lithium cell vendors and will be offering many new capacities and sizes very soon with favorable pricing. In the range you mention, we will have a 5000mAh pack in 2s to 6s sizes in the BalancePro HD line.
Regards.
(in reply to Nelectric)
       Post #: 128
RE: Welcome to the FMA Direct - Kokam LiPo Support Forum - 5/4/2006 11:25:26 PM
Nelectric
Status: offline
Hi Greg,
great news, (mainly if at better pricing they meet your higher standards and keep being the best in the market..), would be great to know when so we can plann our future projects. Thanks for the information.
Nelson
(in reply to Greg Covey)
       Post #: 129
RE: Welcome to the FMA Direct / Lithium Power Solution ... - 5/5/2006 12:51:16 AM
Nomadic
Status: offline
Please decipher the following description of a cellpro pack. In particular " (15C / 90%) " & "15C, 11C/140 degrees. Thanks
Cellpro Kokam 1250mAh, 3-cell series (11.1V), heatshrunk with Deans Ultra connector, super high discharge (15C / 90%) -- Size: 80mmH x 42mmW x 17mmT, Weight: 117 grams, Ratings: 15C, 11C/140 degrees F, Outputs: 11.1V Nominal, 1250 mAh.
(in reply to RCadmin)
       Post #: 130
RE: Welcome to the FMA Direct / Lithium Power Solution ... - 5/5/2006 1:10:36 AM
Greg Covey
Status: offline
Nomadic,
That's a good question. I'm surprised more people don't ask it.
The old ratings method was seen as something like your first example; 15C / 90% It meant that at a 15C discharge rate (or 15 times the pack capacity C) you would still get 90% of the stated capacity. This older rating scheme focused on the capacity left in a pack at a high discharge rate and turned out not be be a critical factor in maintaining cycle life or longevity of the pack. In those days, most vendors (including FMA) had not documented the effects of temperature, cell balance, and discharge rate on the Lithium pack life span.
Today, the new rating scheme looks like this; Ratings: 15C , 11C/140°F , Cell Rating Spec
The first number, 15C, is the maximum discharge current that the cell will handle without puffing, catching on fire, or generally destroying itself.
The second numbers, 11C/140°F, means that the cell can truly be continuously discharged at 11C without loss of cycle life because it remains at or below 140°F. In a multiple cell pack, the inner cells will be about 10°F hotter or 150°F which is ok. The Rule-Of-Thumb is that this second set of numbers is about 70% of the highest C discharge rating without puffing. There are exceptions to this rule but it works for most manufacturers cells.
The last "Cell Rating Spec" is a hyperlink to the information in chart form that plots all the data taken during the cell qualification testing. As FMA is about to release many new cells from multiple manufacturers, the Cell Rating Spec will provide a consistent and more appropriate method for rating the discharge capabilities of Lithium cells.
< Message edited by Fred Marks -- 5/5/2006 2:28:30 AM >
(in reply to Nomadic)
       Post #: 131
RE: Welcome to the FMA Direct / Lithium Power Solution ... - 5/12/2006 11:53:32 PM
Numthums
Status: offline
Hi,just a question for anyone who might be able to help me out.
I just bought a cellpro charger and 3c lipo with 3mm connector on it I also bought the 3mm polarized header with 2 pins should I solder my speed controller leads directly to these pins on the header or is there another method of connection? thanks.
       Post #: 132
RE: Welcome to the FMA Direct / Lithium Power Solution ... - 5/16/2006 1:14:43 AM
Greg Covey
Status: offline
Yes, that is the most common way to do it. If you don't have any shrink tubing to cover the soldered joint, use some tape to cover it up and keep things from shorting out.
(in reply to Numthums)
       Post #: 133
RE: Welcome to the FMA Direct - Kokam LiPo Support F... - 6/6/2006 5:49:18 PM
Nelectric
Status: offline
Hi, anybody know where i can still get a 3S 2000 15C Cell Pro pack? i know they are discontinued but i need only one to complete a 10S2P 4000 pack.. Thanks in advance.
Nelson
       Post #: 134
RE: Welcome to the FMA Direct - Kokam LiPo Support F... - 6/6/2006 9:04:24 PM
Greg Covey
Status: offline
Nelson,
Hobby Lobby still has a 4-cell 2000mAh pack in stock here. You could remove one cell and keep it for a spare.
It looks like Horizon Hobby still has them in stock here.
Click to see fullsize image.
Click for fullsize
       Post #: 135
RE: Welcome to the FMA Direct - Kokam LiPo Support F... - 6/6/2006 10:31:17 PM
Nelectric
Status: offline
Thanks a lot Greg! I`ll go for it.
Nelson
       Post #: 136
RE: Welcome to the FMA Direct - Kokam LiPo Support Forum - 3/31/2008 10:49:03 PM
dbateman
Status: offline
Who handles Kokam batteries? I'm finding with close to three years of operation in my Aeronaut Panther that they are the best for all around performance coupled with longevity. Doug
(in reply to fvigg)
       Post #: 137
RE: Welcome to the FMA Direct - Kokam LiPo Support Forum - 4/7/2008 7:59:55 PM
areeves1950
Status: offline
hi
I am new to all this and learning, i hear the cellpro 4s is the best lipo charger. I want to buy a battery off ebay from batteryworld 123 they have jst hx 4pin balance connector
will the cell pro 4s charge and balance this battery is there a special connector i have to buy... also i am interested in a123 packs....
any info will help
alan
< Message edited by areeves1950 -- 4/8/2008 4:47:43 AM >
       Post #: 138
RE: Welcome to the FMA Direct - Kokam LiPo Support Forum - 6/1/2008 6:40:42 AM
Sawacs
Status: offline
Disregard.... Found the answer..
"Face Piles of Trials with Smiles"
AMA 219178
(in reply to areeves1950)
       Post #: 139
RE: Welcome to the FMA Direct - Kokam LiPo Support F... - 10/4/2008 2:38:58 PM
