hypersoniq
PA, USA Status: offline
I ran an attempt at MotoCalc... with some dimensions from the web for the GWS55 unit... In-flight Analysis - BlueCor Angel F-18 (Twin GWS EDF55-300H) 1000ft above Sea Level, 29.92inHg, 68°F Motor: GWS 300H; 3860rpm/V; 0.7A no-load; 0.37 Ohms. Battery: Thunder Power TP2100; 8 cells; 2100mAh @ 3.7V; 0.022 Ohms/cell. Speed Control: Castle Creations Sprite 25; 0.0025 Ohms; High rate. Drive System: GWS EDF55-300H; 2 motors (parallel); 2.17x4.49 (1in hub); (Pcoeff=0.22; Tcoeff=0.46). Airframe: BlueCor Angel F-18; 275sq.in; 35.3oz; 18.5oz/sq.ft; Cd=0.043; Cl=0; Clopt=0.37; Clmax=0.74. Stats: 243 W/lb in; 62 W/lb out; 26mph stall; 37mph opt @ 33% (34:48, 124°F); 827ft/min @ 14.6°; -607ft/min @ -10.7°. I must have entered something wrong regarding the model data (probably airfoil etc...) When I calculated twin 480's with a slightly larger span/area it spit out to speed of 117mph... That just didn't seem right to me... 2 GWS edf55-300H fan units with motors @$16 each, might be worth a try... If it's extremely weak, they can always find a home on a butt-ugly foam "combat" delta...
_____________________________
There are 10 kinds of people in the world... Those that understand binary and those who don't.
