Chris300s
MI, USA Status: offline
I have a lot of time one them. I've built 4 with ST 1.4's, Moki 1.8's and 2.1's. I think that they're a great deal of fun. Out of the 4 I have never had to add lead to balance them, nor have I had a problem with them being too tail heavy. My current setup: Moki 2.1 with custom radial mount swinging a Zinger 20x10. Bisson muffler, Varsane pump and tank located on the CG. Hitech 8 ch. Supreme receiver, Duralight 1200 Mah 6v. pack, Futaba (3) 9304's (2) Hitech digitals and a MK elevator bell crank. It weights 12 lbs, torque rolls at 1/3 throttle, has explosive vertical and Harriers better than the majority of 40% planes. Recommendations for it: O.S. 1.6 or Moki 1.8 instead of the 2.1 (there is such a thing as too much power). If you're running a pumped engine (OS, Cline regulator on Moki's...) I recommend sliding the tank back to the cg. There are two locator plates for the wing, make doublers for them as mine wore the holes open. I've worn out the Hangar 9 C/A hinges so replace them with "Klett" type and pin them. Cap's are excellent performers in the 3D arena due to their excellent tail group. They don't "groove" like Extra's will but then again Extra's don't get "wild and crazy" like Cap's do.
