RE: AKM SU-27 Flanker-Does Look Good
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: AKM SU-27 Flanker-Does Look Good Page: <<   < prev  35 36 37 38 39 40 [41] 42 43 44   next >   >>
Login
RE: AKM SU-27 Flanker-Does Look Good - 1/15/2007 6:16:14 PM
bob27s
Status: offline
Dont try to over think this one on the prop too much Many people do. Also worth while to forget a bit about the math aspect of things (rpm x pitch is not always indicative of forward velocity). And forget static thrust. This means absolutely nothing (very little at best) unless you are hovering or starting a take-off roll. Dynamic thrust is a different animal. Some of those concepts have meritt and are useful, but for what we are doing here.... go with what is suggested.
General oversimplified explaination ....
small diameterxhigher pitch = speed, small frontal disk area is less drag - this is for speed performance. Sometimes at the expense of a longer take-off run (slower aircraft acceleration), but not always if engine rpm increases enough to overcome the reduced blade area. (example - This is why a QM40 turnign a 7x8" diameter prop at 25,000 is quicker than a Q500 turning a 9x8" diamter prop at 20,000 - and by reason that the airframe can make use of this prop)
big diameterxless pitch = slow,low speed thrust - larger disk area is drag - slows plane down, but you get better take off performance, sometimes better vertical. Yes more efficient, but the added drag of the larger prop disk sometimes eliminates that advantage. If the plane is going to be slow to start with, sometimes a bigger diameter prop is indeed the way to go. (works sorta like gearing in a truck or car)
The key with any engine, especially one with a tuned exhaust, is selecting a prop that allows the engine to run at its best power rpm. With a tuned exhaust, you have to prop to match the tuned rpm of the system.
And, something to remember for all 2c engines - more rpm represents more fuel burned per minute, which represents more power being produced. Clearly, and engine turning a 12x6 at 15,000 rpm is producing more power than another engine turnign that same prop at 13,000 rpm. just an example. (engine must by design be capable of achieving the performance).
For the Jett 90L engine, you want to target between 13,000 and 15,000 peak ground rpm. A 12x6 will hit or exceed 14,000 rpm easily. So it is the baseline prop. It can turn a variety of props. Anything from an 11x6 to a 13x6 is fair game. Can turn up to a 13x8 or 14x6 (for scale or aerobatics) by using the torque version jett-stream or a turbo-jett muffler which is tuned for lower rpm use (12-13K rpm or so).
For the 90LX, the target ground rpm is 14,500 or higher. Higher is better. A 10x10, 11x7 or 11x8 is ideal. Also works great with a 12x6, and 11x9. On this engine we baseline an APC 11x8 at around 15,000 rpm.
With either engine, you can expect the engine to unload nicely in the air, upward of another 1000-2000 rpm in level flight.
Prop selection also has to be based on the application and desired flight characteristics, and requires some experimenting depending on your aircraft and performance desires. A super clean 60 size, 7 lb pattern ship with retracts may require a different prop selection than say a fixed gear 9 lb F-14 Tomcat.
What you will find described here by myself and many in the form are prop suggestions representing some of that real world trial-and-error testing.
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to Steelie)
       Post #: 1001
RE: AKM SU-27 Flanker-Does Look Good - 1/19/2007 11:52:12 PM
sticktickler
Status: offline
Question for any of you guys that have already built this. Where the heck do you buy Spring Air Retracts I do a search and get mattress companies and is the Robart 521W1 a direct repayment for it? And why are you guys NOT using Oleo struts wont they fit up inside?
(in reply to bob27s)
       Post #: 1002
RE: AKM SU-27 Flanker-Does Look Good - 1/20/2007 1:02:22 AM
jetpilotrich
Status: offline
http://www.retracts.com/
OLEOS WEIGH A TON!
RICH
(in reply to sticktickler)
       Post #: 1003
RE: AKM SU-27 Flanker-Does Look Good - 6/4/2007 6:17:40 AM
jodini
Status: offline
This is sort of a shameless bump, but I read this forum so often I thought I would put some pics on here!
Haven't done the maiden yet, but hopefully this week!
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to jetpilotrich)
       Post #: 1004
RE: AKM SU-27 Flanker-Does Look Good - 6/4/2007 6:26:58 AM
Sparhawk
Status: offline
Good luck with the maiden jodini. I like the scheme, like a modified version of the Mig-29 without all of the zig-zags that are on mine. You will find that you will have no problem seeing it in the air too. Great visibility.
Take off, trim, pour the coals on and hang on for the ride!
Spar
Oh great are the days my landings = my take-offs....!
Revver Bro #158
(in reply to jodini)
       Post #: 1005
RE: AKM SU-27 Flanker-Does Look Good - 6/10/2007 4:14:35 AM
grumpE
Status: offline
Well I hate to steal Jodini's thunder but his beautiful Su 27 has flown!!!
Here are some pics. Much bigger versions can be found at www.omahawks.org Go into the gallery and open the Misc 2007 file.
Joe did a wonderful job on his with help from a VERY talented and skilled friend, Dean Copeland. Dean also had the pleasure of doing the maiden flight. The windwas gusty but he made it look really smoothand easy.
Enjoy.
Eric
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by grumpE -- 6/10/2007 4:15:19 AM >
Keep your stick on the ice and remember, we're all in this together..................................
(in reply to Sparhawk)
       Post #: 1006
RE: AKM SU-27 Flanker-Does Look Good - 6/11/2007 2:59:01 PM
bob27s
Status: offline
Excellent...... and congrats on the first flight... the plane looks awesome in the air
Bob
Bob Brassell
(in reply to grumpE)
       Post #: 1007
RE: AKM SU-27 Flanker-Does Look Good - 6/17/2007 5:47:14 AM
jodini
Status: offline
Went out for a few more flights on the SU-27. The more I fly it...the more I like it! I'm slowly taking out the expo on my elevators. Made a cool landing today...came in hot and at the last second, pulled the nose up to about 40 degrees and it just made a perfect airbrake landing. Very cool!
My second flight up though, I came down for a fast pass and notice something fluttering. Came down for a landing and when I checked out the elevator, it was O.K. but the whole back stab had broke and was just being held by Ultrakote.....THAT WAS CLOSE!
So I added some 1/2 tri-stock and hopefully that will hold. I just hope that it wasn't caused by fluttering of the elevator!
       Post #: 1008
RE: AKM SU-27 Flanker-Does Look Good - 7/10/2007 2:59:50 PM
jonathanmanopla
Status: offline
hello people i buy a AKM su-27 flanker but i want to know if the plane with and OS 61 with tuned pipe y suficient to fly o really need other engine like 91
(in reply to Cyclic Hardover)
       Post #: 1009
RE: AKM SU-27 Flanker-Does Look Good - 7/10/2007 3:15:33 PM
Isaac F
Status: offline
Hey guys,
I also want to order one of this AKM SU 29 Flanker. I am thinking on installing some hobbico mechanical retracts and since I already have a OS61 and a tune pipe I also want to know what you think about this set up.
Have any of you have intall a OS 61 on this airplane? How do you think it will fly?
Thx for your time and help,
Isaac
< Message edited by Isaac F -- 7/10/2007 3:16:22 PM >
(in reply to jonathanmanopla)
       Post #: 1010
RE: AKM SU-27 Flanker-Does Look Good - 7/11/2007 12:56:41 AM
jonathanmanopla
Status: offline
hello i want to know if someone try to fly the AKM SU 27 FLANKER with a .61 engine with or without tuned pipe
(in reply to Flyboy Dave)
       Post #: 1011
RE: AKM SU-27 Flanker-Does Look Good - 7/15/2007 6:20:28 AM
dr_wogz
Status: offline
Well, guess it's time to add my 2 cents to this 'super long' thread!!
I too am building one, for a club mate (I can't seem to say "no" to fellow flyers, and I guess I do good work if I seem to be constantly buidling other people's planes!!)
Fun build, but I wished I had more time & a bigger table to get this one done. You really need to get into a flow, and not have the concentration interrrupted. I feel I had maybe one or two too many while buidling, and some aspects were forgotten / blazed through.
I'm at the covering stage; 3/4 done (at top forward seciton). The guy wants plain, so it's all grey (he found a photo of an f-14.. "Like this"
This was totally the wrong plane to try Sig's new 'Aerokote' on!! I can only seem to get a few peices donw before I'm cursin' (I now have a new 'least favorite', sorry Sig..) I really shoulda stuck with Ultracote, or glassed it.
well, will report later, and maybe have some photos when I delivere it.
Failure is not an option.
It comes bundled with the software.
       Post #: 1012
RE: AKM SU-27 Flanker-Does Look Good - 7/18/2007 5:24:34 AM
Robert Strouse
Status: offline
I just completed mine and wow is it cool with one minor exception. At about 1/2 throttle the elevators go into a violent flutter. Anyone have any advice on how to fix this.
I installed the entire empenage as per instructions
1. Control surface gap is nearly nil. Couldn't fit a sheet of paper in there.
2. Zero slop in the control linkage.
3. HS625MG servos with 76oz/in torque. The gear train seems to be pretty solid.
Near as I can tell the only thing is a little torsion flex in the 4-40 control rods that run to the elevators.
Help would be appreciated since my Russian air superiority fighter could be taken out by a Spad right about now.
