RE: AKM SU-27 Flanker-Does Look Good
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: AKM SU-27 Flanker-Does Look Good Page: <<   < prev  35 36 37 38 39 40 41 [42] 43 44   next >   >>
Login
RE: AKM SU-27 Flanker-Does Look Good - 8/27/2007 3:28:35 PM
bob27s
Status: offline
that is looking good Jonathan !
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to jonathanmanopla)
       Post #: 1026
RE: AKM SU-27 Flanker-Does Look Good - 9/8/2007 3:26:36 AM
AK Models
Status: offline
I have not been to this thread for a long time, looks like you guys are busy...
I did notice that I have been selling this kit more than ever, Thank you to all that contributed their ideas and tricks to make it a good flying plane!
Thanks.
Come visit AKM website @
http://ak-models.com/
(in reply to bob27s)
       Post #: 1027
RE: AKM SU-27 Flanker-Does L... - 9/8/2007 3:47:02 AM
AK Models
Status: offline
quote:
ORIGINAL: Sparhawk
Shameless bump, but is there anyone else out there in the process of either flying, building, or planning to build one of these this winter?
Come on guys, there must be others with built Flankers and pics to post???
Spar
Anyone with info on Alex's (AKM) F16?
How many out here would be interested to try F-16 as test built/refine/test fly program? I would offer very limited maybe 5 kits (as always all laser cut) and plans (simple, not much text), but very useful. I do have canopy, nose cone molds and tail cone molds.
I had one built myself, it comes together very easy, I also had another guy try one of them, but he went off the plans and decided to go with Full Fly stab, witch killed it.
See his built thread here: http://www.rcgroups.com/forums/showthread.php?t=504463
Please let me know directly at akm@mchsi.com or post it here as well.
(in reply to Sparhawk)
       Post #: 1028
RE: AKM SU-27 Flanker-Does L... - 9/8/2007 5:45:11 AM
JEFFHINES73
Status: offline
F-16
How much for these kits and how much to ship one to australia I will fly anything once given the chance
Also need to give ya a ring on the phone alex about getting a SU-27 shipped over here when is the best time to call ya
thanks
jeff
jeffhines73@yahoo.com.au
My tongue misbehaves and digs myself a grave
(in reply to AK Models)
       Post #: 1029
RE: AKM SU-27 Flanker-Does Look Good - 9/9/2007 5:40:56 AM
nchrome
Status: offline
I would be interested in one. Just need to know for sure what retracts I would need or if it will fly just as good with fixed gear. Kind of a limited budget. I've flown my SU-27 a few times but am having a little trouble keeping the nose up with out useing rudder in a high speed turn. would like to get away from this if at all possible. Is it possible to move the fuel tank back a little farther without too much modifying of the frame (fuse) Or could there be something else that I'm missing that is causing this problem. I have a ST-61 with the big ugly muffler on it but I do plan on getting a tuned pipe for it to help reduce some of the nose weight. I also have a problem with the nose wheel flexing too much and hitting the prop before I can get airborn. It doesn't happen al the time but when it does kindof ticks me off.
(in reply to JEFFHINES73)
       Post #: 1030
RE: AKM SU-27 Flanker-Does Look Good - 9/10/2007 2:08:30 AM
bob27s
Status: offline
quote:
ORIGINAL: AK Models
Thanks.
Its a good project..... and a good flying aircraft.
Does not take much to convince folks of that
Bob Brassell
       Post #: 1031
RE: AKM SU-27 Flanker-Does Look Good - 9/10/2007 2:33:53 AM
Sparhawk
Status: offline
I would love to have one, but it would definitely be a winter build as I have almost zero time right now, due to work.
So, c'mon people, ante up. Good builders are needed for the test group.
Spar
(Alex - nice to see the pics of my Flanker on the website... looking good! )
Oh great are the days my landings = my take-offs....!
Revver Bro #158
       Post #: 1032
RE: AKM SU-27 Flanker-Does L... - 9/10/2007 3:00:43 AM
Cyclic Hardover
Status: offline
quote:
ORIGINAL: JEFFHINES73
F-16
thanks
jeff
Well since I started this thread, I vote for the guy down under. Sort of a buy one get one free.
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
       Post #: 1033
RE: AKM SU-27 Flanker-Does Look Good - 9/10/2007 4:00:39 AM
Robert Strouse
Status: offline
ncrhrome,
I have a Flanker and my nose does not drop in a high speed turn and my nosewheel does not flex. It tracks like its on rails. It tracks so well that I am confident in pulling a full power 180 just a few feet from the ground. Knife edge flight requires very little rudder but does need a bit of down to keep it straight. I can get it to waterfall nicely when I cut the power back but recovers the drop easily with a little more rudder pressure and a bit of throttle.
However, a friend of mine has one as well and his C.G. is a little farther forward of mine. His nose does drop in the turns and you need to coordinate a little rudder to keep it level. I would recommend adding a bit of tail weight until the nose gear almost floats above the ground. To give you and idea when I land I hold the nose up to slow down and it doesn't drop until the plane is almost stopped. Sometimes I start turning it around to taxi it back with the nose in the air. Just sitting on the ground I can lift the nose about an inch and it will settle back on the tail boom.
My C.G. is located on the front bolt of the retract. Yeah, seemed a bit nutty to me at first too but it really makes the plane fly, track, and land well. You can almost reach out and touch it as it saddles right in for a landing. As for my friend I will readjusting his C.G. this week.
BTW I am running a 91FX with a 12x8 and a Jett pipe - What size prop are you turning I have gobs of clearance? I hope this helps.
Robert
(in reply to nchrome)
       Post #: 1034
RE: AKM SU-27 Flanker-Does Look Good - 9/10/2007 4:01:44 AM
Blade47
Status: offline
I will have time to build One.
Pete
Revver Brother #93
(in reply to Cyclic Hardover)
       Post #: 1035
RE: AKM SU-27 Flanker-Does L... - 9/10/2007 4:33:11 AM
Robert Strouse
Status: offline
Alex,
This is awesome news! How soon will you have the kits ready? The end of the flying season is drawing near and I would like to build another one of your kits.
Robert
       Post #: 1036
RE: AKM SU-27 Flanker-Does L... - 9/11/2007 4:37:57 AM
AK Models
Status: offline
For all Flanker lovers, see THE ORIGINALS HERE: http://ak-models.com/russia2007.htm
I will be offering ONLY 5 kits @ pure cost for test built.
Please understand that not all of you will receive the kit.
If test builts and fly goes well I will be glad to offer it as a kit. Thank you for understanding.
(in reply to Robert Strouse)
       Post #: 1037
RE: AKM SU-27 Flanker-Does L... - 10/2/2007 10:22:18 PM
rrendon
Status: offline
Hello everyone!!
I will like to thank you all for the informations!!I bought my SU-27 last week and I'm waiting on it.
Can somebody tell me how much time it takes to build the model working around 1 hour per day. (Aprox)
I'm from HONDURAS Central American and thanks god weather isn't a problem to fly on weekend.
I will try to take some pictures of our runway!!
Take care you all.
       Post #: 1038
RE: AKM SU-27 Flanker-Does L... - 10/2/2007 10:41:58 PM
jonathanmanopla
Status: offline
hello hola supongo hablas espaƱol que en ingles me cuesta un poco escribir te dire a mi me tomo un mes y un poquito mas terminar el avion costruyendo asi poco a poco la cosa es tener todo al tiempo para no tener que parar por que te falte una pieza , pero es un avion de muy facil construccion con todo y eso que yo le hice unos cambios instalandole retracs mecanicos en ves de los spring air en este foro puedes ver la fotos y de muy buenos acabados espero te val
