RE: AKM SU-27 Flanker-Does Look Good
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: AKM SU-27 Flanker-Does Look Good Page: <<   < prev  35 36 37 38 39 40 41 42 [43] 44   next >   >>
Login
RE: AKM SU-27 Flanker-Does Look Good - 10/5/2007 2:30:35 PM
jonathanmanopla
Status: offline
quote:
ORIGINAL: nchrome
Hope that's not a ST61 on the nose of your bird. Cause I have one on mine and I am very unhappy with it. I'm going to replace it with a SK 70. These engines are very nice and will turn an even bigger prop that what a regular 90 would turn. But its your plane and I hope that everything goes OK for you. Mine would drop the nose on a steep turn unless I added a lot of opposite rudder to keep it up.
hello nchrome the engine that i have in my SU is a super tigre .90 i only do the break in alredy in other of my plane is brand new and i hope its work great , in this moment after 5 flights of that engine is working good thanks
(in reply to nchrome)
       Post #: 1051
RE: AKM SU-27 Flanker-Does Look Good - 10/5/2007 11:34:48 PM
jonathanmanopla
Status: offline
the last picture of my plane the finish
i hope you liked
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Flyboy Dave)
       Post #: 1052
RE: AKM SU-27 Flanker-Does Look Good - 10/6/2007 12:37:51 AM
Steelie
Status: offline
Me gusta mucho su avion. Buenos suerte con fuga primero.
_____________________________
Time is fun when you're having flies.
(in reply to jonathanmanopla)
       Post #: 1053
RE: AKM SU-27 Flanker-Does Look Good - 10/6/2007 3:47:03 AM
Sparhawk
Status: offline
Very nice!
I noticed that the tailcones are not on yet. Are you leaving them stock, or sanding them so that look more smoother than the square laser look?
Spar
Oh great are the days my landings = my take-offs....!
Revver Bro #158
(in reply to Steelie)
       Post #: 1054
RE: AKM SU-27 Flanker-Does Look Good - 10/6/2007 4:34:52 AM
jonathanmanopla
Status: offline
quote:
ORIGINAL: Sparhawk
Very nice!
Spar
hello the tailcones i have to painting yet because of that you dont see but the plane i alredy to fly
thanks for your question
(in reply to Sparhawk)
       Post #: 1055
RE: AKM SU-27 Flanker-Does ... - 10/6/2007 5:22:02 AM
lear31A
Status: offline
You built that in only 1 month! VERY nice work! I bet you went through alot of those Marlboro reds!
Will fly for coffee
       Post #: 1056
RE: AKM SU-27 Flanker-Does ... - 10/6/2007 3:47:26 PM
jonathanmanopla
Status: offline
quote:
ORIGINAL: lear31A
helloo jejejeje ooooohh that marlboro box its not my i dont smoke is of my father i dont like nothing of that i be a sport man
jejejej thanks
(in reply to lear31A)
       Post #: 1057
RE: AKM SU-27 Flanker-Does Look Good - 10/22/2007 9:46:34 PM
reyesraul
Status: offline
Jonathan
Qué tal vuela el SU-27?
Recomiendas este kit?
       Post #: 1058
RE: AKM SU-27 Flanker-Does ... - 10/22/2007 10:25:43 PM
rrendon
Status: offline
I already got mine and its really easy to build,I started two weeks ago but I don't have that much time to work on it.
I will like to know which Pilot can I used....Can somebody give me an idea on the scale and were to look for.
Roberto
       Post #: 1059
RE: AKM SU-27 Flanker-Does Look Good - 10/22/2007 10:40:36 PM
jonathanmanopla
Status: offline
quote:
ORIGINAL: reyesraul
Jonathan
hola te digo la verdad el avion como kit es muy bueno para el armado las peizas encajan a la perfeccion lo unico que no incluye nada del hardware necesario pero eso es lo de menos , y por lo de volar no pude este domingo que paso que iba a ser el vuelo inagural ya que yo al cambiarle el sistema de retracs tengo 9 servos en ves de los 7 que dice el manual estoy esperando que me llegue una bateria de 2500 mah y 6 v para mayor confiabilidad y duracion
en el momento que lo vuele te aviso que tal
saludos jonathan
(in reply to reyesraul)
       Post #: 1060
RE: AKM SU-27 Flanker-Does Look Good - 11/8/2007 12:17:50 AM
rickpaw
Status: offline
Hi guys,
I've been reading the thread from page 1 and decided to build one myself. Will build according to instructions with the exception of epoxy bearing on the lower fin for the rudder torque rods. I won't bore you with the construction pictures, as you all have seen them all. I will post pics of the finished aircraft.
       Post #: 1061
RE: AKM SU-27 Flanker-Does Look Good - 11/8/2007 3:28:09 AM
Robert Strouse
Status: offline
quote:
ORIGINAL: rickpaw
Hi guys,
Rick,
This is an awesome aircraft. Good luck on the build. I do have one other suggestion on the mods since I have seen two of these and both were afflicted with the same issue. The 4-40 rod on the elevators allows too much flex and will cause a violent flutter. If you change out the 4-40 rod on the elevators for 1/8" music wire this issue goes away and its not too difficult to accomplish. I described a method for doing this a couple of pages back.
Anyhow its very well designed, looks good, and flies even better.
Robert
(in reply to rickpaw)
       Post #: 1062
RE: AKM SU-27 Flanker-Does Look Good - 11/10/2007 5:26:37 PM
rickpaw
Status: offline
Robert,
I'm way past the point of fixing the torque rod as the fuselage is almost done and I'm moving on to the wings. I'll take a chance on this. I might beef up the whole stab assembly with carbon fiber rods, and will seal the hinge gaps for sure.
This is a great kit. All the parts fit well. I may get a second one.
(in reply to Robert Strouse)
       Post #: 1063
RE: AKM SU-27 Flanker-Does Look Good - 12/18/2007 3:17:17 AM
rickpaw
Status: offline
Well, here she is, ready to cover. I took Robert's advice and removed/replaced the stock 4-40 elevator torque rods with Dubro's heavy duty torque rod (#558). Seems to be strong enough to eliminate flex.
Power will be OS 91. Futaba radio gear, Robart retracts/struts. Right now I'm still debating on the paint scheme.
