RE: AKM SU-27 Flanker-Does Look Good    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: AKM SU-27 Flanker-Does Look Good
Page: <<   < prev  46 47 48 49 50 51 52 53 [54] 55   next >   >>
Login
RE: AKM SU-27 Flanker-Does Look Good - 10/29/2011 1:20 PM
ron9844
Score: 100
Last Login: 5/15/2013
Status: offline
Hi
Just received my short kit and it looks very nice. Trying to decide on the engine and retracts. I am looking foe an OS 91FX, Has anyone tried or used the new E-FLITE Electric retracts.
Thanks in Advance
Ron
Hide Signatures
(in reply to Cyclic Hardover)
       Post #: 1326
RE: AKM SU-27 Flanker-Does Look Good - 10/30/2011 4:14 AM
NoOneFlysAtMyClub
Score: 100
Last Login: 5/21/2013
Status: offline
Jaaron,
That is correct. When sanded to size, it is a little thicker than 1/8" an tapers some to the tip.
Very light and very strong. The kit is a joy to build.
Mine is all glassed an ready for painting. Have not decided on the color scheme yet.
Tony
Hide Signatures
(in reply to pedroglow)
       Post #: 1327
RE: AKM SU-27 Flanker-Does Look Good - 10/30/2011 4:58 AM
jaaron01
Score: 100
Last Login: 11/26/2011
Status: offline
I've got one wing built, and need to start on the other one.  I've decided to put some energy into the fuselage and get it completed/sanded and ready for covering.  I fuelproofed inside the engine area, and fuel tank area today.  Tommorrow I'll hopefully finish sanding the fuselage and be ready for covering that area.  I think i'm going to go with the red / while / dark blue theme.  Seems easy enough to see in the sky when it's traveling at high speed.
Thanks for the confirmation on the wing TE, just didn't seem correct to me, but I know I followed everything to the tee.  At least I got and answer and can begin to move forward with this craft.  It's been in the works for a couple years, then I got side tracked on a Top-Flite Stinson Relaint.  Couple years later, now that the Stinson has flown, it's back to the jet and get ready for spring time fly'in.
Jim
Hide Signatures
(in reply to NoOneFlysAtMyClub)
       Post #: 1328
RE: AKM SU-27 Flanker-Does Look Good - 10/31/2011 7:47 AM
NoOneFlysAtMyClub
Score: 100
Status: offline
Jim,
Mine has been in the ready for paint stage for two years.
I moved, changed jobs and built a few kits since.
Now I'm back on it.
I added non functioning canards to mine to mimic the SU-33.
The idea came from a post way back in this thread.
I will try to get a few pics loaded sometime this week to show what I have done.
Tony
Hide Signatures
(in reply to jaaron01)
       Post #: 1329
RE: AKM SU-27 Flanker-Does Look Good - 11/1/2011 4:53 PM
jaaron01
Score: 100
Status: offline
Last 15 Posts - reverse chronological order
NoOneFlysAtMyClub
Can you post a couple photos' of your wing tips?
Hide Signatures
       Post #: 1330
RE: AKM SU-27 Flanker-Does Look Good - 11/2/2011 10:55 PM
jaaron01
Score: 100
Status: offline
Got both wings put on today, but still got to complete the underside of them.  Also bought some servo's for the wings.  Lot's of sanding left to do. Also glassed the nose area, as I suspect it will receive some abuse.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1331
RE: AKM SU-27 Flanker-Does Look Good - 11/3/2011 11:15 AM
NoOneFlysAtMyClub
Score: 100
Status: offline
Jim,
Here are the wing tip pictures you wanted.
The missile rails in the kit look too short and fat, so I made new ones.
I am painting mine, so I fully sheeted the wing.
The whole plane is glassed and sanded at this stage.
I will post some pictures later of the whole plane.
Tony
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ron9844)
       Post #: 1332
RE: AKM SU-27 Flanker-Does Look Good - 11/3/2011 12:51 PM
jaaron01
Score: 100
Status: offline
I'm thinking of leaving the Missle Rails off mine, and adding a little more to the wing tip.  I know those will get caught on something heading out the to field, or while at the field, and that'll be it, so I'll just spair myself the upset now. Finishing off the wings today and getting the servos's placed.  Probably will go ahead and sheet the entire wing for a little added strength. Anyone else have photo's of there progress or lack there of?
Hide Signatures
       Post #: 1333
RE: AKM SU-27 Flanker-Does Look Good - 11/3/2011 9:46 PM
jaaron01
Score: 100
Status: offline
Seems like I was inhaling sawdust all morning, but finally got 1 wing completed, sheeted the entire wing, and the ailerons, installed the servo, and servo horns, beveled the aileron and dry fit the hinges.  1 wing down and 1 to go, then all attention goes back to the fuselage and the rear tail feathers.  Just out of curiousity what servo's are most using for the ailerons?  I was thinking just going with basic servo's for the ailerons, and the heavy duty for the rudder's and elevators.
Click for fullsize
Hide Signatures
       Post #: 1334
RE: AKM SU-27 Flanker-Does Look Good - 11/4/2011 8:24 PM
jaaron01
Score: 100
Status: offline
Got the other wing completed today and sanded, and now all attention has shifted back to the fuselage.  1 area I had problems with was the wheel wheel areas.  For some reason the tire mounts I bought for the retracts, were hitting the side of the engine nacelle.  So I dug out the area so the retracts would function correctly, and mulled over what to do in this area.
So today I decided to just cut and box the area instead of the deep gouge that was there.  See below.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1335
RE: AKM SU-27 Flanker-Does Look Good - 11/5/2011 8:28 PM
pedroglow
Score: 100
Last Login: 5/6/2012
Status: offline
Bueno,pues la guinda del pastel.......,,Al final me he complicado la vida un poquito y me he currado unas tapas de fibra de vidrio con resina epoxidica.
Y aqui la tenemos....... ,lista para cortar a medida,pintar y poner
Colocado todo el tema de receptor,pila,interruptor,comprobador de pila....etc...
Se acabó,ahora a esperar que venga un día bueno para poder estrenarlo.Lo próximo ya el estreno.
Saludos
Hide Signatures
       Post #: 1336
RE: AKM SU-27 Flanker-Does Look Good - 11/5/2011 11:20 PM
jaaron01
Score: 100
Status: offline
Just got back from the hobby store and bought some covering along with a trim seal tool, for ironing the small areas.  Thinking I'll start covering the wings tonite so I feel I'm making some progress.
Hide Signatures
       Post #: 1337
RE: AKM SU-27 Flanker-Does Look Good - 11/6/2011 12:22 AM
Steelie
Score: 100
Last Login: 3/29/2013
Status: offline
Bueno, me gusta mucho.
_____________________________
Freedom Flight. Is there any other kind?
Hide Signatures
       Post #: 1338
RE: AKM SU-27 Flanker-Does Look Good - 11/8/2011 11:25 AM
NoOneFlysAtMyClub
Score: 100
Status: offline
Here are some shots of my progress.
Fixing small imperfections.
Should be shooting primer in a few days.
The canard is fixed. Set at '0' with the stab and wing.
Power is a Super Tigre S.90K with tuned pipe.
Tony
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Steelie)
       Post #: 1339
RE: AKM SU-27 Flanker-Does Look Good - 11/8/2011 3:19 PM
Quikturn
Score: 118
Status: offline
Great job Tony,
I like those canards. Someone earlier in this thread talked about getting those to articulate. I thought a carbon fiber rod which carries through the fuselage could be used to connect both of them together. Then glue a control horn onto the rod inside the fuse. The question then is how to mix it in to the controls. It would be nice to have those canards assist in lifting the nose during slow speed flight (keep the nose up during landing) but I don't think it would be good to have them move during high speed flight.
Has anyone beefed up or made any mods to the elevator?
Ultrasport Brotherhood #45
P-40 Brotherhood #35
Hide Signatures
       Post #: 1340
RE: AKM SU-27 Flanker-Does Look Good - 11/9/2011 1:11 AM
jaaron01
Score: 100
Status: offline
Okay so no covering has been completed yet, due to other projects that have come about.  However after seeing those photo's with the Canard attached, you've got me thinking about them again myself.  While I wouldn't want to make them functional, they are very cool.............wheels are turning.
Hide Signatures
       Post #: 1341
RE: AKM SU-27 Flanker-Does Look Good - 4/15/2012 1:24 AM
SQUIZZY
Score: 100
Last Login: 4/16/2012
Status: offline
Can anyone tell me if you balance this plane with retracts positioned up or down
Hide Signatures
       Post #: 1342
RE: AKM SU-27 Flanker-Does Look Good - 4/15/2012 11:03 AM
NoOneFlysAtMyClub
Score: 100
Status: offline
UP!!!!
Hide Signatures
(in reply to SQUIZZY)
       Post #: 1343
RE: AKM SU-27 Flanker-Does Look Good - 4/15/2012 10:46 PM
SQUIZZY
Score: 100
Status: offline
Thanks Mate, as this is my first retract venture I was sure it was up but needed some asssurance.Just hope it flys as cool as it looks.
Hide Signatures
       Post #: 1344
RE: AKM SU-27 Flanker-Does Look Good - 10/1/2012 3:51 AM
jodini
Score: 100
Last Login: 5/19/2013
Status: offline
Hey Squizzy!
Hope you are still working on your bird!
I flew my SU-27 today. Was having problems with my Jett Engineering motor and final leaned out the low end and that did the trick! I was screaming down the runway and fell in love with this machine all over again! I didn't even put it in storage...going to keep flying it like I used to!
Keep up the good build!
Joe
Autogyro Crazy
Hide Signatures
       Post #: 1345
RE: AKM SU-27 Flanker-Does Look Good - 10/1/2012 5:47 AM
combatpigg
Score: 376
Status: offline
How fast do these "Extreme Speed Prop" planes fly..?
They look like a lot of work for a modest return in actual speed.
Would a sport plane like a Chaos or Ultrasport be as fast or faster with less power..?
< Message edited by combatpigg -- 10/1/2012 1:41 PM >
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to jodini)
       Post #: 1346
RE: AKM SU-27 Flanker-Does Look Good - 10/1/2012 8:18 AM
NoOneFlysAtMyClub
Score: 100
Status: offline
Yup!
Hide Signatures
(in reply to combatpigg)
       Post #: 1347
RE: AKM SU-27 Flanker-Does Look Good - 10/3/2012 4:44 AM
jodini
Score: 100
Status: offline
Probably...but it won't look as good going this fast!
Autogyro Crazy
Hide Signatures
       Post #: 1348
RE: AKM SU-27 Flanker-Does Look Good - 12/18/2012 6:09 AM
SpeedBoy
Score: 100
Last Login: 3/24/2013
Status: offline
quote:
ORIGINAL: NoOneFlysAtMyClub
Tony
Tony , do you have more progress on your Su-27 ???
Would be great to see it with color .
Living on a War Zone !!!!!
Seriously
Hide Signatures
       Post #: 1349
RE: AKM SU-27 Flanker-Does Look Good - 12/18/2012 7:17 AM
NoOneFlysAtMyClub
Score: 100
Status: offline
Speedboy,
My wife and i have spent the last six months building a new house. No hobby time.
Just now starting to get my hobby space set up.
The plane is in primer, final sand stage (before the move). I have three small dings to fix (so far).
I will probably start painting after the first of the year. When I do, I will post some pictures.
Tony
Hide Signatures
(in reply to SpeedBoy)
       Post #: 1350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
